Question about Craftmade International Dryers
Ceiling fan won't turn on with remote or wall switch
  • Deborah Oct 31, 2012
    The fan has remote and and wall switch which has not been used in app. a year. All new batteries in each unit.
  • Wayne Chung
    Wayne Chung Jan 26, 2013
    How do I reset minka aire fan so the receiver works properly
It is a new fan? If so electrician needed..
If not try replacing batteries in remote.... its happened to me...
Posted on Oct 31, 2012
Why Ceiling Fan Fixture does not work
You get what you pay for! Shouldn't buy a store brand.
Jul 14, 2014 | Hunter 52" Ceiling Fan With Light And...
Just installed a heller ceiling fan with remote, it works fine from the remote but the light nolonger works from the light switch
All the switch on the wall does is turn the power on/off. You have to do everything from the remote with the wall switch on.
Dec 27, 2013 | Hampton Bay 24002 Ceiling Fan
Hunter fan works light broken
Check to make sure light wires are connected at light kit & remote. Otherwise it's probably a bad receiver. If there is a pull chain for the light pull it once & try the remote light button again.
Mar 10, 2013 | Hunter Ceiling Fan Light Switch Control
My Fanimation Islander FP320 stopped working, I've replaced the wall switch but fan won't spin and lights won't dim.
Check to make sure your fan is set on the high speed & the light is at the on possition with the pull chains.
Jan 01, 2013 | Fanimation FP320OB The Islander® FP320...
Problem with hunter ceiling fan 23272
The problem is with the remote receiver attached to the fan body. It is a small device that acts as a remote switch and this is cradled in a pocket inside the ceiling fan itself. If you are handy, you can replace this device yourself. I believe you need to purchase a new kit from Lowes that comes with a matched transmitter and receiver for fan control. Go to Lowes Lighting section for this product.
Jan 12, 2018 | Hunter Dryers
On the hampton bay remote control fan and light module, i do not have wiring diagram. from my ceiling box, i have a red, a black, a white, and a bare copper wire. I think it is because the light switch has...
Unfortunately, Mark it's really not as simple as it sounds, to connect the wires properly. Because of that third red traveler wire for the 3-way switch. Actually, ceiling fans don't work well, when a 3-way switch is involved, because it was designed only for lighting convenience. When the fan is turned on, the other ceiling lights will start to glow, whether they are ON or not..
You would be much better served if you can locate another line to come off of and wire to that. Of course,y you won't have the convenience of a wall switch to operate it. But, that's what the pull chains on the fan are for.
Hope this helped you and thanks for choosing FixYa.
Sep 04, 2011 | Heating & Cooling
Ceiling fan is all wired up and on ceiling but light doesn't come on or fan doesn't spin. I have checked connections and tested for power. Is there a switch or anything on receiver that needs to be...
Jerry, from what you said, I assume you have a remote controlled ceiling fan. If that's the case, check the batteries in the hand held and the receiver, to make sure they are charged. Also, make sure they are installed properly. The Owner's Manual should have a reference to setting or resetting the codes for the remote control (Hand Held & the Receiver). Check those to make sure they are matching. And don't forget, the wall switch must remain ON for the fan to work, even with the remote control. The remote simply overrides the wall switch, when in operation. You may have to use the pull chain to start the fan motor the first time, then the remote can take over from there.
Good luck. I hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 10, 2011 | Heating & Cooling
The remote controls the fan speed but wont dim or control the light. the unit wont work if the light switch is off so I cant use the fan at all unless the light is turned on
mcdevito75 here, Generally the Ceiling fan motor is hooked up by-passing the wall switch but still to the hot laed going to the wall switch whlie the lights are hooked up to the hot lead after the wall switch, So without the remote, Manually operate your fan and lights. First with the wall switch off the fan should work and the lights no work. Now turn the fan off with the pull chain on the fan shroud close to the ceiling. Now turn wall switch on and lights should work with wall switch and the fan should also work. if so, re-program the remote or change the batteries or even re--place the remote.
Jul 26, 2010 | Hunter Ceiling Fan Light Remote Control
Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
Jul 14, 2009 | Hunter Ceiling Fan Light Remote Control
Dryers Logo
925 people viewed this question
Top Craftmade International Dryers Experts
Craig Butler
Craig Butler
Andrew Taylor
Andrew Taylor
Bill Boyd
Are you a Craftmade International Dryer Expert? Answer questions, earn points and help others
