Question about Mitsubishi Vehicle Parts & Accessories
Car idles ok but cuts out when you try to drive it off
I have put new air flow meter on but still does not run
    Top Expert:
  • Mitsubishi Master
  • 79,847 Answers
The following are the general instructions on the start of diagnosing any electronically controlled engine or transmission problem.
The engine and the automatic transmission (transmission control is only for automatics, engine is still computer controlled no matter the transmission type) in this vehicle are computer controlled and in most cases when a fault occurs a fault code is stored in the memory of the computer control module. There are exception to this, such as the Mass Airflow Meter and fuel pressure problems. What must be done is to have all the basic testing done such as a scan of the system for fault codes as well as a check with a live data scanner tool for engine functions that are not within range of normal, a trained technician is required to know what is correct and what isn't, then based on careful diagnostics done from a factory repair manual the correct part is replaced or the wiring repaired or the computer replaced (known as the PCM or ECM,ECU), which is very rarely the problem. Other basic checks must be done as well such as mechanical problems with the engine as well as engine state of tune and mileage on the engine. The transmission can have mechanical issues as well such as no gear engagement at all or a failed pump or other pressure related problems. Also engine mechanical problems can and do cause many drive-ability related problem such as rough idle and other symptoms.
Posted on Nov 05, 2012
My 2005 gmc envoy keeps cutting off while driving
Run a diagnostic test to see what codes come up. Suspect the mass air flow meter.
Sep 29, 2014 | 2005 GMC Envoy
My car shut down wen im driving alot wen im at the lith 1996 mazda 626
have you checked if your air filter is blogged? since you removed the air flow meter and run ok means that the flow of the air is wrong read and the ECU is causing shut off the engine. Check also if the air flow meter itself is not working correctly.
Sep 26, 2012 | Mazda 626 Cars & Trucks
1989 jaguar xj6 keeps cutting off replaced fuel filter, fuel pump, air flow meter drives ok some times then quits and eventually starts back
If you have put in an after market fuel pump,the presure of the pump might be just at the limit.The same happen to me and it cost me $$$ to be told that my new pump was not OK.
May 19, 2012 | 1989 Jaguar XJ6
Can acts like it is going to stop running when you
try checking all air intake hoses from air cleanr to inlet manifold for splits or tears and if they are ok have your air flow meter checked
Apr 04, 2010 | 2002 Jaguar X-Type
2000 montero sports Stall while driving,
well u bought a foreign made car wat did u expect
Mar 10, 2010 | 1999 Mitsubishi Montero Sport
Idle problem
Try to disconnect the Air Flow Meter. It is the first plug just before the air filter/air intake box. If this improves your situation you will need to source a new or aftermarket Air Flow Meter.
Apr 17, 2009 | 1999 BMW 318 ti
89 crx idles funny
ok in new zealand we call it the honda idle.
it's not bad, but what we've found out is that it maybe you air flow meter.
get some airflow cleaner and clean the air flow meter and all intake parts. worst comes to worst replace.
Feb 19, 2009 | 1990 Honda CRX
Vehicle Parts & Accessories Logo
98 people viewed this question
Top Mitsubishi Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Navin Sharma
Navin Sharma
Are you a Mitsubishi Vehicle Part and Accessory Expert? Answer questions, earn points and help others
