Question about Bissell 8910 ProHeat Clear View Upright Vacuum
Belts fine but no suction Bissell 8910 - Bissell 8910 ProHeat Clear View Upright Vacuum
  • Official Brand Answer
  • 315 Answers
Here are some simple troubleshooting steps to help out: http://www.bissell.com/FAQDetail.aspx?id=1098
Posted on Nov 05, 2012
SOURCE: bissell model 8910 carpet cleaner
Depending on which style you have, it may have a opening on the right side as you look at the front of the machine. If not you may need to remove the cover. If it does it says "belt access" and has two 1/8" (about) slots in the cover. with a small screw driver or something similar insert tool into slot and gently pry(if you are looking from the side) the left slot up and towards the right and the right slot up and to the left. It will slowly (or quickly depending on how hard you have to push) pop up and you can slide it off and see the pump. I think it is easier to just remove the 4 screws that hold the pump in place so you can replace both belts at the same time and not struggle with having to stretch the new belts. The last time I did this the Sprocket(small metal peice with teeth that turns the brushes) had broken off. I cleaned and dried everything and used 30 second epoxy to glue the sprocket back on and it works fine lasts a long time. Once you have removed the 4 screws holding the pump you can use a flashlight and screwdriver, knitting needle, pen etc. to hook the belt from the brush on to the pump shaft(sprocket) very easy. You may need to tilt and angle the pump a little to gt the belt over the lip on the sprocket. Like I did when I did this you will need to put the smooth belt on over the pump shaft first then put on the brush belt and screw the pump back into place (4 screws just snug because you can easily strip the plastic mounting holes) and put smooth belt on the electric motor shaft. you may need to stretch the belt a little because it has no gears it is just friction that turns the pump. Clean and dry everything this will make this repair last longer. If you will take a few minutes after each use to clean at least around the belt area they will last a long time. You can even put a belt conditioner on them for added life. Have a wonderful day!!!!!
Posted on Nov 10, 2007
reddevil6
  • 1673 Answers
SOURCE: need to download users manual/how to install brush belt
http://bissell.com/images/UserGuides/7901.pdf
same as 8901
Posted on Jan 17, 2008
tooltech75
  • 80 Answers
SOURCE: bissell proheat model 8910 water will not come
  • check pump belt
  • seat tank properly
  • check tank filter
i have repaired many of these and found that 90% of the time its the pump! #41 on diagram < click
9% its the heater clogged up #65 on diagram < click
1st check the small problems i wrote above
if all else seems fine start by removing the heater and disconnect the hoses from it. blow through one end of the heater (should be no restriction)
Posted on Oct 08, 2009
Vac Belts
  • 701 Answers
SOURCE: change belt on proheat bissell 8910
I have added a link for the owners manual for your model and a link for the replacement belts you need.
8910 User Guide (PDF)
Bissell Proheat 8910 Replacement Belt
Posted on Oct 30, 2009
heatman101
  • 43501 Answers
SOURCE: Bissell ProHeat 8910 wont spray water or solution
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
sgb
Posted on Sep 30, 2010
The brush belt has come off my Bissell 8910. Part
heatman101
tey36
Apr 18, 2010 | Bissell 8910 ProHeat Clear View Upright...
How to replace elt on bissell 8910
I have listed a link to the owners manual and a link to the belt you need. Hope it helps you!
Bissell 8910 User Guide (PDF)
Bissell 8910 Replacement Belts
Oct 31, 2009 | Bissell 8910 ProHeat Clear View Upright...
Change belt on proheat bissell 8910
Oct 30, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell proheat model 8910 water will not come
  • check pump belt
  • check tank filter
Oct 08, 2009 | Bissell 8910 ProHeat Clear View Upright...
Bissell 8910 ProHeat Clear View Upright Vacuum Logo
106 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
