Question about Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer
Washing machine will not start any cycles
It will not start in any cycle
    Top Expert:
  • Maytag Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 01, 2012
SOURCE: MAYTAG WASHING MACHINE
The rubber smell is the belt from the motor to the tub. The grinding sound is/was the tension pulley that keeps the belt tight. The bearing on the pulley probably went out and now the belt is burning because of the friction of sliding around the pulley. The belt and the pulley need to be replaced. If you have the room, turn off and disconnect the hoses. Unplug the electrical cord from the wall outlet. Remove the drain hose and any water in the tub. Carefully tip the washer over backwards, DO DROP IT!!! Now you should be able to see the motor, tub, tension pulley, and belt. With a basic 3/8' drive socket set, probably metric, and a couple of screw drivers you should be able to remove the belt and the pulley. Take the belt, pulley, and model numbers to an applicance parts store and buy replacements.
I only suggest this because I hate paying labor. If you are not machanically inclined then you are going to have to pay the labor.
Good Luck
Posted on Dec 19, 2007
  • 41 Answers
SOURCE: washing machine leaks from underneath after rinse cycle
i would 1st look to make sure the drain hose is not loose or broken. be sure it is staying in the drain pipe in the wall.it could be a cracked housing on your pump. hope this helps
Posted on Jul 11, 2009
  • 76 Answers
SOURCE: water leaks out of bottom of machine olny when
This can happen when the rubber pipe that connects between the electric tap and the washing tank got disconnected .
Usually it happens after washing fully load machine with towel, blankets etc.
Open the back of the machine and check the rubber pipe, if loose or out of position get it back in to place and tight the metal bands that hold it .
Posted on Jul 15, 2009
  • 27 Answers
SOURCE: The washing machine started making a grinding
sounds like a bearing... although it could be the water pump... water pump is an easy fix... bearing is not an easy fix... take the belt off the bottom of the pump (under the machine) and see if it spins freely by turning it w/ your hand... or if it seems really stiff... if it looks good then it's def. your bearing...
Posted on Jan 15, 2010
barkencoa
  • 3463 Answers
SOURCE: washing machine is jumping around on the spin cycle
A few possibilities here.
Make sure the washer is level, both back to front, and side to side.
Do not over load, and make sure that there is more than 1 article in it, otherwise you will get an out of balance load.
Make sure the water is drainlng away properly.
Check the drum for excess movement, this would indicate a broken spring or worn drum bearings or worn or broken drum shaft.
Check the concrete wieghts at the top and bottom are not loose or broken.
Check the suspensions for excessive wear.
Hope this helps
Posted on Mar 31, 2010
LG Turbodrum DD 8.5kg WT-R852 washing machine, will not completely fill with water to water, to initiate the wash cycle, wash process stops there.
THE WASHER IS OBVIOUSLY HAVING A PROBLEM DETECTING THE WATER LEVEL? IT DETECTS AS FULL WHEN ITS NOT AND THEN GOES INTO DRAIN CYCLE? THE FILLS AGAIN? I would suspect the water pressure switch but if it was detecting a full cycle it would sent it into wash cycle? the water inlet valve only allows the amount of water it is told to send in and does not control the amount or drain cycle. Im not sure here but Im thinking maybe the water level switch may be flawed, the one that has low-medium and high? all these can be checked with a multimeter
Mar 01, 2015 | LG Washing Machines
Why my washing machine will start the wash cycle but will not spin or rinse?
the drain pump is probably blocked or overheating, when it starts beeping which lights are flashing reading from right to left e.g. 1,3,5 also what is the model number?
Aug 17, 2014 | Fisher and Paykel Washing Machines
Whirlpool adp 9411
If this is the machine with just a knob for the wash cycles, and one button to start the wash cycle, you will have to replace the timer. There is no reset that I know of.
Dec 16, 2013 | Dishwashers
My neptune washer will start and run about half a cycle and it acts like it gets stuck and on one cycle and never shuts off. I put a load of clothes in before I went to bed and next morning the machine...
What does half a cycle mean are you in Wash cycle, Spin Cycle? What does the Cycle Status LED indicate?
If you think the wash load is in a spin cycle of the wash cycle or rinse cycle place the machine in Spin Only cycle and see if it will complete.
Waht are your DIY skills? Do you want to try the repair/fix?.............Rich
Oct 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Wash Cycle doesn't start
Unplug the machine for about fifteen minutes. When your fuse blown it caught in the middle of the cycle. By unpluging it will reset the machine.
Dec 07, 2009 | Washing Machines
Nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
Jun 30, 2009 | Washing Machines
Washing machine begins the wash cycle going immediately to the agitate cycle, without filling up with water first.
water will not stop running into drum unless shut off at faucet does not happen all the time and wife can't find her rubber boots
Apr 26, 2009 | Washing Machines
Washing machine does not stop filling
Does the machine start working normally after turning the wash cycle manually ?
Feb 15, 2007 | Roper RAS8445KQ Top Load Washer
Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer Logo
91 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
