Question about Mitsubishi Vehicle Parts & Accessories
Car idles ok but when you depress accelorator it splutters and cuts out when you try to drive it
It will not pick speed up at all
    Top Expert:
  • Mitsubishi Master
  • 76,691 Answers
Duplicate question.
Posted on Nov 05, 2012
Hesitates on acceloration
Clean the throttle body and the idle air control motor. Pull the Idle motor and clean it with a brush and pick. Use brake clean. Get as much black/carbon off of it as you can.
Sep 04, 2014 | Cars & Trucks
2005 kia Rio Cinco. Runs really rough when starting it up; running ok when gas pedal is depressed. At idle speed it is bogging out almost stalling???
what is the idle speed? 750 rpm in drive or 800 in neutral?
check that
check for loose or damaged vacuum hoses, and air filter box leaks
Aug 07, 2014 | 2005 Kia Rio Cinco
Dangerious engine splutter
Has anyone checked the fuel pressure, and has the fuel filter been replaced ?
Jun 25, 2013 | 1999 Chevrolet Blazer
My diesel vw transporter misfires/splutters on
I have just had my T4 2.4 cambelt and water pump done but the van does not run right unless the choke is out any ideas?
Many thanks
Mark
Mar 31, 2010 | 1999 Volkswagen Euro
'97 540i spluttering & cutting out
best bet is to go get any codes that may be stored in the PCM. This will take alot of the guess work out of diagnosing it. Or remove the spark plgs and replace them.. If you have 50,000 or more this could be the cause but a code may tell you which one is the issue
Nov 30, 2009 | 2009 BMW 5 Series
2002 hyundai santa fe will idle but has no powerwhen driving have to shift transmission manually no matter how much you press on gas you dont hardly pick up speed will not tach over 3 idling around 2 when...
I assume your vehicle is 3.5 V6?... What you describe is 'LIMP HOME' mode of the Electronic Throttle System. Have it PROPERLY diagnosed by a qualified Hyundai Technician.... ONLY SOLUTION ( NOT JUST THE BEST SOLUTION).
Sep 08, 2009 | 2002 Hyundai Santa Fe
Adjusting carburetor on poulan chainsaw
Does saw try to run? Initial settings are about two turns out from CW stop. Set high speed (on warmed up engine) to 4-stroke with no load, but smooths out with light load (cutting wood). Idle is set for fairly smooth idle, but engine picks up with throttle without lag. Idle speed setting is somewhat below chain drive clutch pickup, but allows engine to keep running.
Jul 04, 2009 | Garden
Struggles to stay at certain speeds PLEASE HELP!!!!
how many km on it?it sounds like the plug wires if it gets worse on wet days
Jun 26, 2009 | 2000 Oldsmobile Silhouette
Have 1987 nissan sentra wagon 1.6 carb.engine the problem is an idle problem when I start in the morning or when its had time to cool down I depress the accelorator pedel to set the choke and high idle cam...
Check your Ignition timing before anything
check your plugs see what color they are
red or orange means carb is to lean , black
or oil means to rich then you can go from there
and set mixture screws on carb , let me no how you make out .
Mar 09, 2009 | 1987 Nissan Sentra Wagon
Vehicle Parts & Accessories Logo
Top Mitsubishi Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
fordexpert
Are you a Mitsubishi Vehicle Part and Accessory Expert? Answer questions, earn points and help others
