Question about NetComm V210P
Cannot access 192.168.22.1
Cannot display Login page for set up
  • Yolanda Nov 02, 2012
    Up and running now, thank you for the information - it was a great help.
  • 3,606 Answers
In order to restore your router to its factory default settings, please follow these steps:
• Ensure that the ATA is powered on (for at least 20 seconds).
• Use a paper clip or a pencil tip to depress the reset button for ten seconds and release. At this point, the reset is in progress. Do not
power off the unit at this point.
• After the ATA reboots, the default settings are now restored. This entire process takes several minutes to complete.
• Once you have reset the ATA to its default settings you will be able to access the device's web configuration using
http://192.168.22.1 with username "admin" and password "admin".
1. Connect the WAN port to your broadband router using the Ethernet cable supplied. If you would like your PC to be connected to the network through the V210P/V220, you can connect another Ethernet cable (not supplied) from your PC to the LAN Ethernet
port. This enables your PC and the ATA to share one Ethernet port on your router/switch.
2. Connect your telephone handset to the Phone port. For V220, you can connect an additional handset to Phone 2 port.
Notes: A second VoIP account is needed unless your VoIP provider supports multiple connections from the one account and both ports need to be configured
individually (even when using one account that supports multiple connections).
3. For V210P unit, connect the Line port to your PSTN wall socket.
4. Connect the AC power adaptor and press the power button to turn the ATA on. The ATA will boot up and in a few minutes, the
Power and Ethernet Lights will light up.
You can read more here:
http://www.dodo.com/top-right-navigation/support/technical-support/voip/setup-guides/netcomm-v210p-setup-guide/
Good luck
Posted on Nov 02, 2012
When I attempt to access some web addresses, i.e. https://eds.ospi.k12.wa.us/ the login page briefly displays and then goes to a YAHOO page with this message "The requested URL...
your system must be bad .I copied and pasted the url that you asked about and it came up just fine to the login page .I use google chrome
Aug 09, 2017 | Computers & Internet
Another business we share an office with wants to use our photocopier. How do we set up their own password to enable this to work.
You can always find solutions to Xerox problems @ www.xerox.com/support Once you set this up both you and your neighboring business will BOTH have to use individual codes. Hope it helps!
Solutions for : How To Set up or Modify Auditron User Accounts Solution : Set up or Modify Auditron User Accounts The following information describes how to register userIDs and usernames, login names, and passwords for authenticating accesses attempted through the network for scanning services, and impose restrictions on the maximum number of pages to be copied or scanned. Up to 500 user accounts can be registered.
NOTE: You must be a System Administrator to perform this solution.
  1. Press the [Log In / Out] button on the Control Panel. The Login screen will be displayed.
  2. Enter the System Administrator userID using the numeric keypad on the Control Panel, or select the [Keyboard] button on the Touch Screen to enter the userID, and then select [Save] on the Touch Screen.
  3. If necessary, enter the System Administrator password using the numeric keypad, or select the [Keyboard] button to enter the password, and then select [Save] on the Touch Screen.
    NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed.
  4. Select [Confirm] on the Touch Screen. The System Administrator Menu screen will be displayed.
  5. Select [System Settings]. The System Settings screen will be displayed.
  6. Select [Login / Auditron Administration]. The Login Setup / Auditron Administration screen will be displayed.
  7. Select [Create / Check User Accounts]. The Create / Check User Accounts screen will be displayed.
  8. Select a user account number or use the numeric keypad to enter a user account number in the Go to (001-500) field.
  9. Select [Create / Delete]. The User Account screen will be displayed.
  10. Enter a userID using the keypad on the Touch Screen, and then select [Save]. The Create / Delete screen will be displayed.
  11. Select from the following options:
    • UserID: Allows a userID to be entered using the keyboard on the Touch Screen. Up to 32 alphanumeric characters can be entered including spaces.
    • User Name: Allows a username to be entered using the keyboard on the Touch Screen. Up to 32 alphanumeric characters can be entered including spaces.
    • Password: Allows a password to be entered using the keyboard on the Touch Screen. 4 to 12 alphanumeric characters can be entered. The Password button is also displayed if a password was selected on the Login Setup / Auditron Mode screen.
    • Remote Login Settings: The following settings can be modified on this screen:
      • Login Name - Allows a login name to be programmed that needs to be entered when the machine is accessed through the network.
      • Password - Allows a password to be programmed that needs to be entered when the machine is accessed through the network.
    • Account Limit: Select [Copy Service] or [Scan Service], and then select [Account Limit]. Using the numeric keypad on the Control Panel, specify and restrict the maximum number of pages to be copied or scanned for the account. The maximum number can be entered within the range of 1-9,999,999 pages.
    • Reset Total Impressions: Deletes all data tracked for the selected account.
    • Reset Account: Clears all settings and data for the selected account.
  12. Select [Save].
  13. Select [Close] three times.
  14. Select [Exit].
Feb 03, 2011 | Xerox CopyCentre C123 Copier Copier
My apple laptop MacBook 13 has a message on the screen that is prompting me to enter a username and password. I have never set up a username and password so how do i bypass that page? or what can i enter...
Apparently someone gained access to your Macbook and enabled the password login feature of the operating system.
The login window that is displayed has a button for "Forgot Password". Click this button to see whether the person that set the password lock provided a cute hint for the password.
If they did not provide a hint, I would question anyone that has recently had the opportunity to access your Macbook to see whether they set the password lock. They would have the password.
Dec 20, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Hi, Can't connect my cisco 857w to my pc
make sure in your pc you set the obtain ip address automatically to your lan card and reset the router also and access the ipconfig command and check the ip address and access the login page thru internet explorer and do the setting for wireless access.
Jan 14, 2010 | Cisco 857W (882658019555) Router
Can't log in to any Yahoo page
Try using mozilla firefox browser.
Jan 03, 2010 | Yahoo Mail
Cannot access Belkin security settings
avast virus disable it then try it you get the other wise reset the router and re-configure it after reset you get the all configuration in default setting then you easly get it but anti virus disable then work after then you can enable
Feb 26, 2009 | Computers & Internet
Need to establish PIN/Code for machine - help xerox c123
  12. Select [Save].
  14. Select [Exit].
Jan 08, 2009 | Xerox CopyCentre C123 Copier
How to turn off the router's firewall
1. Insert the Product CD into your CD-ROM drive. The CD will run automatically.
From the Utilities section, select to install the uConfig utility to your hard disk.
2. When the utility has been installed, double-click on the uConfig icon. The
following screen will appear, click on the Yes button to proceed.
3. Select the router from the products list and click on the Open Web button. To
retrieve and display the latest device(s) in the list, click on the Refresh button.
4. Do not exit the uConfig program while accessing to the web-based interface.
This will disconnect you from the device. Click on the OK button to proceed.
5. At the login page, press the LOGIN! button to enter the configuration page. The
default password is “password”.
6. For the first time login, you will be prompted to select your time zone setting first
before accessing the router’s main web page. Take note that during the next
and subsequent logins, you will not see the System Time Setting page again.
7. You will then reach the web page of your router’s web-based interface.
8. Under the SECURITY CONFIGURATION command menu, click on Firewall
Configuration.
Oct 22, 2008 | Compex Computers & Internet
Can't access webpage outside of my USR5461
Did you get this resolved. I have the same problem, I get the router's login page when I try to access from outside.
Aug 05, 2008 | U.S. Robotics USRobotics USR5461 Wireless...
NetComm V210P Logo
1,455 people viewed this question
Top NetComm Computers & Internet Experts
Prashant M
Prashant M
mega_mind
Are you a NetComm Computer and Internet Expert? Answer questions, earn points and help others
