Question about Philips (NAP313922881592) Remote Control
How to open a Phillips remote control???
Would anyone know how to open a Phillips 313923810941? Its a basic tapered remote for TV with the red, green, yellow and red buttons along top, underneath the power button. Pretty sure i can fix it if i could get it open. Have already taken the screw out.
  • Julz Warahi May 22, 2007
    hi thanx any way, i got some movement from the bottom section but the top was firmly stuck??? i was too scared to force it any further!!! appreciate the help, if you have any other tips, i would appreciate it.
  • 45 Answers
Force it by using a thin-tip flat screwdriver on its side, then to all sides until it will be open.
Posted on May 17, 2007
  • Aleksandr Sanchez May 22, 2007
    look for any sticker, screws are often hidden by a sticker. if no more screws, all you have to do is force it.
I have a spare Phillips that sounds like the one you have. I will send it to you for the shipping cost if it matches your TV. Please contact me, KD4ML at JUNO.COM for photo. Aloha, Howard
Posted on Aug 18, 2007
How to setup phillips universal remote to a panasonic tv
Philips Universal Remote control Instructions
  1. Turn on the device (TV, DVR, etc.) you wish to operate.
  2. Press and hold the SETUP button until the red light indicator remains lit, then release the SETUP button.
  3. Press and release the desired mode button (TV, DVR, etc.).
More items...
Philips Universal Remote control codes for TV, VCR, Set-top Box ...
www.directutor.com/.../philips-sru210327-universal-remote-control-codes-tv-vcr-set-top... How to setup phillips universal remote to panasonic tv Google Search
Nov 29, 2016 | Panasonic Televison & Video
Does anyone know how to open the case of Philips TV remote control RC4401?
This remote control is not clicked as you may expect, it's been screwed inside.
To open the remote control, you have to gently peel off the front gray panel using a unsharp knife, beginning to the top (near the power button).
Once removed, you can access to 10 small screws that holds the blue frame (partly visible on the edge).
Once opened you can access to the electronic and the buttons.
Then you will certainly be disappointed to discover that some buttons (the Power for example) are not reparable. A small pin breaks when excessive force is applied. Gluing this pin does not help either.
This is a throw away remote control, better buy a universal that does the most used functions.
Oct 30, 2014 | Televison & Video
Technika 19-228
It sounds like you are using a component video cable (red/green/blue) and either the red or blue cable is loose or broken. Most likely the blue. Check both at DVD and TV ends.
Dec 30, 2013 | Televison & Video
I have a new sharp aquos tv LC 60LE633U. Remote is broken but have a universal Phillips remote anyone know the code ? Help please
Hello
Three digit universal remote codes for Sharp tV are:
004/ 009/ 079/ 095/ 111/ 112/ 114/ 122/ 123/ 124/ 173
Four digit codes are:
0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Feb 28, 2012 | Sharp Televison & Video
NEED SONY CODES FOR PHILLIPS REMOTE
Universal Remote Control Simple Setup
* Point it at a TV set and press the Mute/Power button. (Mute button if TV is already on, or Power button if the TV hasnt already been turned on)
* Keep pointing it at the TV until the TV turns on or muted, most TVs respond in about 5 seconds, the most is up to 20 seconds. (Other universal television remote you find in stores take minutes to program and enter long confusing codes)
* Once the TV is muted or turns on, simply let go of button and you have total control. You can use the remote as if you had the original remote, and responds instantly. ENJOY YOUR FREEDOM of choices with our remote!
Most remote controls require minutes of programming a universal remote code into each television while you read the confusing instruction manual.
Jan 02, 2010 | Philips Magnavox Learning Universal Remote
Projection tv is Blurry and offset
You have a focus and screen control box it has 3 controls on top 3on bottom these are the controls for Red-Green-Blue screen drives and for focus to each tube. IT should have Focus /Screen on it.
Dec 19, 2008 | Philips 50P8341 50" Rear Projection...
Mirai TV remote control set up code
does anyone know the codes for a mirai tv for a universal remote
May 07, 2008 | Jensen TS2750J TV
Please does anyone know how to manually tune in a phillips uvsh TV Model: 25pt4521/07. I don`t have original remote but universal one operates fine (except for tuning maybe !). thanks ****.
your gonna need the ORIGINAL REMOTE control BECAUSE it has those other special options design for this unit besides the basic operations . heres a link where you can purchase a new one , hope its helpful. http://www.replacement-remotes.co.uk/products/Philips-25PT4521-07.shtml
Apr 22, 2008 | Televison & Video
Tv codes
Hello, Well I have a Phillips universal remote but but maybe they are the same. For the Orion TV try 105, 115, or 713. For The Pioneer DVD Try 042. If one or more does not work, Look for a "code Search" button. Turn on the device, then push and hold down the code search button until the red indicator stays on, then release the search button. Press and quickly release the desired mode button (TV, DVD, etc). The red indicator blinks off once. . If it is a tv or vcr use the channel up button until the channel changes. Press the power button on DVD and see if it is right Hope this helps.
Mar 16, 2008 | Philips Magnavox REM-350 Remote Control
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Televison & Video Logo
5,306 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
