Question about Hotpoint Washing Machines
Washer dryer keeps tripping m/c trip switch
On drying programme it sometimes runs for 10 mins and somtimes for 30 mins.I have replaced the switch but still no good
    Top Expert:
  • Hotpoint Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 01, 2012
4 Suggested Answers
sx-engineer
  • 10 Answers
SOURCE: hi, my hotpoint wd860g washer dryer keeps tripping
The most common reason for this is a Short circuit dryer element.
the best way to find out is to isolate the dryer and try it.
UNPLUG FROM MAINS FIRST... remove lid, you will then see the dryer box. on there is a fan (2 wires) thermistor (little wire plug goes in there) possibly a thermostat with a red or yellow dot in the middle or it could be a thermal fuse which looks like a long yellow thick wire, and finally the element, There are 2 different types of element, what you need to do is disconnect the wires to the element, put insulation tape around the ends of the wires and tuck them out of the way of the metal dryer box.
Put it on a wash cycle, if it does not trip then it is the dryer element.
Please note, with these wires disconnected, you will not be able to do a dry cycle as lights will flash.
Hope this helps..
Please rate my help.
Regards
Sussex engineer
Posted on Oct 23, 2009
rylee_smith
  • 8619 Answers
SOURCE: Hoover Tumble Dryer trips out
Hi
Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Whenever this fuse goes bad it'll either trip the circuit breaker or the dryer wont heat. You can also check it for continuity with an ohm meter, no continuity means the fuse is bad and you need to replace it. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 21, 2010
Testimonial: "Thanks for your quick response I will try and work out whch one it is and replace it"
  • 142 Answers
SOURCE: my hotpoint wd440n washer dryer
Is it an immediate cut off when in the drying mode? That would indicate a short somewhere. If it takes a few seconds, I would check the circuit breaker. If it is smaller than 20 Amps it should be replaced. Also if you have aluminum wiring, it tends to "loosen up" which causes exra heat in the breaker, thereby accelerating cut off. Just tightening the connection takes care of that. Be sure to turn it off!!
Posted on May 08, 2011
My zanussi washer dryer keeps tripping the electrics
check ground wire for tightness on plug in and on breaker box.
Mar 31, 2012 | Zanussi ZWD12270 Front Load Washer / Dryer
My Campbell Hausfeld 30 gal 6.5 hp oilless compressor, WL611201 trips the breaker when I switch it on auto. But will not trip the breaker if I use the breaker as an on off swithch. However, it somtimes...
not likely as your pressure switch is pneumatic, What else operates on that same breaker, perhaps replace the breaker as they sometimes get "tired"
hope this helps
Let me know
Dec 18, 2010 | Campbell Hausfeld Air Tools & Compressors
Tripping house fuse
It would help to know what size breaker is feeding this dryer. If it is a two pole 30 amp, then I would first replace the breaker and see if the problem continues. I would check the name plate ratings of the dryer, should be rated at 229 volts and 30 amps. If it continues to trip the breaker, then I would be looking at the heaters in the dryer as the source of the fault,
Please vote !
May 12, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
My machine flicks the mains switch as soon as i turn it on, both washing and drying. it first flicked the safety switch about halfway through a dry load...what could it be?
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
This sounds like a heater issue since it's tripping the power on both the wash & dryer, in events of overheating the machine will trip your power for safty & to prevent the risk of fire however since you mention that it trips the power as soon as you switch it on you could have a blocked pump or burnt out motor too if your finding that the machine is tripping the power earlyer & earlyer each time you retry i would focas on the motor or the pump 1st
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys..
remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Apr 22, 2010 | Hotpoint Ultima WD72 Front Load...
Hi, my hotpoint wd860g washer dryer keeps tripping the fuse box. sometimes 20 mins in to a wash and sometimes up to 40 mins and then will keep tripping over and over. then it will run for a bit again and...
Hope this helps..
Regards
Sussex engineer
Oct 22, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
My DLE2514W LG dryer keeps running with 6 Min. Left
There is a humidity sensor (Hence the words Sensor Dry) inside the machine which trips out when it sees a lack of moisture in the air going past it.
It is not adjustable without special equipment
That sensor has failed and will need replaceing
Jun 07, 2009 | LG DLE2514 Electric Dryer
Washer and dryer keep tripping the elec outlet
either you have a loose wire in your box or at the machine
Mar 24, 2009 | Dryers
My new maytag centennial electric keeps tripping
Hi Matt
I'm not sure that swapping out the breakers to higher rated ones will give you a solution so I'll throw in 2 cents to see if my advice holds true. Let's start by asking this. Is the appliance "rated" at 220 volts at 30 amps per leg. I assume this from your post as to what it has been rated. Next - How long is the "run" of wire from the junction box to the outlet where the appliance plugs in? This usually does not matter in most households but if the run is of significant length it may need a larger gage wire to support the current draw of the appliance. Lastly, and perhaps most importantly, are the lugs and wire connectors tight at the outlet, the plug, and the breaker box. A loose connection will ramp up the current fast. This is assuming the first two items were met. Tell me if any of this helps and we'll work it out from there.
Thanks.
Len
Feb 28, 2009 | Maytag Centennial 7.0 Cu. Ft. Super...
Hoover HDV6UK keeps tripping circuit breaker
There are only 2 things that it could be both are heat related:
THe thermostat and thermal limiter OR the heating element. We can not rule out the motor though. Then you can get into the control boards. Maybe it is time.
Jun 05, 2017 | Hoover HDC6 Electric Dryer
Washing Machines Logo
50 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
