Question about Powermax Air Tools & Compressors
Wont start changed spark plug checked gas still wont start.
alicantecoli
  • 22326 Answers
SOURCE: 2000 ford focus wont start after driving thru a puddle of water
check the pick up sensor
Posted on Nov 12, 2008
  • 5 Answers
SOURCE: 2004 honda crf 150 wont start
how menney miles has it dun???check compreshon on bores.shoud be 110+psi 4 good running.
Posted on Apr 21, 2009
  • 376 Answers
SOURCE: mantis tiller sv-4 echo engine no spark from coil
Sounds like it's flooding either from over choking or the inlet needle in the carb is leaking. Have you removed the plug and blown out the cylinder and plug with air and then tried to restart? Be careful not to keep cranking with the choke pulled out. When it 'hits' ONE time, move the choke halfway in and crank again
Posted on May 31, 2009
  • 174 Answers
SOURCE: Honda Pressure Washer HP 5 not starting
You can try spraying some carburetor cleaner into the carb. If it starts for a minute, your carburetor need cleaning. When you added new gas did you remove the old gas first? Is the air filter clean?
Posted on Jul 19, 2009
  • 118 Answers
SOURCE: my lawnmower wont start. changed the spark plug,
Has it sat out in the rain?You may have rust on the magneto. Or there may be gunk in the carburetorSquirt just a little gas into the carburetor and crank it. If it fires up but dies, you have carburetor problems. If that is the case you will need tho remove it and clean it ( boil it in soapy water ).If no spark, you will need to remove cover and take off the magneto and sand off the rust. Then put a little oil on it to protect it. When re-installing it bring it to almost touching and tighten it.
Posted on Aug 05, 2009
Tiller will not start changed plug and cleaned gas and lines
check for a stop switch or wire from the switch being shorted out
Apr 17, 2016 | Yard Machines Garden
Honda lawn mower wont start
fuel spark air has to get all in the proper time to fire remove plug and squirt a little gas in hole put plug back and try again
Apr 18, 2015 | Honda Garden
Hi I did a tune up ,changed and checked every thing I done ..too I changed the oil ,oil filter ,gas filter air filter ,got a new battery changed the plugs there new too...even a new belt new key ...but...
Spark and gas??? Must have both. Pull spark plug wire and check for spark. If you have spark, check gap on spark plug. Check the bowl on carburetor. loosen bowl screw to see if gas is coming out. If you have gas coming out, carb needs to be taken off and cleaned or rebuilt.
Oct 11, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Will not start with new parts?
is the spark plug wet when you pull it out ? Is your gas fresh? Did you check for spark? If all is good then I would check compression, then Carb
Oct 21, 2011 | Craftsman 25cc Gas Line Trimmer
Engine wont start, has gas and spark?
Crank or cam sensor. Have a OBD II reader plug into it and see if you have any codes.
Feb 03, 2010 | 1999 Volkswagen Passat
Wont start with new plug. I can smell gas, but none on plug
Check the start stop switch, sometimes they can get dirty causing the saw not to get spark. Also maybe check Your air cleaner. if it's clogged it may be flooding itself out?
Jan 26, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
Wont start
Hi
Check the spark at the plug,the compression and carburation.Check and clean the gas and air filters.Disassembly thr carb and clean it with compressed air.Change the gas from gas tank and start the engine.
best regards savumihai71
Dec 20, 2008 | Coleman Powermate Powermate 5000W...
Engine wont fire up
Do you have fresh gas in the bike? Try changing the plugs with new ones and check for spark. You can do this by putting the new plugs on the plug wire and grounding it to the head on the engine crank the motor over you should see a bright blue spark. Check one plug at a time. No spark check the ignition wires and coils. As for the oily plugs it could be they are just fouled caused by either flooding the motor while trying to start, bad plugs, week coils, bad gas, poorly adjusted carb's. I would start with the plugs and work my way back to the carbs. Still fouling the plugs after all that start checking the engine, ie compression check ect.
Dec 14, 2008 | 2003 Suzuki VL 125 Intruder LC
Air Tools & Compressors Logo
Top Powermax Air Tools & Compressors Experts
Clint Wood
Clint Wood
Level 1 Expert
Bill Boyd
Are you a Powermax Air Tool and Compressor Expert? Answer questions, earn points and help others
