Set up tronic lcd wall clock lo8132 - Audio Players & Recorders
How can I set the time?
Once you select the time zone and whether you are observing DST, the clock sets automatically. That's the point of having an atomic clock.
Apr 19, 2016 | Sharp Atomic Wall Clock, Silver/Titanium...
Can not set time zone
Press the triangle shaped button to set the correct time
zone. It will toggle the clock mode through the four available time zones in the Continental U.S. Above the seconds digits, the LCD display will indicate "P" for Pacific, "M" for Mountain, "C" for Central and "E" for Eastern.
Mar 01, 2011 | La Crosse Technology WT8005UB Atomic...
I have a lacrosse technology wall clock how do i set the time
You don't set the time. You set the Time Zone and it sets itself.
What model is YOUR clock?
This site lists several models of La Crosse wall clocks with downloadable instructions.
http://www.klockit.com/depts/AtomicClocks/dept-52.html
The link below is generic but there are specifc downloads for clocks with other features.
http://www.klockit.com/PDFs/lacrossemanuals/AnalogWallClocks.pdf
Jun 18, 2010 | La Crosse Radio Controlled Atomic Clock
Quartz president wall clock, I need to set the chime
I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
*Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
*Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
John
Apr 21, 2010 | Watches
Seth thomas autoset wall clock not functioning. replaced both sets of batteries (AA and CR2032), still not working.
I wish I had a solution... I'm in the exact same situation. I put in new batteries, and all I get is a faint reading of gibberish from the LCD screen, and that's it. I've tried following the instructions, but I can't set the time in the LCD clock, since it's unreadable, and almost completely gone. Seththomas.com has a web page indicating that "they will be back with info", but no support or FAQ pages. Disappointing... I have three of these clocks, and they are all behaving the same way.
Apr 10, 2010 | Seth Thomas Radio-Controlled Howard Wall...
I can't get my atomic wall clock to set on daylite La cross wall
The easiest way to reset it would be to change it to Eastern time - that will give you the correct Central DST.
Bill B
Mar 18, 2010 | La Crosse Radio Controlled Atomic Clock
Seth Thomas wall clock wont set to time.
either the battery is weak or the gears inside are stuck and need to be worked with flathead or eyeglass repair screwsdriver.
Jul 06, 2009 | Seth Thomas Radio-Controlled Howard Wall...
Remote programming codes
Hey Kashaclysm, try this: www.urcsupport.com
Have your remote handy, have your TV model number handy.
Dec 14, 2008 | Olevia LT32HVM 32 in. LCD Television
447 people viewed this question
 Grubhead
Grubhead
