Question about Nintendo CTA Digital WI-BBP Wii Fit Balance Board Battery Pack
Wii Fit Balance Board Won't turn on
My new Wii Fit Balance board which was working ok for 2 days now when i try to turn it on the blue light only comes on for a second then goes off. i have tried replacing all the batteries, but no change.....
  • 2 more comments
  • l_bradford Jan 04, 2009
    I just tried re-syncing with the console and this fixed the problem. it does still seem a bit out though, as my weight changed a lot!!! I think i will try adding the stabilisers to see if that helps. Thanks
  • Anonymous Jan 14, 2009
    I changed the batteries and my light won't go on at all
  • Anonymous Feb 05, 2009
    Same problem got it to resync finally and now it thinks I'm standing on it when I'm not so I still can't use it. HELP!
  • nettsfamily Feb 13, 2009
    I have the same problem the blue light will not stay on and the Wii unit does not seem to recognize the fit board. I changed batteries and it made no difference. I tried the little red sync button and nothing happens. What else can I do?
I fixed it by re-syncing it with the console. all good now, although it seems a little out of balance, but at least working....
Posted on Jan 04, 2009
  • Ericka Lipscomb Oct 02, 2010
    I had this same problem (new batteries-no power) i re-synched and it fixed it!!
Weight don't seem to be accurate
Posted on Jul 11, 2009
3 Suggested Answers
  • 19 Answers
SOURCE: communications with the wii balance board interrupted
dont push your feet hard or the batteries might come off of the cap isnt put on or the batteries are fully used
Posted on Feb 13, 2010
  • 80 Answers
SOURCE: Canot use Wii fit balance board
Ensure batteries are fresh. Ensure that Wii Fit (or other Balance Board game) is started up completely before pressing the power button.
Posted on Jan 28, 2009
The wii fit game is telling me to push the power button on the balance board with my foot. It blinks blue and that's it. The batteries are fine. So what do I do?
You need to sync the balance board with the Wii. It's easy to do and takes 10 seconds.
1) Start Wii Fit.
2) When it asks you to push the power button as you're describing, open the SD card slot on the front of the Wii and observe the red button.
3) Now, flip over the balance board. Remove the battery cover on the bottom of it, and press the red button beside the batteries, and the blue light should start to blink.
4) While the blue light on the balance board is still blinking, quickly press the red button on the Wii. If they are both blinking at the same time, they should be syncing to each other.
5) Your Wii Fit Balance Board should now be synced with your Wii! If it has been synced successfully, you will no longer need to sync it, and should now automatically connect when the button is pressed with your foot.
Apr 09, 2011 | Nintendo Wii Fit for Wii
I have a wii fit board, when you power it up, it
Had the same problem. It's a sync problem.
First, best to double check you have fresh batteries.
Next, turn the board upside down and remove the cover from the battery compartment.
Open the small hatch cover on the front of your console unit.
Now start wii fit from the disk menu item.
Next, press the small red button inside the balance board battery compartment. The blue lights will blink for approx 3=5 sec.
While they are blinking, press the red button on the console (in the hatch compartment).
This should re-sync your board and the light stays lit.
Good luck.
Apr 07, 2010 | Nintendo CTA Digital WI-BBP Wii Fit...
Bought 2nd hand wii fit, have just loaded disc and replaced batteries in board but power light not staying on board, flashes for about 30 seconds and then switches off. Does it need to be synchronised with...
    Hope this helps
    Try these steps!
  1. Insert a Wii Balance Board compatible game disc in the Wii console.
  2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
  3. Open the small SD Card slot cover on the front of the Wii console.
  4. Remove the Battery Cover on the bottom of the Wii Balance Board.
  5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
  6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
  7. The blue light will stop blinking and stay on steady once the synchronization is complete.
please leave a good rating and testimonial if you appreciate my help. THNX
Mar 27, 2010 | Nintendo Wii Fit for Wii
Wii balance board wont switch on
i got the wii fit. we hook it up. and it's work. but the next day. it's dont work. i put new battery in it. the light turn on. then shut off by the self. so i dont know what to do? please help us.
Dec 29, 2009 | Nintendo CTA Digital WI-BBP Wii Fit...
I tried to play balance games on wii fit but when it said turn on the balance board it turned on for 2 seconds and turned right back off how do we fix this and we just put new batteries in it?
your board may well need to be synched to the wii again, try that. if the battery pack still rfuses to work, try some AA batteries first, then resynch it. If it still refuses to work suspect your battery pack has discharged and replace it.
Nov 27, 2009 | Nintendo CTA Digital WI-BBP Wii Fit...
We used our wii fit on another wii system. After
    Try these steps!
  7. The blue light will stop blinking and stay on steady once the syncronization is complete.
Fore more detailed information (including pictures) on how to sync the Wii Balance Board, click here.
If you are still unable to sync your Wii Balance Board, please call 1-800-255-3700 so that they may assist you further.
Hope it helped.
Nov 22, 2009 | Nintendo Wii Fit for Wii
I cant synchronise my board with the wii box
Make sure you are trying to sync it when the Wii Fit game asks you to. It will say "place you wii fit board on the floor and turn it on" or something like that. and then when it asks you, turn it on, and it should sync.
otherwise, try it on another wii if you can... if it works on another wii then its your wii.. if it doesnt work on another wii then it is you Wii Fit Board.
Sep 15, 2009 | Nintendo CTA Digital WI-BBP Wii Fit...
Wii fit balance board 3 quadrants are green and 1 is red
This means that one of the 4 sensors is broken. You will need to contact Nintendo via their website to get it repaired.
Good luck, and sorry about that!
Feb 11, 2009 | Nintendo CTA Digital WI-BBP Wii Fit...
Jan 04, 2009 | Nintendo Wii Fit for Wii
Power
    Try these steps!
Sep 09, 2008 | Nintendo Wii Fit for Wii
Nintendo CTA Digital WI-BBP  Wii Fit Balance Board Battery Pack Logo
1,684 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Troy Gorman
Troy Gorman
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
