Question about Health & Beauty
Replaced batteries and lights on lower scren scroll left to right and back, chair won't move. when I try all lights go out
  • ruddski May 11, 2010
    Need to know what type of electroncs and brand of chair. each brand has different patterns of scrolling that tell you specific things to look for. My guess would be that the batteries are not tight or you have a loose inline connection, because as soon as you try to pull any amperage through system it shuts down.
  • 32 Answers
Sounds like problem with controller and or joystick, need to have someone check with programer.
Posted on Jul 13, 2009
MY BATTERY INDICATOR LIGHT CONTINUSLY SCROLLS FROM LEFT TO RIGHT CHAIR WILL NOT MOVE
You are in locked mode. try turning the joystick on and pushing the horn twice. or if that did not work try turning the joystick on and pushing gimbal forward until it beeps and then back until it beeps. should be unlocked, scrolling up and down will stop and you can drive.
Jan 27, 2016 | Pride Jazzy Select Elite
Tip
Helpful Information when posting problems ith power chairs, scooters or lift...
If you are having problems with a power chair, mobility scooter or lift chair Give as much information as you can. Did Medicare pay for the mobility product? How old is the product? How old are the batteries? When you are getting flashing lights on the battery level indicator or light on scooter console. Count the number of flashes ie: 4 flashes pause 4 flashes pause etc. If the lights are scrolling are they moving right to left or left to right? As much info as you can give will help in telling what problem you are having and easier to help if possible.
In problems with lift chairs does to chair go up but not down? Will the chair move up or down at all? Do you have a red light visible on your transformer that is plugged into the wall socket?
Thanks
Lennie
on Sep 13, 2010 | Health & Beauty
THE BATTERY LIGHT CONTINUSLY SCROLLS FROM LEFT TO RIGHT AND CHAIR WILL NOT MOVE
Turn on Joystick and push horn twice, you are in locked mode. If this didn't work then turn Joystick on push gimbal forward until you hear a beep, then move the gimbal back until it beeps you are now unlocked. Gimbal= what you push to go left right forward or back on a joystick.
What the lights moving right to left on jazzy select 6 power chair
If you are moving as soon as you turn on the chair, the lights will move from right to left. Try waiting a few seconds and see if the lights stop moving. If they do stop, then you can move forward. Hope this helps.
Jun 20, 2014 | Pride Jazzy Select 6 Indoor Power...
Jazzy 1107 power chair won't move
3 flashes indicate that there is a short circuit to the left motor and battery connection. Check wiring and connections
Jun 14, 2013 | Pride Jazzy 1113 ATS Indoor Power...
Battery level indicator continually flashes when turned on, chair does not move.
Not much info to go on, but you may be in Lock Mode. On a VSI the Profile LEDs scroll left to right.To Unlock a VSI: Push joystick forward until beep, then pull joystick back until beep. Unit is now unlocked.
Mar 09, 2013 | Health & Beauty
Where it shows the charge of the battery it keeps running across the screen and you can't use the wheelchair. It won't move. It does this every time after taking it off the charge.
Spot does the lights scroll from left to right or right to left? If they move from right to left then shuts down completely then the chair is in lockout or sleep mode. To unlock - turn the chair on and immediately press the horn button twice ( beep beep) This should get it out of sleep mode. Now if the lights are scrolling left to right then the chair still thinks it is being charged and the inhibit function is bad. You can call your local provider to have a tech check it or you can call Repair Xpress at 1-877-581-3733 to check it they have atech in your area to check it. Hope this helps
Aug 29, 2010 | Invacare Supply Group Invacare Pronto M51...
Lights flashing
If your chair is in freewheel (levers on back of motors not in drive) then the light will flash. But are the lights scrolling left to right or right to left? You can check for freewheeling by trying to push the chair from behind if it moves easily then it is in freewheel and you will have to move the levers to the drive position. You need to give more info of the flashing lights are all the lights flashing are only some flashing? etc
Aug 16, 2010 | Invacare Supply Group Invacare Pronto M91...
The charge lights blink and the chair won,t go.
Just had this problem with my Guardian Aspire. They had to replace the electronic box with the joy stick. BIG BUCKS!
Mar 12, 2009 | Jet Health & Beauty
Health & Beauty Logo
326 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
