Bosch dryer F11 error code
Machine works fine then stops with error code f11
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
F11 indicates a fault with the main control board.
Prepare yourself for a shock when you click on the parts link.
Click here for the part
Posted on Nov 01, 2012
SearsTechToo
  • 261 Answers
SOURCE: Kenmore Elite H3 error code F11
F11 is a serial communication error. It is recomended to check connections from the motor control unit to the ccu. We are looking for the blue wires that carry info from component to component. The ccu is on top under the cover positioned in back for older machines and front right for new machines. The mcu, motor control unit is behind the kick panel below the door and is front left usually.Again we want to unplug check for dark or crusty connections if not to carefully reseat the connection and not only the blue serial wires but power as well. Remember to first unplug the machine and while you work the machine can reset, 30 minutes is typical.
Posted on Sep 13, 2008
  • 63 Answers
SOURCE: Whirlpool Duet Error Code F11
its your ccu board under top in back easy to change about 300.00 that is f 11 code "plz"
Posted on Nov 15, 2008
jsrock516
  • 5911 Answers
SOURCE: What does the F11 error code on my Kenmore Elite He 3t mean?
"F11" is a serial communications error. The following link explains the possible causes and how to troubleshoot:
http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
First, attempt to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). In many cases, this is all that is required in order to correct momentary glitches with the unit. If the error code reappears, follow the advice provided in the link. In the majority of the cases, I've experienced, it was the CCU that caused the problem.
If you have questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Jan 22, 2009
  • 107 Answers
SOURCE: error code f11
F-11 is communication error between the Motor control unit and the Main CCU. Either of these or both could be bad. Sometimes unplugging all the connections from the CCU (under top panel) and plugging them back in will fix the problem. If fixed, there's a bad connection at the CCU.
Posted on Mar 13, 2009
  • 3741 Answers
SOURCE: Washer stops with F11 code; door won't open
F-11 ERROR CODE MEANS :
Serial Communication Error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
TO RESOLVE THE PROBLEM:
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
Posted on May 05, 2009
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Bosch gas range error code F11
    Disconnect the ribbon from the control panel and clean it using pencil eraser. then carefully reconnect it.
    If the F11 is still there most likely it's the control panel.
    God bless you
    Feb 01, 2013 | Bosch Evolution 500 HGS5053UC 30"...
    Flashing F 11, drum spins by hand.unplugged for 30 sec and plugged back in started to fill then stopped .flashed F11 again
    The F11 error can be difficult to resolve even for us technician's.
    The F11 error occurs when the central control and motor control don't talk to each other.
    If one of the controls was actually bad then I'd expect to see the error code every cycle. If it does, start by checking all the wiring connections from the panel to the CCU. Post back your results.
    Dec 02, 2012 | Whirlpool Duet GHW9150P Front Load Washer
    Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
    Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
    Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
    Bosch dryer error code F11
    Sorry to be the bearer of bad news.
    Oct 31, 2012 | Dryers
    Disply screen flashes F-05
    I have a hotpoint waschmachine wt640 since lastweek I have an error on the control panel F5 andnow it changes to F11 .The machine is just working for a few minutesand stop showing the error message F11 . please help
    Feb 28, 2011 | Hotpoint Aquarius WD640 Front Load...
    Stops on spin cycle and gives a f11 error code
    F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancel, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech.
    Mar 29, 2010 | Kenmore Elite 45986 Front Load Washer
    Error code F11
    Not sure what machine you have?
    F11 Error Code for Whirlpool Duet & Duet HT :
    F11 is Serial Communication Error, communication between the central control and the motor control unit cannot be sent correctly.
    Check all connectors at the motor control and the Main control, check the motor, check drive system for any worn or failed components.
    This is the only F11 Error code I could find for a washer.
    Jan 13, 2010 | Dryers
    Sep 08, 2008 | Kenmore Elite 45986 Front Load Washer
    How do i find what an error code means?
    if that is a whirpool or kenmore remove bottom panel look for tech sheet in plactic bag codes are in it
    Sep 02, 2008 | Washing Machines
    Washing Machines Logo
    2,431 people viewed this question
    Top Washing Machines Experts
