My pioneer PL221Z turntable arm slides across record why?
ARM WON'T STAY ON RECORD
arthurroger
  • 170 Answers
SOURCE: turntable arm slides across record, Am. D.J.-1500
See what type of cartridge is installed in the arm. Manufacturers use common cartridges in turntables, such as Stanton, Shure etc. Detach the head shell from the arm (it usually slips right off via a locking ring and four-pin mini plug) Look for the manufacturer and model number on the cartridge. No need to remove it from the head shell. On most modern cartridges, the stylus (as they are called, rather than the needle) simply slips off and on. No need to remove the entire cartridge (via screws) and re-align it. In fact, many DJs bring a set spare cartridges and styli on a gig, already mounted in head shells, and simply interchange them as needed. When you have the make and model of the cartridge, go to Radio Shack or use their website to order a new one...or  two. Or go to Google and enter "phono stylus" as your search term. You will find reasonably priced styli for nearly every cartridge imaginable. I operate 50 year-old turntables and am able to find replacement cartridges and styli on line. Ebay also has a number of listings, by make and model of the cartridge. When the new stylus arrives, observe how easily the old one comes out of the cartridge- usually pull and slide - and slide the new one in. Re-insert the head shell on the arm, tighten the locking ring, and you're good to spin!
Posted on Jan 08, 2009
djproaudio
  • 515 Answers
SOURCE: techniques SL-D1 Turntable anti skid...
Actually, this sounds like the needle is damaged. Make sure there is a tip on there. Just because it's new, does not mean it is not damaged. Sometimes end-users improperly handle the stylus/needle when installing.
If you are 100% certain that the stylus is ok, then the anti-skate needs to be set correctly. Generally, leaving it on 0 (zero) is ok to start. Then try and balance your tonearm according to THESE INSTRUCTIONS. These instructions apply to most turntables. The fundamentals are the same for all turntables in that you need to balance (float) your tonearm for optimal use.
Hope this helps some.
- Davis.
Digital Analog Therapy
Electronic Repairs
www.repairny.com
Posted on Nov 04, 2008
  • 3 Answers
SOURCE: Arm does not track properly but skips across records
Just guessing, but it sounds like you haven't counterbalanced your tone arm.  When a tone arm skips, it's usually because there's too much counter weight on the rear of the tone arm.  You want between 3-5 grams, but first you have to calibrate your tone arm (balance it so you know where zero is).  If you don't know how to do this, refer to the Ion directions called "Tonearm Setup" in the instructions.
Posted on Jan 04, 2009
  • 42 Answers
SOURCE: BSR turntable arm slides across record
There can be a number of reasons for this.
Have you checked that the stylus tip has not broken off? this is a common cause and will require a new stylus.
Posted on Jan 24, 2009
Grubhead
  • 5259 Answers
SOURCE: Digitech turntable - skipping stylus and arm
You might need to apply more pressure to the stylus. There should be a weight on the end of the arm, it should have a control to move it up and down. The only other thing is the stylus damaged from transit?
Posted on Feb 02, 2010
The tone arm drops onto the record, but then continues moving across the record without playing the record. Anyone know what's going on?
Does the needle actually contact the record? If not, you may be missing a "pad" under the record, or you may be simply missing the needle that needs to be there to follow the grooves.
Nov 02, 2014 | Audio Players & Recorders
Needle slides across record
It could be 3 different things. The first is check the needle make sure its not dirty. the second is make sure the weight is set correctly. And the third is did you take the tone arm off the protective part that holds the tone arm in place when moving or travelling .
May 19, 2012 | Numark ttUSB Turntable
The arm with the needle slides across the LP record - doesn't pick up sound
This is often a problem when you are using a 78 needle on a 45 or 33 record. Some needles can be flipped, so check to see if yours is able to flip between the 78 and 33 setting. If not, you may simply need a new one.
Jan 03, 2012 | Philco PC-841.651 Turntable
I have a JVC AL-A158 turntable, just got it from a thrift store for $13. Cosmetically, it's brand new. No scratches, no scuffs, no nothing it's even still got the plastic on the 45 record adjustment, and I...
2 things, make sure the back arm weight is adjusted correctly,, allowing enough pressure to be placed on the record, if that doesn't help, you have a chip in the needle thats not visible to the naked eye,
Apr 30, 2011 | Audio Players & Recorders
Hello when , I put the needle on the record it doesn't play and slides across
Two causes the stylus is worn, or there is not enough pressure being applied to the stylus. Most cartridges track at 2-3 grams. The weight at the end of the arm should be set around this figure and slowly moved higher till it tracks without sliding and without creating too much rumble in the sound. If you have to take the weight up high, then that's a good sign the stylus has gone. Or that the arm itself has a fault on it somewhere (when tried with a new stylus installed).
Apr 25, 2011 | Gemini XL-100 Turntable
The arm won't stay down, as soon as it sets down on the record it automatically stop and moves back to the resting spot.
If you have the automatic arm on you`res and you have to move the slidder control to make it work,don`t slide the control all the way.Just til you hear a click and then move the arm you`r self.Also make sure it is set to the size record you are trying to play.
Apr 22, 2010 | Pioneer PL-990 Turntable
Hi, The needle keeps sliding across the record. A coin on it does not help, the sound is ok when it stays. Any idea?
You have either not enough force on the stylus, turn the weight on the end of the arm, or more likely the stylus is worn.
Jan 20, 2010 | Audio Players & Recorders
The stylus just slides across the vinyl records - I have adjusted the weight on the arm but still does this
Make sure the turntable is level.
Make sure the stylus is mounted correctly on the arm. With no record on the turntable, and placing a soft cloth under it, lift the arm and see if it slowly settles down or falls quickly. Depending on the make, arms can become sticky and lose their ability to "float." Re-adjust the weight dial if possible.
Jan 11, 2010 | Audio Players & Recorders
Jan 17, 2009 | Crosley CR248 Turntable
Needle slides across the record on Crosley 5 in 1 player
you have unscrewed the suspension screw?
also check the needle for dirt and dust... try blue tacking a 5p coin to the top on the needle to give it a little more weight, if the needle stays in place then the arm balance if off, and unless there is a mechanism to adjust that on this turntable then i guess its a return!
Dec 26, 2008 | Crosley CR248 Turntable
74 people viewed this question
 Grubhead
Grubhead
