Question about HP PSC 1610 All-In-One InkJet Printer
How to scan slides with HP 1610
I do have problems scanning transparencies and slides with my printer. I am using Vision Scan VP-6050SQ as white light (6500ºKelvin) but thr amount of light seems excesive becuse colours are not distinguised but a light browm for every thing. Do yo know how to adjust the scanner to get proper resaults?
  • Anonymous Mar 25, 2009
    can my psc 1610 all in one scan slides?
    Guru:
  • 859 Answers
Will you help me help you with a little more information please?
Thanks. When you attempt a scan with your backlight setup are you able to instruct the scanner through its settings and options that you are using a transparency backlight at 6300K? If these options are there, what light temperature options do you have besides 6300 or is that the only one. And are your slides in standard tray or in a plastic jacket? A standard tray is a clamshell device where you lay your slides in frames and when done close and snap the clamshell closed.
Thanks,
Worldvet
Posted on Jan 04, 2009
Scan slide negatives film
I have had that problem with the MX310.
depending on what IOS you are running
you can get software free that will scan
Transparencies "opposite"
Oct 12, 2013 | Canon Pixma MX410 All-In-One Printer
How do I scan transparancies? With the holder in place on the flat bed the whole frame scans and not the slide.
You need to put a piece of white paper, the same size as your slide on the back of your slide. Your scanner doesn't recognize the edges of the transparancy (it is looking through it), so if you place a white paper on top of your transparancy it wil recognize the edges.
Nov 15, 2011 | Epson Stylus RX500 All-In-One InkJet...
Can HP psc 1410 PRINTER SCAN NEGATIVE AND SLIDES
Chances are that somewhere in your family photo collections you have a bunch of slides and negatives that you wish you could do more with. You may want to include them in your family history, to publish them on the Web, or simply to make digital copies so you can share them with the family.
If you've ever tried to scan a negative or slide on a regular flatbed scanner, you'll know that it doesn't work, and you end up with a pure black scan. In this article we'll show you how you get your negatives and slides into digital format, and what issues you may face along the way.
pixblue.gif Benefits Of Scanning Film
There are some key benefits to scanning film (we'll use the term to include slides and negatives) in comparison to scanning a photo. When you scan film, you can use the full area of the slide or negative, whereas a photo will generally only display a cropped portion of the original. You are also scanning the original source image rather than the color corrected and tweaked version of it that the photo processor has provided you with. The process of turning a negative image into a positive one involves inverting the colors in the image and removing the orange cast from the negative. This would be a complicated process if you were doing it by hand; however, your scanner will provide you with software to do this automatically, or you can purchase standalone software to do it.
Most cheaper flatbed scanners are designed to scan photos and other images that reflect light when it is shone onto them. The problem is that film is transparent and light passes through it rather than being reflected off it. Many flatbed scanners have an optional transparency adapter, which replaces the scanner lid with a larger box shaped ob....
Jun 09, 2010 | HP PSC 1410 All-In-One InkJet Printer
Can u use the scanner on a hp pcs 1610 all in one inkjet printer without the color ink cartridge?
Hi, the answer is no you cannot, the printer will only work if both cartridges (black and color) are installed, if you install just one the check print cartridge light will flash.
Hope this helps
Muzzi_123
Nov 14, 2009 | HP PSC 1610 All-In-One InkJet Printer
Unable to install SCAN functions for HP PSC 1610
If you are having issues using your PSC 1610 on the Vista operating system there is actually an easy workaround using "paint" (I'm using "SnagIT").
Check it out:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00809848&lc=en&dlc=en&cc=us&product=390315&lang=en
For whatever reason you can't use the actual button on the printer/scanner but when you open paint you can scan the doc from your computer.
Hope this helps!
Mar 27, 2009 | HP PSC 1610 All-In-One InkJet Printer
Help on HP PSC 1610
The all in one solution software you used in XP doen't work with Vista.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie HP 1610) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Jan 05, 2009 | HP PSC 1610 All-In-One InkJet Printer
Scanning slides into computer
From Lexmark's website:
To scan negatives, slides, and transparencies, you need to place the original between the light source and the sensor array so that the light passes through them before hitting the sensor. However, Lexmark scanners place the light source and the sensor array on the same side in order to catch the light as it reflects off the original. Accordingly, in order to scan originals of this type, you need a transparency adapter (also called a TPA or TPU), which is a back light that replaces the scanner cover.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Sep 06, 2008 | Lexmark X7350 All-In-One Printer
Leopard and psc 1610 scanning
First, Install the HP Software from here: http://preview.tinyurl.com/4wfxnq
Then, Search for 'scan' in spotlight or quicksilver.
Open up 'HP Scan Pro'
Choose your settings, and scan away.
Do NOT use the 'scan' button on the printer, it does not work. Ignore it and use the software.
Nov 09, 2007 | HP PSC 1610 All-In-One InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
352 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
