Question about Broan-NuTone Dryers
Wiring problem "I am a do-it-yourselfer without a lot of electrical experience. I have installed a new fan combo above my bathroom, but I'm not sure how to complete the wiring. Here's a link to the instructions and the wiring diagrams for the fan that I purchased. http://www.broan.com/common/productDigitalAssethandler.ashx?id=379d6b45-26d0-49db-892f-46d1974b8ca3 The bathroom has a light above the vanity controlled by one switch and one outlet next to the bathroom sink. I removed the light fixture above the shower area that was controlled by a second switch. Then I removed the box for the light and have the wires loose in the attic. There are three wires, each of them have a black, white, and ground in them. One comes from the circuit breaker box, one comes from the light switch. There's one more and I'm not sure where it goes. I do not know exactly how to wire in the fan. I bought a 3 way switch, but I do not have the black/white/red/ground wire going from the attic down to the switch. I don't want to wire everything together and ruin the fan. I would appreciate any advice you can give. Thank you!"
  • Broan-NuTone Master
  • 5,245 Answers
11-1-12
Thanks for link to manual.
Solution might take more response for full clarity, and you seem a good electrician.
I have numbered two questions that may be unimportant.
Add a comment, response after 5 pm CST
Here is illustration showing Black Hot and White Neutral in attic junction box, as you described. With black-red-blue wires connected as shown in Broan manual. And each device connected to White neutral wire in junction box.
http://waterheatertimer.org/images/Triple-fan-light-night-light.jpg
You have access to attic, and can drop another cable down wall into switch box. This will give necessary total 4 wires between switch and Broan
http://waterheatertimer.org/OWB1.html
Key start point: Junction box in attic has the Black Hot wire and White neutral coming from circuit breaker box.
This cable powers the junction box.
There are 3 cables in junction box, each cable with black and white.
Cable from breaker box with Hot and Neutral. Cable going to light switch.
Another cable jumps power to next box in the circuit, and will be reconnected when finished, black-to-black white-to-white
Old light switch in wall was single pole.
1) How many cables are inside switch box? Just one cable from attic with black and white wire?
2) 3-way switch is the wrong switch, unless you mean 3-pole triple switch with 3 screw terminals on one side of device?
Here is another link that shows wiring choices if you decide to use 3 separate switches (or timers or occupancy sensor to turn on night light) instead of triple switch: Install triple box.
http://waterheatertimer.org/How-to-wire-switches.html#4-f
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Nov 01, 2012
  • Gene Haynes May 30, 2014
    Did you add the link to electrician service... or did fixya add that promotion, implying that you are recommending the service? Fixya has become a bowl of product promotion guised as questions and answers among people
aborcass
  • 2651 Answers
SOURCE: Need Wiring instructions
no problem just wire the black to black and white to white. connect the ground and cap off the blue wire, its used only for ooptional light assy
Posted on Apr 03, 2008
muttandjeff
  • 359 Answers
SOURCE: wiring connection ceiling fan
copper to green , white to white , seperate the black and the black with th white tracer you wired together connect the black to the black and the black with white tracer to the red in ceiling , without looking this is my best advise ,good lk
Posted on Nov 27, 2008
  • 1114 Answers
SOURCE: Combo lite/vent fan/nite light affected by heat?
There's probably a thermal switch in the fixture which turns the fan on when the lights are on for a period of time and heat accumulates in the fixture. It sound like the heat from the attic is setting off the thermal switch. When the attic heat drops, the fixture works correctly.
This is a catch 22 situation, because if the upper housing in the attic is insulated from the attic heat, the insulation will prevent heat dissipation from the heat generated by the fixture's light bulbs. So, for safety reasons, the upper housing should not be insulated.
I'll need to work on this to come up with a fix.
Posted on Jul 20, 2009
dnewcombe1
  • 1564 Answers
SOURCE: Im needing to stall a new switch and timer on a 2
Your fan is a 220 volt, your power supplyu is a 110 volt. Not going to work.
Posted on Sep 07, 2009
jcameo7270
  • 675 Answers
SOURCE: I am attempting to install my Hunter 21095
Black is for the fan motor which you connect to black(hot), black/white is for the light which you connect to the switched lead in the ceiling, the white lead from the fan goes to the neutral lead in ceiling, and tjhe green wire is earth ground and goes to the box screw in the ceiling
Posted on Jan 20, 2011
We have the Kokols Wallmount Bathroom Pedestal Glass Sink Vanity Combo but the p-trap keeps leaking. How do we fix it?
Remove it, (Don't forget water will come out when you uncscrew it!!!) clean it thoroughly, especially the ends, clean and check seating of any rubber washers to make sure they are fitted correctly and not being distorted when the rings are tightened, reseat it with no force (it should sit naturally without having to force it in) and tighten rings. There are lots of videos on youtube showing how. If you cant stop it leaking buy a new trap. It's worth while looking very carefully for exactly where the leak is before you remove the trap, it might be coming from higher up. Repair Leaky Sink Drain Pipe
Jun 21, 2014 | Kokols Clear Vessel Sink Pedestal Bathroom...
What would it cost to have a vent/fan installed in bathroom?
Learn the cost to install an fan by doing it yourself compared with the cost an electrician will charge. Installing a through-the-wall fan is an involved project that requires carpentry and electrical skills, so it's best left to the pros unless you have those skills.if you don't have , you should pay charge for service and the cost of fan .there is cheap and expensive fan .depends on yourself.
bathroom light
Apr 12, 2012 | Home
Bathroom fan is on the same circuit with the light. Is there a switch that I can install on the fan so that I can control it from the light switch without running an additional wire?
It depends in part on the fan. Many but not all give you the option to run seperate feeds for the fan and the light, which is necessary to do what you want. If you are experienced with electrical work, you will be able to tell because the feeds for the fan and light will be pigtailed together in the small junction box built into the fan housing. You will need to run a new cable to the location where you plan to mount the 2 switches also... hope this helps
Jun 01, 2011 | Cooper Wiring Devices ACE DUAL CONTROL...
Show wiring diagram for 274w combo
1) A wiring diagram can be mistaken because wire colors vary.
That's why electricians don't guess, they test.
2) Look at device to be replaced and note what color screw each wire goes to before disconnecting wires.
If old device is single pole switch, then there are 2 brass screws, and one of these screws is connected to Hot wire, and the other screw is connected to Load wire (light, fan, motor, pump)
3) Separate wires inside box for testing.
Do not untwist any wires.
Tape tester leads to wood sticks to keep hands away from power.
Turn power ON.
Test each wire to bare ground wire.
Tester lights up on Hot. Hot wire connects to dark-colored screw on combo device.
4) Hot is identified.
Test Hot to all other wires, except bare ground wire.
Tester lights up on Neutral wire. In a single-pole switch box Neutral wires are usually twisted together and covered with wire nut. Neutral wire connects to silver screw on new device.
5) Load wire that goes to light,fan, motor, pump connects to brass screw on new combo device.
6) If you do not have a Neutral wire in your switch box, then outlet will not work.
You can connect bare ground wire to silver screw and have outlet work, but this is not code, and definitely not recommended for a child's room or any room near water pipes or faucets or metal pipes of any kind. You need to add a Neutral wire and/or install GFCI protected device for any bathroom area.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 05, 2011 | Cooper Industries Cooper Wiring 274W...
Have a nutone fan for bathroom taken motor apart to try to figure why it will not turn anymore after i put some oil on the shaft previously. Thought maybe the oil shorted out the something but could only...
Save yourself the grief and buy a new fan. Either replace the whole unit or take the fan from the new unit and install it in the old fan chassis. It will be a lot less painful than trying to troubleshoot the old unit.
May 06, 2010 | Broan-NuTone N-8663RP Combination Light...
I removed an old fan/light combo from my bathroom and put a new one in. The wiring comes off two switches wired together (3 wires total) and I need to know how to wire to the new fan/light combo. There is...
Hook the black wire from one switch to the fan and the black wire from the other to the light. Then hook all of the white wires together.
This will get you working like you want it too.
Heatman101
Feb 23, 2010 | Kitchen Appliances - Others
Arc fault breaker trips sporadically
Are there any heaters anywhere in the circuit for this breaker? (ie: bathroom fan w/light and heater) If yes, I would suspect and inspect them first. Also,any type breaker will trip more easily if the electrical connection screws on the breaker are not tight enough...check to make sure that's not the case.
Jul 31, 2009 | Eaton 20A ARC FAULT BREAKER
Installation of a Panasonic Fan FV-05VFL2...
If you are not very handy I don't think I'd tackle this project. There's going to be drywall cutting, backing to install, attic crawling, wiring, ducting to attach, proper insulating. As an electrician I've done this sort of thing in between 1 and 2 hours, depending on how smooth things go. If you find somebody you trust that's done it before who is willing do to it on the side for cash you're looking at $25-$60 for labor. Is it worth it to you?
Feb 25, 2008 | Panasonic Fan FV-05VFL2 WhisperFit-Lite...
Dryers Logo
396 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
maddyveggie
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
