I have a Teco Inverter JNEV-203-H1 The Input is 230 volts , single phase AC, 60 HZ The output is 3 phase, 230 volts, 60 HZ In the Instruction Manual apear how to program aqnd a list of parameters I am trying to get in Internet the Instruction Manual and I can't find it
I found information about this issue in Internet
If you need additional informationin how to get it let me know.
Best Regards
Eliseo Ruiz
Industrial Solutions LLC
Gate Operators System
Power and Electrical Control Consultant
Posted on Jan 04, 2009
  • fsommer1 Sep 08, 2010
    It would have been helpful if you told the guy WHERE you found it on the internet.
The settings for welding aluminium using a Tig200P AC/DC inverter
If you are using a remote then you would set the machine in standard for controlling output and also to AC output, HF tig, contactor and control in remote position. I don't know if this helps or not but I pulled it from an owners manual.
1/16" (.062) - pre-flow .1 sec., hot start 20, amperage 70, Hz 100, balance 20%, post-flow 6.0 sec.
For pulse settings - set pulse width 60%, peak current 100, background current 30, Hz 1.0
1/8" (.125) - pre-flow .1 sec., hot start 20, amperage 150, Hz 80, balance 20%, post-flow 6.0 sec.
For pulse settings - set pulse width 60%, peak current 150, background current 50, Hz 1.0
3/16"-1/4" - pre-flow .1 sec., hot start 20, amperage 185, Hz 60, balance 20%, post-flow 8.0 sec.
For pulse settings - set pulse width 60%, peak current 185, Background current 125, Hz 1.0
Mar 14, 2014 | ARC Thermadyne Inverter Stick/TIG Welder...
Digital inverter generator has no 240 volt output
Most power inverters are strictly single-phase. Meaning true 120V or 240V, and no splitting or duplication. It sounds as if your inverter is a single phase 120V, and likely is not stackable on the AC side.
I recommend looking for a Low Frequency Split Phase power Inverter if you want both 240 and 110 volts.
Aug 09, 2013 | Vacuums
Need wireing diagram for AO Smith 1HP motor S#C56A97B08 Ser32409J2
less hassle replace whole pump if motor over heated possible bad seals and distortion to pump housing will leak
Dec 04, 2017 | Pool & Spa
What should i set the micro switch on the back at?
2 ohm stereo (per channel): 975W
4 ohm stereo (per channel): 660W
8 ohm stereo (per channel): 400W
4 ohm bridge-mono: 1950W
8 ohm bridge-mono: 1320W
Load Impedance: Safe with all types of loads. Rated for 4 and 8 ohms in Stereo mode, 4 ohms in Bridge-Mono mode
Voltage Gain to 1-kHz, 8-ohm rated output,
CE 1000:
30.5-dB gain at 1.4-volt sensitivity;
26-dB gain at 2.34-volt sensitivity.
CE 2000:
32.1-dB gain at 1.4-volt sensitivity;
26-dB gain at 2.83-volt sensitivity.
Required AC Mains: 50/60 Hz (North American units are 60 Hz only); 100, 120 and 230-240 VAC (+/-10%) units are available.
AC Line Current,
100 Volts: 11.4 A;
120 Volts: 9.5 A;
230-240 Volts: 5.0 A;
At Idle: All amps draw no more than 90 watts.
AC Line Connector: NEMA 5-15P (15 A).
Sep 07, 2012 | Crown CE2000 2-Channel Amplifier
I have a miller cp 300. It is wired for 3 phase power. I need to hook it up to 230 volt power. How do I do this correctly.
You cannot do this... 3 phase and single phase cannot be inter used... see 3 phase is 440 V AC, single phase is 230 Vots AC. This is unless the unit has Dual capability, in this case the wiring could only be wired to a Single Phase. of the unit. You will need a slow blow breaker of the correct rating and also the cable must be similarly CURRENT rated. If it IS only 3 phase, you can purchase after market single phase to 3 phase converters, that will allow you to plug the 3 phase into a single phase circuit and work, they quite costly though.
Mar 22, 2010 | Welding Tools
Can I cange 3x230v up to 400v
Are you stating you have an A200 mixer that is 3 phase 230 volt?
I was under the impression all A200's were single phase. The D300 floor model came 3 phase. In any regard, to change the input voltage to any maching, you would have to replace the rotor, stator, and control group, including wiring. It has to be kept to orgiinal specifications, and tech support would have to authorise the change. As you can imagine, it's not really an option. If you change from 50 to 60 Hz, you would have to change your worm gears also.
Oct 03, 2009 | Hobart A200 Stand Mixer
We have a Carrier mini split AC that we are wiring on a portable office that will be going to a foreign country, the Carrier #38QG24-H. This unit's voltage specifications is 200-240volts, single phase, 50...
please 200- 240 volts is a standard for all and for the breaker is depending of the country if 120 v single phase you will install as usa if 220 v single also you can connect you breaker but the problem is some countries are not 50 hz comfirm the unit is 50/60 hz.
Sep 24, 2009 | Heating & Cooling
I wish to rewire a single phase electric motor with compositor's that is currently setup for 230 VAC to 115 VAC. The motor is a Ingersoll-Rand Air Compressor motor with the following nomenclacher. Single...
The motor itself should have a sticker which describes the wiring for 115. It is a small change involving a single wire moving from one pole to another inside the motor starter cap (the bump on the motor itself).
Aug 26, 2009 | Air Tools & Compressors
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
Here are the specs on your compressor:
Electric Single Stage Air Compressor, Motor Running Power 5.0 HP, Free Air Flow @ Maximum Pressure 16.1 CFM, Free Air Flow @ 90 psi 18.0 CFM, Maximum Pressure 135 PSI, Phase Single, Voltage Rating 230 Volts, Current Rating 21.5 Amps, Tank Capacity 60 Gallons, Tank Type Vertical, Height 71 Inches, Length 20 Inches, Width 30 Inches, NPT Outlet (F) 1/2 Inch, 60 Hz
Good luck with your new comressor.
Mar 21, 2009 | Air Tools & Compressors
Computers & Internet Logo
236 people viewed this question
David Payne
David Payne
