Question about CDA Washing Machines
Washing machine empties-i remove clothing and then it refills with water?
Help me!!
    Top Expert:
  • CDA Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 01, 2012
  • 100 Answers
SOURCE: Creda Washing Machine Detergent Dispenser not emptying
does the detergent get wet?
may be the blue trap door that is behind the detergent in the drawer is set for liquid detergent ie 'closed' and needs to be set to open to allow the powder past. or the holes above the detergent section where the waster comes out are blocked so water goes in another route.
you could always put the powder straight in with the wash to get yourself out of trouble.
Posted on Feb 03, 2009
SOURCE: hoover 600mb 6.0 kg top load washing machine (not as below)
Machine unbalanced or belt is worn maybe
Posted on Apr 04, 2008
astruttman
  • 45 Answers
SOURCE: water in washing machine from emptying sink.
A washing machine filling with water overnight or when not in use has two possible causes. Either the water is running into the washing machine from the sink ( If the drain hose is connected directly to the u-bend under the sink ) or one of the water valves isn't shutting off properly and water is dripping slowly but surely into the washing machine. The latter problem can take several hours before the water level rises high enough inside the washing machine to be visible.
It's easy to track down the cause of water entering the washing machine when not in use. If turning off the hot and cold water taps stops it, then it's one of the water valves not shutting off properly, and needs replacing. It's just a process of elimination to find out which one it is. If not, the water is likely to be coming from the sink (use above link). Sometimes by removing the soap dispenser drawer and carefully observing inside the soap dispenser you can clearly see water dripping in at regular intervals.
Blocked water valve filters: I've come across cases where a filter in the water valve has become caked in a brown sludgy mud-like substance due to disturbances in the plumbing. This could be because of work carried out on internal plumbing or even after workmen have turned the water off in the street to work on the water mains. After the water is turned back on, muddy or gritty water can enter the household pipework and when you use the washing machine it can draw this contaminated water into it.
In this scenario very fine grit or muck can get past the filter and stop it shutting off properly, or the filter is so blocked that water pressure to the valve is reduced enough to prevent the valve shutting off properly. Remove the water valve filter with some pliers and thoroughly clean it out. If the fault persists, replace the valve.
Important things to watch out for are -
  1. Washing machine water valves need a certain amount of water pressure to actually ensure the water is shut off properly. Therefore, if your water pressure is very low, it can seep in past the closed valve. This problem is less likely to suddenly appear unless your water pressure has suddenly dropped. It's more likely to be a problem with a new installation. ( Related: Low water pressure and washing machines )
  2. A faulty tap can mean that although you turn it off, the water supply isn't actually cut, so be careful of assuming if the fault still occurs, that you have definitely discounted the water valves. If unsure, you would have to disconnect the hot and cold fill hoses to ensure the water supply is properly cut when the taps are turned off. This problem is a lot more common with water taps that turn off with a red or blue plastic lever.
  3. If the washing machine has just been filling, you may get some dripping of water into the soap dispenser for a few minutes after. Don't mistake this for a valve not shutting off properly.
  4. If the water ever gets turned off while work is carried out on the water mains in the street or for major plumbing in your home, run lots of water in the house through taps at the sinks until it runs clear after the water is turned back on.
Faulty water valves should be replaced or there is risk of flooding.
Posted on Jan 11, 2009
  • 6 Answers
SOURCE: Washing machine WK61420GB drum does not turn
replace the brushes in the motor ( approx £5 parts)
Posted on Feb 21, 2009
RescueTech
  • 145 Answers
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Posted on Apr 20, 2009
Maytag washer (LAT7400AAV)shuts off during rinse cycle
The machine control board is programmed to allow a maximum continous fill time of six minutes
or an accumulated fill time of 8 minutes for each full wash cycle.
If the required fill time exceeds the time limit, the washer will shut down.
This is to prevent flooding in the event there is a loose hose clamp or damaged air dome hose.
Check the incoming water lines for a minimum pressure of 20 psi.
If lower, the customer can use smaller clothes loads and reduce the pressure to 10 psi.
An alternative solution would be to change the plastic inlet screens to metal screened washers
and remove the nozzle extender found in the water valve inlet hose near the dispener inlet."
Dec 10, 2014 | Maytag Washing Machines
Bosch classix 14oo washing machine displaying fault code F18.Wont pump water out but will spin if clothes are taken out.PLEASE can you help?
it could be that its spinning after you take the clothes out because you have given it 2 opportunities to drain/pump out.. once with the clothes in and once when you have removed them. Machines wont spin if the water doesn't drop below a certain level within a designated length of time. The problem might be a simple blockage
Check filter
Check drain hose and pipe its emptying into
Put machine on its soap box side down (very important) and powered off (very important)
Looking up the base of the machine you will see the pump right in front of you
Check wiring
The pump on these machines if I remember well have 1 screw and then you have to twist it to remove it
This will give you a chance to see if something got behind or is wrapped around the emptying propellor
Oct 16, 2013 | Washing Machines
I have a LG 15.0kg top loading fuzzy logic washing machine. Machine does not empty water out. What could the problem be?
i have a lg fuzzy logic 15.0kg and on fuzzy mode , it continue to supply water and do not wash clothes
please can anyone help me what can i do .
Oct 26, 2012 | LG Washing Machines
Our clothes are coming pout smelling bad after a wash. The machine is old. We do not know if there is a filter to clean out? Not even adding SHOUT will help the smell.
You should put one half cup of bleach in the washer and let it fill. After it sets for an hour run it thru a cycle refil and do it again. All washers have water left in them even when they empty so it sounds like you had stale water in it and possibly mold bleach will take care of it and a few cycles.
Aug 08, 2010 | Washing Machines
Dismantle washing machine fisher and paykel - unit smells -need to remove bowl to clean out
b4 u remove bowl try this 1/ buy 2 pkts bicarb of soda. 2/pour into empty bowl of unit. 3/select high water level 4/ select hot fill. 5/ start cycle 6/ let it wash for 5 to 10 mins then turn it off, do not let it get to rinse and drain the water away. leave it over nite with water still in it, in the morning restart program and let it do a normal cycle with no clothes in it. it will not refill as it already fill of water.please reply to see how u went or 4 more help
Mar 16, 2010 | Fisher and Paykel Washing Machines
Dec 30, 2008 | Siemens WK61420GB Front Load Washer /...
Smartdrive 703 Model Washing Machine Leaving brown stains in clothing after some wash cycles. Stains are small and seem to be something coming through to the clothess from the slits in the drum holes. ...
if you do cold washs all the time you get a build up of sludge between the drums you need to fill it with hot water and let it soak for a few hours and then put through a high wash to rinse out,no clothes.Or you can remove the drum and wash it .hope this helps
Mar 14, 2008 | Washing Machines
Washing Machines Logo
20 people viewed this question
Top CDA Washing Machines Experts
NOEL
NOEL
ray gallant
Are you a CDA Washing Machine Expert? Answer questions, earn points and help others
