Question about Sharp Microwave Ovens
Replace magnetron sharp - Sharp Microwave Ovens
  • John P. Cater Oct 31, 2012
    How hard is it to replace magnetron in Grill 2 Convection R820BKRB?
    Top Expert:
  • Sharp Master
  • 14,553 Answers
You have to take the unit apart--I would suggest you Google this by model number and look on You Tube who has video instructions for lots of equipment for replacing parts.
The first hurdle may be a lot of these units use special security bolts that require a special bit just to get things apart.
Posted on Nov 01, 2012
Magnetron part for a sharp carousel Microwave oven Model R-930ak
Maybe a faulty magnetron but check for abnormal noise caused by faulty diode pack. If you are in UK google the part number
RV-MZA114WRE0
R930AK Sharp Sharp Microwave
Apr 07, 2017 | Sharp Microwave Ovens
What is the most critical aspect in choosing a replacement magnetron ?
You can't install a magnetron that exceeds the capacity of the high voltage power supply. It's also unwise to install one of a higher output power than the original. Make sure any replacement is for a non-commercial oven, as some commercial ovens have used magnetrons with higher voltage and current ratings.
Jul 16, 2016 | Sharp Microwave Ovens
Not heating
Usually one of three things and not in any order:
The diode commonly used in most microwaves= it cannot be shorted and work.
The inverter board which powers the Magnetron.
The magnetron itself which does the work and can only be tested for sure by replacing.
12_12_2012_1_10_05_am.jpgtypical Microwave diode.
12_12_2012_1_10_45_am.jpgtypical Magnetron
Dec 11, 2012 | Sharp Microwave Ovens
Microwave runs lights come on but it doesnt heat up any food
It shows that magnetron is not operating,check high voltage diode grounded from the high voltage capacitor by replacing the same with same specification,if problem remains then check connection leads connected with magnetron for loose or corrosion,finally check by replacing the magnetron.
Feb 04, 2011 | Sharp Carousel R530EST Microwave Oven
Not geting hot
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Sep 07, 2009 | Sharp R-963 Convection/Microwave Oven
Sharp over the range microwave, no heat when turned on an a loud humming noise
HI, there are two issues here. the Magnetron tube and the noise filter has failed.
Just to make sure of the Magnetron failure, expose the device and, check the Magnetron temp fuse located near the device. this fuse will show no continuity when tested if faulty. if it testes out ok, replace the magnetron.
Jun 19, 2009 | Sharp Microwave Ovens
Everything seems to be working but it doesn't heat anything
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
May 11, 2009 | Sharp R-530ES Microwave Oven
Sharp Microwave oven magnetron blown or faulty
You can e-mail the spare parts manager with your model number here: JHB023@seartec.co.za
Aug 06, 2008 | Microwave Ovens
Microwave Ovens Logo
234 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
