Sometimes if I turn the camera off then on again it will take one shot, then Flash shorts every time i press button to take a photo. Any Idea's please. Camera is about 5 yrs old but not been used much.
SOURCE: Sony Cyber Shot DSC-L1 Digital Camera
Sounds like a jammed lens block assy.Does lens make any attempt to open??.Did camera get a knock or fall.Not much you can do but send for repair,Would advise get estimate before proceeding with repair.,
SOURCE: sony cyber shot DSC-H3 flash
The same problem just appeared to us. We decided that it is a software bug and we reset the camera with the following combination:
Home ->Settings(the toolbox) -> Main Settings 1 -> Initialize.
This fixed the problem.
Have in mind that all your settings will be lost (but not the pictures).
SOURCE: Sony DSC H-5 Camera battery problem and slow response time
use lithium batteries. They last longer
SOURCE: SONY CYBERSHOT DSC - H3 DIGITAL CAMERA FLASH PROBLEM
Hi Jim,
Have you tried resetting all settings on the camera? On a Sony camera, it is called "initialize". The initialize setting is found by going to the menu, and tabbing down until you find an option called either "reset settings" or "initialize settings" and then confirm it.
Many times that will fix the issue, in case something has either been enabled/disabled on accident, or the software is sticking (which happens from time to time)
Thank you Art, you hit the nail on the head. I got in touch with a Sony repair shop and they explained exactly the same as you have. This saved me a packet on a service which I was told "if it aint broke ,dont mess with it". Thanks again.
