Question about KLH (AT2100) System
KLH AT2100 speaker system cuts out after about five minutes
The speaker system is connected to a VCR/DVD player, which in turn is connected to a TV.  When we play a dvd with surround sound, the speakers work for about 5 minutes and then you can hear them cut out. Connections on back of sub woofer seem to be all right. The fuse is good.
SOURCE: Connecting a sub-woofer to Pioneer VSX-453 surround reciever
connect to same terminals as front speakers, this will also cause reduced volume from front speakers. (as per owners manual)
Posted on Nov 19, 2007
SOURCE: Connecting my Medion surround sound to my Sony dvd recorder
u need an amplifier (5.1), u put the two outputs in, and then theres loads of outputs coming out of yer amp. hey presto, im doing the same thing at my uni flat, but i need the amp. peace out x
Posted on Jan 02, 2008
Testimonial: "Excellent help Thanks"
  • 521 Answers
SOURCE: cutting on and off
the short tracking in the connections occurs normally after a long period of use.get it repaired if you want.or i will suggest you to get new sub woofers as the old one is at the end of its life.
pls do rate the solution
thanks.
regards.
fixya expert team
Posted on Sep 03, 2008
  • 5 Answers
SOURCE: loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Posted on Dec 16, 2008
SOURCE: sub woofer cuts on and off.
I was rid on my hum just as soon as I took my plug out of my powerstrip and plugged directy into an outlet. Must be something to do with incomplete grounding. It has been working just fine every since I plugged it into the wall.
Posted on Feb 19, 2009
Power on, few second automatically shut down in sharp video cd mini system. model # CD-M10000
hi,
speaker output amplifier of u system may be damage. that's why it goes off. check the out put amplifier.
ok
Jan 11, 2011 | KLH (AT2100) System
Nne help hooking up speakers to entertainment system
If you have a optical out on your dvd player and optical in on the receiver that is the best connection for digital sound, the vcr section will have to be hooked up analog using rca cords
May 26, 2009 | Mintek LCD TV Progressive Scan DVD Player
Toshiba TV/VCR/DVD combo MW24F12
You did not say if you have connected the video out on the surround system to the video in on the tv. If not connect it and select that input on the tv.
Aug 27, 2008 | Toshiba SD-V392 DVD Player/VCR
Samsung DVD V9700
Double check the cables. if it has a tuner, use that
Nov 25, 2007 | Samsung DVD-V4600 DVD Player/VCR
Installation Help
This means that you have purchased a three piece home theatre system. Two tweeters and a sub-woofer. Assuming you are using a Stereo player (Tape/CD/DVC)you have to connect the Left Output of the Stereo placer to the Left Input at the back of the Sub-Woofer and the Right output to the Right input of the subwoofer by cables. Then take tweeters and connect them to Right speaker and Left speaker output at the back of the sub-woofer ( note if the speakers are marked L/R, then connect them to the subwoofer output accordingly. In case you are using a 5.1 player, then only connect the front right and front left to the Right and Left input at the back of the subwoofer. You are and you can now start playing your music or movies and and you will get theatre quality sound.
Aug 22, 2007 | KLH (AT2100) System
KLH (AT2100) System Logo
113 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
