Question about Porta Air Tools & Compressors
Porto nailer will not drive nail home pressure 100 psi . gun new
NAILS NOT DRIVING ALL THE WAY . AIR PRESSURE IS 100 PSI AFRAID TO GO HIGHER. IS THERE ADJUSTMENT IN DRIVER
  • 1383 Answers
SOURCE: nail gun will not shoot
Not all 120psi air supplies are the same. Here are some differences. The pressure regulator has a great deal of effect on the performance of the air tool. Regulators are sold by the volume of air (cfm)that they can handle. The more cfm the larger the pipe fittings on the regulator. A 1/4 fitting regulator will restrict the air somewhat compared to a 3/8. Another difference is weather moisture is present in the air. Moisture will temporarily help seal the orings, however too much water in gun will cut the orings. The air hose and fittings will also stifle performance. Long small diameter hose will lower pressure at the gun. This can be measured by installing a guage on a T fitting on the end of the hose and watch the pressure as you fire the gun. Larger fittings and hose ID will improve performance. Finally, your nail gun should work on both compressors. To make your nailgun work at home, (assuming that there are no air leaks) lube the headvalve parts with silicone grease. (sold at lowes in plumbing dept) For best performance, replace the orings in the head valve, examine the plastic parts where the orings contact and look for wear and tiny scratches (use magnify lense). Replace these worn parts along with orings. Replace the head gasket and make sure that the body and the head-cap are not warped. Place sheet of fine sandpaper on flat surface, with cylinder removed rub the body of the gun on paper a few times to check for warp. Do same with cap. Parts are available at www.toolpartsdirect.com. Enjoy
Posted on Dec 14, 2008
  • 4 Answers
SOURCE: Dont know what nails to use on my makita brad nailer
is that a model AF505? if it is, your problem may be the gauge. make sure you use 18 gauge nails, he 16 gauge are too big and will jam in the gun.
Posted on Feb 26, 2009
  • 24 Answers
SOURCE: Makita AF503 Brad Nailer won't fire nail
Take head off of tool. Clean and lube orings on the head valve . Do not use wd40 use air nailer oil.
Posted on Apr 14, 2009
spekgt
  • 60 Answers
SOURCE: can I change the pressure on the nail gun?
Hi there .
First check if the nail gun have a adjustment screw . Depending on the brand could be in the front where the nails comes out or by the trigger. Second check the compressor by the air hose connection you should have a regulator valve with a gauge and see if you getting the right air pressure .
Hope this help
Posted on Aug 30, 2009
  • 2428 Answers
SOURCE: D51822 framing nailer - worked just fine for a
Yes your problem right about lubericatoin try putting lite oil in it hopefuly you didn,t taer one of the seals but if you did just standard o rings and you can get them at a hardware store and the gun is easy to rebuild
Posted on Nov 29, 2010
Why might my nail guns not work?
Have you lubricated either nail gun? If not, go to Home Depot and get a bottle of air tool oil. It's in tools by the compressors. Disconnect the air hose from the tool. Pour about a teaspoon of oil into the air inlet of the tool. Reconnect everything and try it 10-20 times with no nails in the tool. Then try it with nails. Good luck.
Sep 14, 2015 | Porter Cable Tools & Hardware - Others
Miss fires and wont sink nails depth set deep and pressure over 120 psi
If no air is leaking from gun, miss-fire is usually caused by worn or too tight piston oring or lack of lubrication. Easy test. Disconnect airline, remove nails, point nose of gun up then down. Driver should stay in uppermost position. If driver moves up then down within gun replace piston oring and retest. Set pressure to about 100psi. Good luck with repair.
Oct 14, 2012 | Porter Cable Coil Roofing Nailer
Hitachi nr83aa shoots out nail and it bends last inch of nail over
One problem may be your air pressure at the gun. It should be between 90 and 100 psi to fully drive the nail fast enough to prevent nails being left high in the work or bent over. Bent nails can also happen if you are driving nails into very hardwood or hit a knot in softer woods but not usually with framing nailers. Another thing to look for is a rounded off driver that is slipping off the head of the nail before it is fully driven into the work. The tip of the driver should be round (some have a crescent moon shape) but square to the sides. If you need a new driver the part number is 878-630, shop the web for one of these, they run beteween $80 and $100 plus shipping.
Jan 02, 2012 | Air Tools & Compressors
Nail gun 58-8434-4 will not drive 3" nails all the
Hi foxden503,
Welcome to fixya!
As a general rule, framing nailers use anywhere from 45 to 120 psi to drive nails. But this also depends on the hardness of the wood.
The nail head should be flush with the surface. If it sticks above the wood, increase the pressure a little bit at a time until you achieve this goal.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jul 20, 2011 | Tools & Hardware - Others
Adjusting airpresure
There is nothing on a nailer to adjust the air pressure. You have to do it at the pressure regulator. It is feasable to mount a regulator at the gun but more likely it's on the compressor. Most nail guns are rated for 90 to 120 psi. Set your regulator to hold the hose pressure between 90 and 100 psi. Using higher pressure to set the nail will ruin your nailer. Use the depth adjustment on the gun to set how far the nail is driven.
Sep 23, 2010 | Nailers 3 12" Pneumatic Air Round Head...
GUN NOT SETTING NAILS
Hello jsc.... the depth that the nailer drives the nail is dependent upon two factors, the hardness of the material you are driving the nail into and the air pressure. Generally when you want the nail to go in more you adjust the air pressure to a higher setting, going 5 psi at a time until you are close to perfect and then fine tuning the air pressure.
Sometimes people find that the air compressor itself is inadequate for the job. in that case, the only choice is to move up to a higher psi compressor. Joe
Thanks for choosing Fixya!
Jul 04, 2010 | Hitachi 3 - 1/2" Full Roundhead Framing...
Senco finish nailer not firing nails
firing pin called the driver is probably broken or needs new seals max air pressure 125 psi senco sells repair kits
May 13, 2009 | Tools & Hardware - Others
Porter Cable BN125A won't set nails below surface
Not sure about the seal, but I do know the pressure has to stay up for this nailer to be effective. Try oiling the gun to free up the mechanics and don't use old nails.
Jan 23, 2009 | Porter Cable Cable BN125A Factory -...
The nails aren't going in far enough using a air cleat nailer
I just finished 800 square feet of oak flooring with this nailer. You might have to increase the psi at the gun and make sure it gets a good square firm hit to set the nail. You can swing and hit the thing pretty hard, I hit it hard to set warped boards in place. I used 120 psi for best results, I tried 90 psi but had more misfires. The nail head only needs to set in far enough so the head is touching the tongue and so the next board will fit. The nail won't be buried into the tongue like you might think. If the occasional nail protrudes from the board you can use a nail set to drive the nail the rest of the way in, but I found that most of the nails didn't want to set by hand. I either clipped off the head with side cutters and folded over the remaining tab or did my best to set the nail if it wasn't long enough to clip. If it bends over really ugly, just carve a little wood from the groove lands on the next board to clear the nail stub. Removing the nails is difficult, it's best to let them be rather than risk damaging the flooring. Also, don't let the gun get down to the last nail. Sometimes if you try to fire the last nail on a strip it will twist and damage the flooring. Always keep a few nails in the gun just to be safe. Hope this helps.
Nov 23, 2008 | Porter Cable 2" Flooring Cleat Nailer...
Air Tools & Compressors Logo
49 people viewed this question
Top Porta Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Porta Air Tool and Compressor Expert? Answer questions, earn points and help others
