Question about RCA TruFlat 27F520T 27" TV
Power button on my rca tv wont turn on sometimes
Sometimes the power button works, sometimes it will work with remote, when you push either power button the button on tv will light up and click three times. sometimes its sticks on and sometimes it doesnt
    Top Expert:
  • RCA Master
  • 14,553 Answers
A number of possible reasons for this---failing part in set or even bad connections on main board in the set----model listed is prone to going dead with high pitched squeel etc.
Posted on Nov 01, 2012
SOURCE: RCA F32450 32" TV: suddenly shut off wont turn on
Followed Terryfic's solution. I am a DIYer and managed to order the part, desolder the old one and solder in the new one. However, when I turned it back on I got a black screen with sound. Hmmm, saw the adjustment screws but was hesitant. Ended up turning about 10 degrees one way and presto chango... Saved a $1200 upgrade to HD for a $30 part! Thanks
Posted on Dec 25, 2007
  • 236 Answers
SOURCE: RCA F20539DG
YOU might have a bad relay or a bad solder connection in the relay control circuit. Sounds like a bad solder joint. Stargazer
Posted on Mar 03, 2007
  • 1694 Answers
SOURCE: Won't turn on.
Bad flyback xformer AKA IHVT.
Posted on Oct 04, 2007
SOURCE: RCA TV stopped working
Time to go to BEST BUY and nuy a better tv
Posted on Apr 16, 2008
SOURCE: rca d52w15
I have the same tv. It sounds like the flyback transformer is arcing out. I replaced the flyback transformer and 3 capacitors. Now i have different problem. Goodluck
Posted on May 02, 2008
How can I program my RCA universal remote to my element tv , what button to press for the light to blink and the code to put so it can work on my tv
RCA does not have for a code Element TV. With that being said there is a work around:
Turn on your TV.Then push the code search button until the LED still ,when the LED keeps on let go the button now push and release the TV button then push and release the power button until the TV goes off, when the TV turn off stop to push the off button now push the set button the code are already set on the remote control( you might have to push the off button almost 100 times or more until you get the right code for your TV. Best of Luck
Aug 26, 2015 | RCA Televison & Video
Will not turn on?
the lightining battery is not working very well. You should exchange it, so the TV power could get to the Tv and let it Work.
Feb 28, 2008 | RCA F36685 36" TV
The codes i got with my RCA universal remote wont work...
Sometimes the programming procedure might haven't right. Four digit codes to check with RCA Brand TVs are: 0031 0004 0048 0054 0094 0100 0102 0107 0129 0191 0005 0009 0000 0162 0163 0342 0003 0015 0022 0096 0113 0125 0179 0187 0188
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
If you want to know more, check this.
Dec 28, 2012 | Televison & Video
Can not control the volume on an rca
Ok to reprogram the remote and this only works if you just use the remote for the tv and the receiver. Like i was saying to reprogram the remote hold the tv button till all the top lights flash, then push the red power button, then hit the up arrow button slowly til the tv cuts off, once it cuts off hit the pound (#) button. The top lights should blink three times, that should reprogram the remote, If it is a tv/vcr combo or a tv/dvd combo then there isnt a code for it. Also there is a series of years that the rca tv's wont take a full code and u can just control the power and the tv channel
Sep 05, 2010 | DISH Network IR Remote Control
I have a remote that i have had for a while and it stopped working. I changed the batteries but it still doesn't work. I have the codes for it but i missed placed the instructions on how to set the code....
turn on manually your set (tv), push the code button on your remote control until led light, release the button, the led still ligth. push the tv button one pulse, push the power button several times until tv turn off. when this happen push enter button... try turn on the tv with remote control.
Mar 20, 2010 | RCA Universal Remote Control
1999 RCA mm36100 TV The buttons on the front panel are all messed up sometimes they work and sometimes not. The menu keeps popping up from time to time randomly and sometimes runs though the menu items all...
Bad push button board, best thing to do is just unplag the board and use remote to operate TV, board is mounted under front cover where button are.
Aug 09, 2009 | RCA MM36100 36" TV
Insignia TV code for RCA Universial Remote Control (RCR450)
If its a four digit code remote. I may be able to help.. Try these...0171, 1204, 1326, 1517, 1963, 2002..
Good luck
Nov 11, 2008 | RCA 4-in-1 Universal Remote Control
Rca tv
your power button is in trouble so , change it with a new one.
Oct 01, 2008 | Televison & Video
Try it without a code. Turn your tv off. Press tv then press the on.off button and tv button at the same time. When it lights up, press play every five seconds until the tv powers off. Next press the reverse button every few seconds (sometimes takes a while), until it powers back on. When it powers back on hit the stop button to save the code.
Sep 08, 2008 | RCA Universal Remote Control
RCA TruFlat  27F520T 27" TV Logo
93 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
