Question about Ricoh Savin Lanier Set Type Mp C7500/ C7570 Ld275c c & M 841289 841290
Need to replace color pcu ricoh mp c7500 - Ricoh Savin Lanier Set Type Mp C7500/ C7570 Ld275c c & M 841289 841290
Functional problem sc302 in ricoh afficio 1315
this is a charge issue - a simple fix would be to remove the pcu and clean round its outside and then clean the contacts to it inside the machine - if this doesnt work the pcu needs stripping down
Oct 22, 2013 | Ricoh Aficio MP 1600 Black and White...
Mp 161
open the right cover where you normally remove the paper jams,then open front cover/door where you put toner,lift the green handle up,push green lock towards the right side while pulling the hopper out,then theres a connector beneath the PCU,pull it then pull out the PCU,use the same same procedure to put it in,start with the PCU,return the connector and put in the hopper,then close all doors/covers
Apr 29, 2013 | Ricoh Aficio MP 161 Black and White Copier
How to clear the pcu code
The printer is set to display the "replace PCU" message after a set number of copies. The only way to clear the message is to replace the color PCU that the message mentions.
Apr 17, 2010 | Ricoh Aficio CL2000N Laser Printer
Thin lines along left side of Ricoh CL2000N laser printer
Printing B&W? Colour? or both?
Depending on your answer, replace the applicable Photoconductor.
Mar 02, 2009 | Ricoh Aficio CL2000N Laser Printer
Ricoh Aficio CL3500N PCU issues
These machines were actually made by Panasonic and they eat PCU's there is no rhyme or reason, they just do. I would replace all of them as soon as possible. These printers were pretty much interim technology for Ricoh until they developed thier own engine. I highly recommend the new 400 color series, low cost per page, vg color and consumables last a long time!
www.mfpsolutions.blogspot.com
http://www.websitetoolbox.com/mb/copierquestions
Jan 19, 2009 | Ricoh Aficio CL3500N Laser Printer
Ricoh aficio cl3500n reads replace colr pcu what is this?
The PCU is the photconductor unit. There is a black pcu and a color pcu. Did you replace these or replace the toner cartridges??
Ricoh Aficio Color Registration Error
One of our Ricoh CL3500N printers- less than a year old- gave us a "color regist error" after changing the transfer belt.
Ran the "adjust color regist" without results. It would just finish and pop back up with the same error.
Color test page printed no color, just BW
I reseated everything, and even replaced the PCU without positive results.
A couple hours later I went back, took everything out (be sure to keep the pcus out of the light!), and vaccuumed the heck outta that printer.
For whatever reason- maybe there was a chunk of toner hanging out, maybe I knocked something loose or back in place, whatever- but when I put all the parts in and turned it on, the error was gone and color printed great!
Dec 11, 2007 | Ricoh Aficio CL3500N Laser Printer
Ricoh Savin Lanier Set Type Mp C7500/ C7570 Ld275c c & M 841289 841290 Logo
Top Ricoh Savin Lanier Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Ricoh Savin Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
