Question about Panasonic KXDT343 Phone
Panasonic KX-DT343 answering in intercom mode
Incoming calls are answered through the intercom. My phone does not ring, it beeps, the intercom comes on and I am automatically connected to the caller. I need to disable whatever function this is so that my phone rings and I have to pick up to answers.
4 Suggested Answers
mumma_1
  • 903 Answers
SOURCE: number of rings on answering machine Panasonic KX TCM 506 BX
http://service.us.panasonic.com/OPERMANPDF/KXTG5631.PDF
this link will take you straight to the operating manual in pdf format
hope this helps you out
Posted on Oct 28, 2008
cnavarro
  • 2460 Answers
SOURCE: Hi: I have a Panasonic KX-T7420
There are 2 things that would prevent you from being able to answer a ringing phone by picking up the handset. Your phone has to be ringing, and you need to set preferred line ringing on incoming calls.
The second part is easy. Press PROGRAM 99 and dial 22 STORE on your phone. Now when a call rings on your phone you can pick it up. If you can't, then your phone is not ringing.
Ringing is set in system programming.
Carl
Posted on Feb 12, 2011
cnavarro
  • 2460 Answers
SOURCE: how do I change the
If this is forwarding to the answering machine on YOUR phone, from the intercom dial *713xx where xx is a number of seconds. I think by default it's using the system number of 40 or 45 seconds. Try 24 for 4 rings (or multiply the number of rings by 6 and you get seconds).
If you're talking about SYSTEM rings before the VM, it's a different story and it requires system programming.
Carl
Posted on Aug 24, 2011
How to get speaker phone to work on Panansonic KX-DT343
Download the Panasonic KX-DT343 users manual and a pdf and there should be what you are looking for if not then there must be something funny going on with the menu system but why not have a look in the settings to see if the intercom setup is there but I think you will find out what you want from the KX-DT343.pdf file.
Dec 17, 2014 | Panasonic KX DT343-B Digital phone - Black
I have a panasonic kx-dt343, i can find the incoming call log but only calls that i've answered not ones i've missed. how do i check the missed calls? how do i set it up so the phone will flash if...
Normally, the ICD group is 601. So, press PROGRAM, pick a button, and dial 54601 STORE. The button becomes a log for all calls ringing into the 601 calling group.
Carl
Sep 22, 2011 | Panasonic KXDT343 Phone
How can i do two way on panasonic 5.8ghz
These directions are for the KX-TG5451, KX-TG5452 and KX-TG5453.
If you want to use the intercom feature, you need to know the handset number for the unit you want to contact. The base is zero. The handset number is set when you register the handsets. So to communicate with the base, press Intercom on the handset followed 0. The base will ring until someone presses Call to answer it (or one minute whichever comes first). (Alternatively, you can use the up/down arrows to select H1, H2, H3 or Base. Then press the right arrow key.)
To communicate between two handsets, press Intercom and then 2 (from handset 1 or 3 to connect with handset 2). Again the handset will ring for one minute or until the person with handset 2 answers. (To answer, they can press the phone, speaker or intercom button.)
If someone at the base wants to use the intercom, they need to press Select until the appropriate handset number is displayed. Then press Call.
To transfer a call, press Intercom and then select the desired handset. When the intercom message is picked up, indicate that a call is being transferred and press Off at the handset or base that initially answered the call.
For a conference call, initiate the call then press Intercom and select the handset to join the conversation. Once that person picks up, then press Conf. (I believe that Conf is a softkey so check the display.) This is only possible with the handset. (Another handset can join the conference by pressing the phone or speaker button on that unit.)
The manual for the KXTG5453 is available here: http://service.us.panasonic.com/OPERMANPDF/KXTG5451S.PDF .
If you have a different model of the Panasonic 5.8 GHz phone, please add a comment with the model number and I'll try to give the directions for that unit.
I hope this helps.
Aug 11, 2011 | Panasonic KX-TG5453PK 5.8 GHz DSS Cordless...
On the Panasonic KX-T7633, how can you answer a call on extension 101 that is actually ringing/incoming on extension 103?
A couple of ways, the easiest is to dial *41103 on the intercom. *40 may also work, but it picks up any ringing outside line.
Carl
Jul 20, 2011 | Panasonic KX-T7633 Corded Phone
Why does the auto dial/store button lights up by itself on the kx-t7730
Get a picture of that and send it to Panasonic! Your phone would be the *ONLY* one that does, since the button has no light.
Now, the AUTO ANS/MUTE button lights up when pressed to put the intercom in the Auto Answer mode under certain conditions. That could be the one you're seeing. It either forces intercom calls into auto answer if it's a ringing call, or into handsfree answerback if it's a voice call. It also indicates a muted microphone on speakerphone calls.
Carl
Aug 17, 2010 | Panasonic KX-T7730 Corded Phone
Hi: I have a Panasonic KX-T7420 phone. When one of the incoming lines is ringing and I pick up the handset, it picks up the intercom and not the incoming line. Is there a way to get the thing to answer...
Carl
Aug 04, 2010 | Panasonic KX-T7420 Corded Phone
No ringing sound for second incoming call
On the intercom, if it's a TA or similar phone system, dial 7311# for call waiting on outside lines and 7321# for call waiting on the intercom. (0 cancels).
Carl
May 21, 2009 | Panasonic KX-TS3282W Corded Phone
Panasonic KXDT343   Phone Logo
171 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
