Question about Lexmark X1240 All-In-One InkJet Printer
My lexmark x1240 will not print in color
After working fine for more than one year, this nice machine will scan in color but no longer print in color. Everything black works fine. I have tried many things including two new color cartridges, #26. When I tried to uninstal the Lexmark 1200 Series I received the message, "Lexmark 1200 is currently in use. Wait until the printer has finished then uninstall." However, I can find nothing which keeps the printer in use.
After a self-test on the color cartridges, the light does not flash twelve times but the page does not come through with colored lines. Suggestions will be appreciated. jim, rocklin, ca
  • 1 more comment
  • jim_2550 Jan 08, 2009
    Thanks for your response. I still have the problem, I have since tried a new lexmark 27 cartridge also but still cannot print in color. The color cartridge self test light does not blink 12 times but the test page does not print in color.
    When I try to uninstall I still receive the message, "Lexmark 1200 is currently in use. Wait until the printer has finished then uninstall."However, I have been unable to uninstall because I can find nothing which keeps the printer from finishing.I have an Acer 5000 and use XP.
  • Anonymous Mar 01, 2009
    will not print a coolor pic but will blk and white
  • Blakniss Mar 15, 2009
    Color cartridge is a little more than half full, but will not print in color on test sheet or any color document. I have tried putting the color cartridge in hot water for about 1 minute; the color is perfect when I dry the cartridge but when reinstalled, the same problem is prevalent. I don't know what to do. Should I throw away a cartridge that shows half full and use a fresh one? I'm starting to dislike this printer and its issues a lot. I guess I got my money's worth since it only cost me $40.00. Still there should be some sort of fix or answer to the color ink dillema.
  • 300 Answers
After disconnecting the cables from the printer and restarting the computer I would suggest removing all printer related software from Add/Remove programs in the Control Panel. After that I would suggest downloading the latest drivers by following the directions below.
You should be able to get the drivers here. Just enter your exact printer model in the Search by printer model field and press Enter.
Click the Download Driver link and choose your operating system in the Select Windows field. Then on the next page, choose the Download Now link on the right.
On the next page you may see a yellow security banner at the top of the browser. If so, click it and choose Download File. After that, choose Save to start the download. After the download completes you can double click the file to start the installation.
Hope this helps. Please remember to rate this information.
Thanks
Posted on Jan 04, 2009
  • S C Jan 08, 2009
    I just had a few questions to ask.
    1. Did you disconnect the usb cable before attempting to uninstall? If so, you may want to attempt to uninstall the programs again in safe mode. NOTE: Some programs dont allow this. If it doest work just restart the machine without pressing F8. If you arent familar with safe mode, you can find info here.
    2. Did you check the printer properties/preferences to make sure that it wasnt set to black only.
Black ink not working lexmark pro915
Check ink level, clean contacts on cartridge and machine.
Oct 10, 2013 | Lexmark Pro915 Wireless All-in-One Inkjet...
I want ti print in color only,how do i do that,?Lexmark X1240 All-In-One InkJet Printer
On your computer, with your file open (your document/picture, etc. that you wish to print), click File > Print. From Print dialog box, click Properties, Preferences, Options, or Setup (depending on the program). The Print Properties dialog box appears. From the Quality/Copies tab, make sure there is no check mark in the "Print Color images in Black and White ". Then hit OK button to save the setting. Once you print your colored document/pictures, etc, it should come out in color.
I hope this helps.
Dec 02, 2011 | Lexmark X1240 All-In-One InkJet Printer
Color cartridge do not want to print
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
May 28, 2009 | Lexmark X1240 All-In-One InkJet Printer
Hideous Color
Still working on it. The weekends are my best bet as I have little time to concentrate after work.
Thank you and I will let you know.
Jan 04, 2009 | Lexmark X1240 All-In-One InkJet Printer
Lexmark x1240 will not print
did you tried to set the properties to mono ?
Apr 12, 2008 | Lexmark X1240 All-In-One InkJet Printer
Scanner not workin-lexmark x1240
Which operating are you using if your using (Vista use windows photo gallery to scan)
Mar 28, 2008 | Lexmark X1240 All-In-One InkJet Printer
All in one printer does not scan or copy
If the Ink Status is showing a ? symbol after you have replaced the tanks, you just need to tell the printer that you replaced tanks ,
To do that , open your lexmark solution centre from the Lexmark start menu group.
Click Maintenence
Click Install New Print Cartridge
Jan 18, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark X1240 All-In-One InkJet Printer Logo
533 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
