Question about Texas Instruments TI-83 Plus Calculator
Batteries drains quickly
My batteries will only last a couple of days if left in the calculator. It's like it is draining even though it had been turned off. I have to remove the batteries after I use it every time to keep it from draining. I'm using good/new Duracells
I had something similar, it kept saying "battery low" after putting in new batteries. Try the Clear method; Take out one battery, hold the Clear button, while holding it insert the battery again and press on, and release. Now press clear again, turn it off and turn it back on again. If that doesn't help... well it must be something else... sorry :S
Posted on May 31, 2007
Batteries seem to drain overnight
hi, don't forget the charger, sounds like the batteries are very weak check the charger by trying another charger if possible...
Regards
Rob
www.gewizrepairs.co.uk
Mar 07, 2014 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
TI-84 Plus calculator keeps draining a set of batteries with each use. Can this be fixed?
Either you are putting in partially discharged batteries (test the new batteries with a battery tested NOT a voltmeter), or there is a partial short in the ca;culator (low impedance). If he batteries test good before insertion and they drain very quickly upon use, then the calculator is defective (it has some sort of low impedance in the circuitry. In this case, complain to Texas Instruments and have them give you a new calculator.
Dec 18, 2009 | Texas Instruments TI-84 Plus Calculator
My calculator drains a set of four batteries with every use. Why?
I am not sure what every use means: duration, programs running etc. But that drainage is properly excessive. TI estimates that with 2 hours a day of usage, the batteries should last a school semester.
Possible causes of rapid drainage.
The most common causes of rapid battery drain are mismatched batteries
  1. Batteries of different brands
  2. Batteries of different types (alkaline (1.5V + rechargeable NiMH 1.2V)
  3. Batteries of different charge levels (new batteries with old ones)
  4. Negative charge build up
Another cause of rapid battery drain is the use of third-party programs: Certain of them keep large amounts of data in memory. Some of them are tweaked to bypass the TI power management scheme and disable the TI APD (automatic Power Down ) after 5 minutes of inactivity.
Possible remedies
  1. Remove all batteries (main batteries and backup battery)
  2. Leave them out of calculator for about 15 minutes. (Beware that this will clear the contents of the memory and that data will be lost along with all applications installed). However Applications cam always be reinstalled once calculator returns to its normal state.
  3. The possible benefit of the removal of all batteries is to make the negative charge build up disappear.
If that fails
If the foregoing steps fail to restore the calculator to its normal behavior, you may have to contact TI Customer Assistance by filling out and submitting a customer assistance form.
Min eis an HP 11C. flashing 0.00
If the asterisk is flashing, the batteries you put in are not good either.
Sep 12, 2009 | HP 12c Calculator
New, barely used 89 drains batteries quickly
Because the games programs are writen badly and are running even when the calculator is off. Battery life will be extended if you get rid of the games.
Apr 14, 2009 | Texas Instruments TI-83 Plus Silver...
HP48SX Battery drain
I suggest you use rechargeable batteries. They usually drain faster than the alcaline ones anyway.So have 2 sets of rechargeable batteries. Evaluate the number of days a set lasts. Insert the charged batteries before the old ones are thourougly drained.
The life of your batteries in the calculator depends on the usage.
About repairs: I am convinced that it will cost you more to have it fixed than to buy a new HP calculator (HP 49g*'s, HP 50g* 's).
Hope it helps.
Nov 13, 2008 | HP 19BII Calculator
Batteries
Most digital camera's drain batteries quickly due to the power required to operate them. You need to carry spares if you are going to use them a lot. You can consider using rechargeable batteries if your useage justifies this i.e how quickly would you recover the cost of buying the charger against the cost of replacement batteries. Otherwise is just something to live with.
Oct 19, 2008 | Kodak EasyShare C613 Digital Camera
Konica Minolta DiMAGE Z10 Battery Leak
It sounds like a short in the circuit board. Not worth getting fixed unless you find a local person. but first try puting a set of lithium batteries in. sometimes those last forever even when other batteries last less than 10 shots.
other wise try takeing the batteries out whenever you are done and see how long they last that way. then you will know if it is a short if they last a long time.
Hope That Helps,
Caleb
Feb 09, 2008 | Konica Minolta DiMAGE Z10 Digital Camera
Batteries Dying Quickly
Change the internal rechargeable battery.
Dec 01, 2007 | Konica Minolta DiMAGE Z5 Digital Camera
Texas Instruments TI-83 Plus Calculator Logo
1,008 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Steve Allison
Steve Allison
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
