Question about GE Carrier Bryant Payne 1 Hp 208-230 Blower Motor Hd46gk230 Genteq Furnace
Thermostat is flashing heat on but the heat pump does not turn on.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 45 Answers
If the stat uses batteries replace them
Posted on Apr 11, 2013
WHAT DOES IT MEAN WHEN HEAT IS SET 66 AUX IS FLASHING
If it is a heat pump if the ambient I door temp is not than 3 degree s lower than 66 it utilizes the aux heat ( heat strips) to help the unit achieve your desired temperature set point faster. Also the heat pump does need help if trying to overcome really cold temperatures. Once set point is achieved the heat pump should be able to keep the home at the set point without aux heat. But the flashing may just be to let you know that the heat strips are in use at the current time. See if when the temperature gets close to your set temp if it goes away. If not a heat pump it may always flash to just tell you heat strips are in use. Some homes mostly trailers only have heat strips but on heat pumps heat strips are there to help heat pump get to your desired temp. But when your heat pump can maintain the temp without the strips is where it saves power. Also heat pump thermostat hVe emergency heat settings. This scares alot of people but if your heat pump isn't working and you have to switch it to emergency heat until you can get it fixed,. That means that the system is only using heat strips and not utilizing heat pump at all. Power bill may be a little higher but remember, most trailer homes only have heat strips and if you do not use emergency heat in this situation your heat strips will only heat home 3 degrees below set point on thermostat to allow heat pump to bring it up the other 3 degrees. If heat pump isn't working correctly you will always be 3 degrees colder than what you set you thermostat at. Maybe too much info but it's prolly just your aux heat on helping system achieve the desired temp you set thermostat too.
Oct 24, 2016 | Heating & Cooling
Heat pump runs on electric when outside temperature is higher than cutin
Check your thermostat and heat pump owner's manuals. Thermostat may be programmed to require electric heat at higher temps. Also could be bad outdoor temperature sensor tied to
Heat pump system controls (I had that problem) When was it installed? Warranty thermostat and or Heat pump? Call installer
Thermostat programming is a headache. No help from installer? call customer service heat pump and thermostat. Some possibility of bad installer wiring. There is also a heat pump "defrost" cycle. Usually the Electric coil will turn on to compensate for the Defrost cycle which is just the standard air conditioning mode therefore moves heat from inside to the outside coil to melt the frost. This cycle may be occurring too often. I had that problem. Fixed under warrantee.
Heat pumps are complex machines. The controls even more.
You need a tech, hopfully you are still under warranty.
Hope this helps.
Feb 27, 2015 | Payne 15 SEER R-410A Complete Split System...
Why contactor on heat pump will not energize heat mode?
Heat pump and AC are basically working the same principle. When you turn on the heat pump is just like to turn on the AC. The main contactor will energize to turn on the compressor. The only difference is the 3 way valve, either switching to AC mode or heat mode. It is the most commom problem for heat pump. Check the thermostat wires for heat mode and defrost control.
Feb 05, 2015 | Heating & Cooling
What does it mean when the aux is flashing on my thermostat?
I assume that you have a heat pump system. If this is the case, the outside temperature is probably lower than the heat pump is sized for and it is using the auxiliary heating system to keep up. The auxiliary heating system usually is an electric coil in the heat pump unit which supplements the heat being produced by the heat pump. This is normal operations and does not indicate a problem with the heat pump, it is just really cold outside. If it is not colder than usual outside, there may be a problem with the heat pump and you should call a heating contractor to check it out.
Jan 10, 2015 | Emerson 1F89EZ-0251 Blue 2" Thermostat,...
Matercool thermostat wont turn on drain pump
Condensate pumps dont work with the thermostat . The pump has an internal float switch that kicks the pump on when the water reach a high level. If the pump failed for any reason the safety swicht will turn off the ac unit to prevent any water overflow.
Sep 07, 2017 | Mastercool Heating & Cooling
We have a new a/c and the system has heat strips. For a/c. we have had the thermostat set on AC at 72degrees. Now that it is getting colder and may need some heat in the house, do we switch the...
If your thermostat has an emergency heat setting this means you have a heat pump system.
Yes you need to set the thermostat to heat for heating the house.
The emergency heat setting should never be used unless your outside unit is not functioning.
The emergency heat setting overides the heat pump (the outside unit will not be energized).
The emergency heat setting will run the auxillary heat (heat strips) only.
When the thermostat is set in the heat position the heat pump will run to heat your house.
If the heat pump can't keep up (extreme cold) then then the auxillary heat will kick in to augment the heat pump until it satisfies the thermostat settings. If your room temperature gets 2 degrees below your thermostat setpoint, your auxillary heat will kick on. Example, say you are going to be gone a couple of days and you turn your heat down to 60 degrees. When you return and it is 60 degrees in your house, you turn the thermostat up to 70 degrees. Since you are turning the temperature up 2 degrees or more (10 degrees in this case) from the 60 degree room temperature then the heat pump will come on and the auxillary heat strips. The unit will continue heating like this until the temperature in the house gets to 69 degrees and the heat strips will turn off and the heat pump will continue to run until the 70 degree setpoint is reached.
Hope this helps.
SeagullAC
Sep 15, 2011 | Heating & Cooling
What does the "auxillary heat"
Auxiliary Heat is used to turn the electric heat strips ON, If the heat pump is not working. Or if the heat pump can't bring the space temperature up to Set Temperature it will display Aux Heat ON....... Assuming you have a Heat Pump System with Auxiliary Electric Heat as Back up...... If the tech didn't install a jumper wire from AUX to W on the subase which is in back of the Display on the Thermostat.....you won't get Auxiliary Heat if the Thermostat is set for Auxiliary Heat. Other wise the thermostat will turn the heat pump on first and then the electric heat (Aux Heat) if it needs it to satisfy the set temperature....... Hope this helps
Apr 21, 2011 | Honeywell Electronic Programmable...
My heat pump thermostat is flashing "filter malfunction" and the heat is not working.
If you filter is in the furnace, it may be clogged or has moved out of position. Thereby, triggering the sensor that is signaling the thermostat that there's a "filter malfunction". and turned the heat cycle off. Check the filter for clogs and change the filter or if it's not in the proper position, but it back in place.
Apr 01, 2011 | Amana Heating & Cooling
Buzzing sound when aux heat comes on
Sounds like it could be a effiency function to warn you that the heat elements are on. Check your thermostat manual and see if you can turn this feature off. If this is not a feature then the thermostat may be wired wrong or something in the circuit may be trying to short out.
Jan 04, 2010 | Honeywell Electronic Programmable...
Thermostat says ''Aux heat on'' and buzzes when we turn on heat
You most likely have a heat pump, the aux heat (usually electric) comes on anytime the room temperature is 4 degrees below the thermostat setting. Does the buzz go off when the aux heat lite goes out? If the aux heat does not shut off then the primary heater (heat pump) is not putting out enough heat to satisfy the thermostat. I need a little more info. Do you have a heat pump? Is it working?
Nov 19, 2008 | Honeywell Electronic Programmable...
GE Carrier Bryant Payne 1 Hp 208-230 Blower Motor Hd46gk230 Genteq Furnace Logo
477 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
