Question about Electrohome 19 inch Slim LED 720p HDTV & One Bonus Nyrius Universal TV Video
Code for electrohome 19el708 tv
Need tv to remote codes
I need the code for an Electrohome Tv for universal remote Tv is 19EL708
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name only of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 09, 2015 | Universal Televison & Video
Sony, RM-V210. need code for Electrohome TV.
This remote control have no setup codes to Electrohome TV. If you wish to get more codes and other details check:
http://electro-medical.blogspot.com/ It has setup code list, and setup procedure to many popular brand remote controls. View the site in 'Mosaic'. It will make search easy. If you wish to buy a genuine remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have set-up codes to your TV brand, and buy that one according to availability.
Jan 03, 2014 | Televison & Video
Codes for electrohome tv
These are the four digit universal remote codes for Electrohome brand TVs. If you want to get three digit code list, and setup proceedings, check this link. It has all details. Do a search by entering the brand name to your device by its search box at top right of the display window, because, posts are not arranged in alphabetical order, by brand name at first.
Dec 21, 2012 | Universal Remote Control GE174Universal...
I need code ALLFORONE remote 4220 for Electrohome tv
These are codes for Electrohome TV: 0004 0009 0254 0003 0022
Sep 15, 2012 | One For All URC4220 Remote Control
I have an electohome tv and am trying to program my rca universal remote- nothing is working...any suggestions?
These are generic RCA Universal Remote codes to control an Electrohome TV: 006, 011, 014, 027, 038, 061, 068.
Your specific model will have other additional codes. If these codes don't work, you could try re-posting with more information.
Many RCA universal remotes have a CODE SEARCH button. If yours does, here are the steps to search for the proper Electrohome TV control codes:
  1. Manually turn ON your TV.
  2. Press and hold CODE SEARCH.
  3. Press and release the TV button.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the TV turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the TV turns off, press and release ENTER.
Hope that helps.
Oct 15, 2009 | Universal Remote Control DIRECTV Universal...
Code needed for a Electrohome tv
The Product: Electrohome 27E510
The Problem:
3rd Party Universal Remote when trying to "scan" for correct codes inadvertently activates a diagnostics setting on the TV set.
The Symptoms:
The word "FACTORY" appears on the upper left quadrant of the screen in RED letters & suddenly all controls are "Locked Out." Television will not respond to button presses on original remote or on it's built-in-buttons on the side panel. All settings/options are "Locked Out" & the TV can only be shut OFF by physically unplugging it. Additionally, when the TV is plugged back in, it is still in the "ON" state & remains in "Locked Out" state.
The Solution: (thanks to a couple of hard-working Support Personnel at NESA)
Plug TV back into power source. Wait until it powers up and the word "FACTORY" is visible on-screen.
Press 6-4-8-3 on the TV's ORIGINAL IR remote device.
You are now in the diagnostic settings Sub-Menu, & the word "ADJUST" will be on the screen.
Press "MENU" on your TV's ORIGINAL IR remote device.
The TV is now back to it's former fully-functioning state.
Dec 28, 2007 | One For All URC-3021 Remote Control
TV code
0381 is one code used for electrohome televisions
Dec 04, 2007 | Motorola Mobility DRC800 Universal Remote...
Electrohome 19 inch Slim LED 720p HDTV & One Bonus Nyrius Universal TV Video Logo
46 people viewed this question
Top Electrohome Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Electrohome Audio Player and Recorder Expert? Answer questions, earn points and help others
