Question about Metra 70-1818 Crysler Dodge Jeep Amp Intgation Harness
Why when i put gas in my car it jump back out
    Master:
  • 689 Answers
Don,t insert the fuel pump gun all the way down into the fuel filler pipe, pull back on it a bit when your filling the tank then it will not Splash back on you, The fuel filler pipe might of got bent some how, That could cause it to do that .
Posted on Nov 06, 2012
Ran fine, shut off. Came back out, turned over but not start. Had jump started twice but put in gear and died. Question: I know low on gas, can this effect anything?
Possibly a fuel supply issue. Will require a fuel pressure tester. Could be in tank pump or a bad fuel pump relay. In a quiet environment, turn key on (not start position ) and listen if you can hear the guel pump run for 1 or 2 seconds.
Sep 05, 2015 | 2004 Ford Focus
Gas gauge problem
check all wiring around starter to see if you pinched 1 or 1 is grounding against starter.
can not add more because you not state make an model
Aug 14, 2015 | Cars & Trucks
2007 chrysler 300 car won't start OBD light on.
Sounds like an electrical issue. You'll want to take it in.
Nov 04, 2012 | 2006 Chrysler 300
Tacoma power goes out when i hit brake
there is either a short in the switch or its grounding something out
Mar 16, 2012 | 1995 Toyota Tacoma
When a'm driving down the road it acts like the transmition won't to jump out of gear kinda vibrates you can let up on the gas it's is ok or you can give the gas and it's ok it's a automatic transmition.
Welcome to Fixya
Common indication of transmission problems happens when the transmission jumps out of gear while moving. Most noticeably, the linkage jumping problems will occur from the reverse position. Jumping out of gear indicates that the linkage holding the gears can be worn or broken. Often the gears will return to normal when the car is put back into first gear, but the transmission should be checked, because the slippage could be the beginning of serious problems that won't allow the gears to shift at all. Here's a link for you to diagnose transmission problems.
Thank you for using Fixya!
Apr 08, 2011 | Nissan Frontier Cars & Trucks
Gas gauge jumps past full mark by 1/2 inch when key is turned on, then drops back and jiggles while in park, when you put it in drive the jiggling stops.
fuel level sensor it will eventually set a check eng light. the unit is on top of the fuel pump assembly it is a little black sensor that can be changed by itself or if u wish a new pump assembly will fix it also.
Oct 24, 2009 | 1999 Chevrolet Suburban
Ran out of gas. put gas in car would not start. got car started with jump. ran a few minutes then stalled. tried jump again but did not start .
When you run a car out of gas,all the dirt and debris from the bottom of the tank is sucked into the lines,First replace the filter and flush the lines if needed.
Jul 21, 2009 | Hyundai Motor 1992 Elantra
Car is jerky and jumps
more than likely it's going to be ether the fuel pump or the fuel filter with the jumping it could be a couple of things i would need some more information to decide what that might be.
Jun 09, 2009 | 1991 Lincoln Town Car
Metra 70-1818  Crysler Dodge Jeep Amp Intgation Harness Logo
Top Metra Car Audio & Video Experts
xxxxxx xxx
Jason
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
