Question about Kodak Cameras
Step by Step on how to change setting's on a Kodak Easyshare Camera
Hello, I have noticed that when I take pictures my batteries die rather quickly, I can take a coulple of pictures and it dead. How do I change the setting's so I can take pictures tonight when My husband and I take our baby; Trick or Treating tonight, I really wanna be able too capture this first for all three of us. Step by Step please, Thank you so much!
    Genius:
  • Kodak Master
  • 1,019 Answers
You have not told us the model of the camera !!!! As far as the batteries failing that quick it is NOT a camera setting. I would suggest some higher quality batteries, Name Brand and Alkaline or better. If that does not solve your problem you have serious camera problems as no camera will kill good batteries in just a few photos.
Best Regards, Russell
Posted on Jan 24, 2013
jackboy
  • 2985 Answers
SOURCE: EasyShare camera lens is extended and will not retract, camera will not stay on either
There is not repair you can do The lens mechanism had failed Contact Kodak re your next move - repair or replace
Posted on Aug 03, 2007
SOURCE: The picture on my camera has lines going through it.
Tina, it sounds like you are having the same problem as everyone olse that own a t1. I had the same problem with the camera and then it just went blurry on me, the menu works and everything but you can't see the image, I'm trying to see if sony has a solution for this, because it's a really nice camera
Posted on Nov 19, 2008
SOURCE: Kodak Easyshare camera turns on and off
Hi, here is whats going on, if your M763 is powering on for 2 secs and the lense opens up then go's right back in, there is a 90% chance you got sand in the unit from say the beach ?
here is a test , when you press the power buttion watch the lense you will notice that the bigger part rotates as it comes out, what you want to do is give it a little help Lightly rotate it abit more just at the point where it normaly stops and go's back in, the cam will prob stay on and work like normal.
now the hard part 2 things to try, a can of AIR from walmarts try to blow out and sand thats around the rings, i did this and have fixed about 20 of these's now, on the others you will need to take it apart and clean the gears and mech of the lense housing then put it all back together.
hope this helps
IST tech
Chris
Posted on May 26, 2009
leepania
  • 1099 Answers
SOURCE: batteries in my kodak easyshare camera don't last
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Turn on your camera without the memory card.
In order to organise your repair or Trade up please Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Dec 09, 2009
  • 4090 Answers
SOURCE: Kodak Easyshare M883 overheats when battery & camera is off
There is a dead short somewhere within the battery holder, replaceing the battery will not fix it It will require intervention by a technician to uncover and fis the short circuit or bare wire. Check out the minimum repair cost and compare it to replacing with a newer model. It may well be throw away.
Please rate my help++++Thankis for using FIXYA
Posted on Apr 20, 2010
Kodak cx7430 battery won't hold a charge
Hello Sonja, Are you using good premium batteries, If they are old they may not retain a charge.
Dec 11, 2012 | Kodak EasyShare CX7430 Digital Camera
I accidentally put in the wrong language, I don't know how to get english back...thanks:)DeeDee
To change language or date/time in the future, yo should use the Setup menu,
  1. Setting up your camera
    • Attaching the strap
    • Loading the AA batteries
    • Turning on the camera
    • Setting the language and date/time
    • Storing pictures on an SD or SDHC Card
just in case if you need user manual in pdf format pls visit the link
below...
KODAK
EASYSHARE C195. Digital Camera.
Extended user guide
http://support.en.kodak.com/app/answers/detail/a_id/19314/selected/true
KODAK EASYSHARE C195 Digital Camera resources.kodak.com/support/pdf/en/manuals/.../C195_xUG_GLB_en.pdf
www.kodak.com .....
Aug 07, 2011 | Kodak C195 Digital Camera
Easyshare C182 12MP Digital Camera: how do i upload pictures from my kodak easyshare C...
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 16, 2010 | Kodak Easyshare C182 12MP Digital Camera
How do I delete photos from my internal memory
KODAK EASYSHARE Software is only compatible with KODAK EASYSHARE C-, CD-, CW-, CX-, DX-, LS-, M-, P-, V-, and Z-Series Digital Cameras; and DC4800 Digital Cameras. If you have one of these camera models, go to Step-by-Step Solutions and Repair tool to help resolve this problem.
If you have one of the other digital cameras, you cannot use KODAK EASYSHARE Software to transfer pictures to your computer. Use the software that came with your digital camera to transfer the pictures to the computer. When your pictures are on the computer, you can use EASYSHARE Software to edit, share, and print your pictures.
Mar 21, 2010 | Kodak EasyShare One Digital Camera
Problem downloading photos from camera to computor
KODAK EASYSHARE Software is only compatible with KODAK EASYSHARE C-, CD-, CW-, CX-, DX-, LS-, M-, P-, V-, and Z-Series Digital Cameras; and DC4800 Digital Cameras. If you have one of these camera models, go to the Step-by-Step Solutions and Repair tool to help resolve this problem.
If you have one of the other digital cameras, you cannot use KODAK EASYSHARE Software to transfer pictures to your computer. Use the software that came with your digital camera to transfer the pictures to the computer. When your pictures are on the computer, you can use EASYSHARE Software to edit, share, and print your pictures. Hope it helps you.
Mar 06, 2010 | Kodak EasyShare One Digital Camera
Batteries in my kodak easyshare camera don't last
Here are the steps:
Dec 08, 2009 | Kodak EasyShare Z812 IS Digital Camera
Kodak easy share z612 will not turn on to take a picture
When the battery dies, usually the camera will retract the lens if possible. If the battery is so dead the lens can not retract, I would recommend trying to charge or change the battery. Or try to turn the camera on, and then manually shutting it off if you can.
Nov 16, 2007 | Kodak EasyShare Z612 Digital Camera
Embedded date on photos
this camera has an internal clock battery, which must keep the date or any other related information while you changing the batteries, the problem is, since you camera is pretty old, the clock battery is probably long dead, it can be changed, but it will require disassembling and resoldering
Aug 19, 2007 | Kodak EasyShare CX4310 Digital Camera
Cameras Logo
26 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
