Question about Saniflo SANIPRO Macerating Pump
Sanipro xr noise - Saniflo SANIPRO Macerating Pump
5 Suggested Answers
jeff_drakesr
  • 155 Answers
SOURCE: sanipro xr massirato the problem is the pump is
You must remove the lid to gain access to the blades. Make sure you unplug the unit first. When reinstalling the lid place a little soap water around the gasket to help with the seal. thanks for using FIXYA. Jeff
Posted on Apr 07, 2010
  • 115 Answers
SOURCE: Sanipro xr is less than 6 months old been working
Water pressure makes the unit kick on and off. Somehow water is draining back into the pump casing, check the flapper on the check valve inside the discharge elbow, it may not be closing properly or may be obstructed allowing waste water to drain back into the pump. Also check the flapper on the flush valve inside the toilet tank (water closet) the flapper may be leaking water into the bowl and from the bowl into the pump casing sitting behind. As far as making a loud noise, there could be a blockage on the drain pipe, blade or impeller. The discharge pipe may be loose, not clamped against the wall and is rattling against the wall when in use.
Posted on Jan 11, 2011
  • 115 Answers
SOURCE: sanipro xr pumps for 15 mins then wont start up
Definitely there is a problem with the pressure chamber, it may need to be replaced. The pressure chamber is were all the electrical components are sitted and is what turns the unit on and off. You can always order parts throught Saniflo's technical dept. 800-571-8191
packrat1948
  • 528 Answers
SOURCE: i have a sanipro xr its not making the sound it
The pump in the lift chamber has quit working. Check the power to it and if that's not the problem then you will have to get into where the pump is to see if the float is hung up. I know it's a nasty job but someone has to do it.
Posted on Jan 30, 2011
I have a Sanipro,it sounds like it pumps real weak and goes off quickly instead of emptying out everything. then it will come on again after aseveral seconds . Could it be the Condenser on the motor?
  1. Saniflo & Saniplus&... Repair Questions - Fixya
    www.fixya.com/.../p1064016-saniflo_saniplus_macerator_pump_002 Saniflo & Saniplus& Macerator Pump - Recent Questions, Troubleshooting & Support ... My saniflo does not flush properly always leaves the toilet paper behind.
Jul 20, 2015 | Saniflo SANIPRO Macerating Pump
I have a 2008 Saturn Astra Xr its making a grinding noise what could it be if it's not the brakes or rotors.
It could be worn out constant velocity joints, if it is noisy only at slow speeds, and turning makes it happen too, get them checked asap.
Apr 28, 2015 | 2008 Saturn Astra XR
I have a sanipro xr its not making the sound it use to when i use to flush and the waste doesnt go down.
Jan 28, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
Sanipro xr is less than 6 months old been working fine but has recently become rather noisy. Sometimes goes off in the middle of the night for no reason.
Jan 08, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
Sanipro xr pumps for 15 mins then wont start up again have to turn the power off and back on for it to pump how do i fix it
Dec 30, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Sanipro xr massirato the problem is the pump is not pumping on makes a stuck sound, how do we clear out the massrator?.
Mar 11, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Engine noise
sounds like it could be 2 things. the valve tappets, meaning valves need adjusting and or loose cam chain which may need adjusting.
May 27, 2009 | 2004 Honda XR 125 L
Noise from gearbox near front sprocket.
Your bike may need the harmonic balancer chain adjusted. Th will notice is noise is very prominent at engine idle and low RPM's. When this chain get lose you will feel the vibration even in the handlebars if it is loose enough.
Dec 03, 2008 | 2005 Honda XR 650 R
Saniflo SANIPRO Macerating Pump Logo
Top Saniflo Plumbing Experts
jasbo
jasbo
Gil Shultz
Vernon Taylor
Are you a Saniflo Plumbing Expert? Answer questions, earn points and help others
