Question about Water Heaters
Need a wiring schematic - Water Heaters
  • Water Heaters Master
  • 5,245 Answers
Copy following link for tank-type electric water heater wiring:
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
For tankless electric:
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
For tankless gas, hybrid, combo, boiler, indirect, solar, heat pump, etc then re-post question with specific brand and model number for possible help
For switches, timers, lights etc:
http://waterheatertimer.org/How-to-wire-switches.html
Posted on Nov 01, 2012
Where can i get wireing diagram no tail lights 1999 Jeep Chrekee classic?
I would go to the Mfg. web site and try to download the wiring diagram. You will probably have to look them over good and make sure it is the correct wiring diagram because on most vehicles made today some have 5 or 6 wiring harnesses they use and you have to find the one that is installed on your vehicle.Vehicle wiring is a headache to say the least. I have run into the same problem and it was a different solution on each of them. I had a 2000 Ford Explorer that had a blue wire with a black stripe and only one end on it! I put a signal tracer on it and it went out when it went through the fire wall. I have used that signal tracer to trace a wire 500' on electrical jobs but the signal stopped at the fire wall. I can tell you this sometimes I would find that the power to the brake lights split off in a switch or the tail lights were powered from a completely different place than where the brake lights were so look elsewhere away from the brake lights for the power to the tail lights.
Col. Dana Gillespie
Aug 14, 2014 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
Honeywell ct87n wiring schematic
These are color codes wires for terminals that control fan relay,start,stop, temp-up/down ect. Also you can trace out those wires, Where they are going and what terminal on the wiring schematic they control.
Jun 27, 2014 | Honeywell Ct87n "the Round" Heat/cool...
Bosh rp12pt schematics
call bosch ----- they have what you need and maybe online for you
Mar 12, 2014 | Bosch RP12PT Powerstream Pro Point-Of-Use...
Wiring schematic for a upper thermostat
Jan 2013
1) Copy following links for wiring upper thermostat:
http://waterheatertimer.org/images/WH-w-combined2-1000.jpg
2) Thermostat must sit flat against tank wall to read correct temperature, and entire opening must be covered with insulation so cool room temperature will not interfere with temperature reading.
Be sure to put cover back on side of tank for electrical safety, and to prevent any possible fire caused by melted parts and overheating.
3) Tighten wires very tight under screw plate, and make sure only copper wire is used, and all wires under plate are same gauge, do not mix stranded wire and solid wire or stranded will become loose.
Only copper under the screw plate and cut back insulation so no insulation gets under screw plate.
http://waterheatertimer.org/images/Burned-thermostat5-143.jpg
4) Add comment and say what you are doing
Jan 23, 2013 | Rheem Water Heaters
Need to increase the recovery rate of Rheem 82SV30-2 elect water heater. Has 4500w upper and 3380w lower elements. Was told by County Health Dept that it was possible to wire both elements together for...
Basic information: Typical electric water heater operates in non-simultaneous fashion where either the upper element is ON, or the lower element is ON, or both elements are OFF, but both elements are never ON at same time.
Easiest way to increase recovery. If you have 10 gauge wire and 30 amp breaker, then install two 5500 watt elements. This will not work if you have smaller 12 gauge wire and 20 amp breaker.
Watt rating appears on side of each element.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Change wiring.
If you run two separate 10 gauge wires to water heater, with each wire on a separate 30 amp breaker, then you can 'wire both elements together' to operate in simultaneous fashion. The elements are each wired independently of each other, but they can both turn ON at same time, and this action avoids heating lag if you also install larger 5500 watt elements.
Simultaneous water heaters can be ordered from manufacturer, and this is common with 80 gallon models where tank must keep up with larger demand.
Copy following link for illustration showing how to rewire for simultaneous operation:
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html#simultaneous
http://waterheatertimer.org/Tempering-tank.html
Aug 14, 2012 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
Do you have a wiring schematic for a Rheemglas model 81V66DB ser # RH0500408476?
I can't identify that model number, and Rheem does not show that model:
Open following link to help identify water heater:
http://www.rheem.com/Products/tank_water_heaters/gas_water_heaters
Contact Rheem:
http://www.rheem.com/Contact.aspx
Oct 07, 2011 | Water Heaters
Titan-SCR2 N-120, water heater, need schematics
I have taken pictures and produced a wiring diagram for this model
Jan 23, 2009 | Water Heaters
Wiring a wh40 intermatic timer to a sears hot water heater
Shut off breaker to you water heater. STILL TEST FOR VOLTAGE BEFORE YOU TOUCH ANY WIRING. The 3 wire that go to you water heater disconnect them. You are going to install them to your WH 40 timer.
The wires that you disconnected will now go to terminals: Black to Terminal 1 & White To Terminal 3, The Ground copper wire will go to the ground terminal should be a green screw.
You will have to buy some 10/2 wiring to go from your timer to your water heater. You can buy it by the foot at Lowes. Figure how much you will need.
With the new 10/2 wire install the Black to terminal 2 & White To Terminal 4, the ground wire will go to the ground screw with the other ground wire.
Wiring that went to terminals 2 & 4 will be installed to you water heater, the same way when you disconnected them. Set your timer clock and your done. Turn breaker back on!
Dec 28, 2008 | Intermatic WH40 - Water Heater Time Switch...
Water Heaters Logo
83 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
