Question about Dimplex Compact Electric Flame Stove Heater
Fan works but no heat
Was in the garage where temperature reached -25 to -30 celcius. Fan still works but will not heat. Did the coils snap? due to the cold? Can they be replaced?
  • 65 Answers
Go to : www.dimplex.com or call: 1-800-668-6663 ext. 358 for custmer help
Posted on Jan 05, 2009
Samsung RB31F Fridge/Freezer - fridge temperature too high, freezer OK
1-The condenser coils are usually located under the refrigerator. They dissipate heat as refrigerant passes through them. If the condenser coils are dirty, they won't dissipate the heat effectively. As debris builds up on the coils, the refrigerator becomes less efficient, causing the refrigerator to work harder to cool down. If the coils are significantly dirty, the refrigerator will not be able to maintain the proper temperature. Check the condenser coils to determine if they are dirty-if the condenser coils are dirty, clean them.
2-The evaporator fan motor draws air over the evaporator (cooling) coils and circulates it throughout the refrigerator and freezer compartments. Some refrigerators have more than one evaporator fan motor. On refrigerators with only one evaporator, the evaporator is located in the freezer compartment. If the evaporator fan is not working, it will not circulate the cold air to the refrigerator compartment. If this occurs, the freezer may still get cold, while the refrigerator will not get cold. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor.
Oct 29, 2017 | Samsung Refrigerators
My Woods upright freezer MU07W running great for 9 years. Will it continue to run if I decide to place it outside on the balcony where temperature goes down to 20 below F or to max of 90 F plus?
Not the best idea. We had one in our garage where it got cold but not that awful cold. Not a good idea unless you want to take a chance.If the unit shuts down for a long time because of the cold the system could freeze or seize up.
Feb 05, 2017 | Woods Upright Freezer MU07W
Everything seems to be running but no air is coming through the vents
If the unit is on heating mode, the inside coil has to reach a predetermend temperature before the indoor fan will start. If the system is short of refrigerant the coil wont reach the temperature and subsequently the fan wont start
I hope this was of some help to you?
Good luck
Jun 09, 2015 | Heating & Cooling
Engineoverheats but still blows cold air
Your statement in it-selves solve the problem.
Your vehicle cooling system and air-conditioner system work independently.
Your vehicle cooling system is driven by the v-belt that turns the water-pump and circulates the coolant within the engine through the radiator and back into the engine and flow is controlled by a thermostat.
Your vehicle air-conditioning system operates from a v-belt that drives an air-conditioning pump which circulates coolant through a sealed system and generates cold air completely independently from the engine cooling system.
It seems that you need to repair the engine cooling system which has a fault and this fault could be
a) combustion seeping into cooling system (blown gasket),
b) cooling fan not operating (this fan engages at specific engine temperatures and suck cold air through the radiator in order to cool the engine coolant as it passes through radiator veins),
c) faulty cooling thermostat (thermostats work mechanically and through temperature expands and opens the water circulatory channel / opening, and in cold weather restricts this opening in order for coolant to allow engine to reach operating temperature and then allows the coolant to circulate freely),
d) engine combustion could be too hot due to fuel mixture discrepancies (too lean) thus overheating the internal combustion process which will overheat coolant,
e) engine cooling system leak causing the system not to seal thus restricting the pressurised coolant circulatory system (the system needs to be pressurised for effective circulation as well as raising the boiling point of coolant (under pressure water would boil at 110 degrees Celcius instead of 90 degrees Celcius).
Hope you find the problem soon as overheating is detremental to the engine and all integrate parts associated therewith.
Jun 04, 2014 | Air Conditioning and Heat for GMC Terrain
Comfort star
Make sure the indoor filters are clean. The outside unit will continue to run until the indoor reaches the temperature you have selected. Dirty filters can throw the temperature out. Its common for outdoor units to freeze up when on heating mode if the ambient air temperature is below 5 degrees Celcius.. The machine should however, defrost itself. There could be a problem with one of the pipe or air sensors on the outdoor unit.
Feb 23, 2014 | ComfortStar CHH012CD-13B Wall Mounted Mini...
We have two Lennox garage heater units that were installed about twenty years ago and one of the units is not working properly. We noticed that the fan comes on and off , sporadically even when the...
Check out the snap discs you have 2 high leval and low leval try jumping them out 1 at a time and see if it runs then , check heat exchanger is clean and not spilt , check burners are burning blue and if they need cleaning out ,
Jan 24, 2013 | Star Enerco Heat HSU45 Garage Heater 45000...
2002 chevy malibu heats up when running at low speeds
CHECK THE THERMOSTAT. THERMOSTAT IS THE ONE THAT SENSE THE ENGINE TEMPERATURE AND TURNS ON COOLING FAN WHEN THE ENGINE IS HOT.
Jan 19, 2012 | 2002 Chevrolet Malibu
I have the ED2FHEXNQ00 side by side. Is there a solution to the freezer not keeping food frozen when the unit is in garage where temps go below 30 degrees. Can I insulate behind it or put a thermal...
Insulating it might work and may be relative. The condenser is the place the where condensation takes place, where refrigerant gas turns back into liquid under pressure. Outside temperature plays an important role in the condensation of refrigerant and if it is too cold, of course, condensation may not take place normally. You need to reduce the flow of air through he condenser fins by disconnecting the condenser fan. Disconnecting the fan will cause a rise in temperature and presure in the condenser that may be conducive to better condensation providing the garage temperature is very cold; the cold air in the garage will be enough to keep the condenser from overheating.
On the other hand, you can install a simple temperature sensor on the condenser fins that can control l the fan. Fan would turn ON when condenser temperature is too hot and OFF when ambiant air around the condenser is too cold. The best temperature sensor is one with a sensing bulb and one that can be adjusted. With a little know how you can solve this issue. It will work if you use the right temperature controller. Remember that all you need to do is o connect the temperature controller on the condenser fan circuit. Provided that you know "Control" this should be easy. Get help if needed.
Dec 20, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge freezer kept in cold garage. Freezer works from time to time but fridge stopped work. Could it be a thermostat problem or due to temperature of garage?
The problem is with the garage temperature. The temperature sensor for the refrigerator is in the fridge compartment, but the evap coils are in the freezer. Refrigerators were designed to work in an air conditioned space. When they are put into unheated spaces, it does not work well. The fridge thermostat typically is set to 40 deg F. If the outside temperature is close to that, then it does not turn on the compressor as much so the freezer will have a hard time staying below freezing.
There are garage refrigerator kits for people who put fridges in un heated garages in the winter. They just simple electric heaters that warm the fridge's thermostat to cause the compressor to run more often. This helps the fridge to maintain temperatures better in the freezer compartment. The same thing can be accomplished by putting a small wattage bulb in the refrigerator compartment. Just remember to remove it during the warm weather otherwise you will pay a large electricity bill in the summer months.
Dec 09, 2010 | Smeg FAB46X Top Freezer Refrigerator
WHAT IS THE MAX TEMPERATURE THIS MODEL CAN SUSTAIN NN-CS599S LET SAY I WANT HEAT THE SUBSTANCE FOR 300 CELCIUS FOR 10 MINUTES..HOWEVER THE OWEN REACH THE SET TEMP AT FIRST 5 MINUTES....IS IT THE OVEN CONT...
I do not know of ANY microwave that will get you anywhere near 300 celcius, the cavity thermals are rated around 110.F and even the mag limit thermal of the comercial units are 300F No where near the celcius temps you are talkig about.
Sep 15, 2017 | Panasonic NN-SN657S Microwave Oven
Dimplex Compact Electric Flame Stove Heater Logo
188 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
David Burbee
David Burbee
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
