Question about Kenmore 3.5 cu. ft. Front Load Electric Washer
Hi! just picked-up a Kenmore Super Capacity 3.5 (front load), that has been in storage for 3yrs.the drum doesn't seem to work when machine is turned on.the belt is in very good condition.what can
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
Does it have the shipping bolts on it? Look on the back.
Posted on Nov 01, 2012
philbran
  • 242 Answers
SOURCE: laundry smells like mildew after washing
Front load washers retain water that you cant see or get to. There are cleaners for washing machines available. I clean mine every month with alot of bleach , try pouring a half gallon of bleach in the soap insert on a normal wash cycle and an extra rinse would not hurt no clothes of course.
Posted on Dec 30, 2008
  • 92 Answers
SOURCE: Our Kenmore 970-C40042 front loading washing
this sounds very much like the bushes have worn out on the motor,they cost about £10.00 to replace and easy to fit,hope this helps.
Posted on Jul 15, 2009
SOURCE: front loading washer won't spin
my amana washer wont spin and does not drain
Posted on Sep 12, 2009
  • 403 Answers
SOURCE: kenmore washer 3.5 super capacity. Machine spins
It sounds like your tub bearing is bad or going bad. It could be the adjustment on your spin cycle. Does your unit allow you to adjust this. Also are you overloading. Can you send me the brand and model of your unit and I help you more.
JimmyC
Posted on Oct 05, 2009
blueextc3221
  • 15935 Answers
SOURCE: washing machine suddenly stopped working during cycle
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 12, 2010
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Heavy duty super capacity plus
You dont. If it is making noise drum bearings or idler needs replaced
Nov 03, 2013 | Kenmore 24032\24036 Top Load Washer
My washer won't spin out at the end of the load
you should check the brushes on the motor they wear down which stops the motor spinning.you can ring a washing machine repair shop give them yr modal number and they can alder some new ones,this is what i did and my machine worked fine after that.
Mar 24, 2013 | Kenmore Washing Machines
Just picked-up a front load washer, & the whole drum won't turn when washer is turned on.the belt is in very good condition.the washer has been sitting in storage for 3yrs. what can i do to ma
My advice would be to to check out the website below.
http://applianceguru.com/category1/
this website will be invaluable to you if you want to repair your machine yourself. Calling an appliance repair service will be very expensive often resulting in buying a new unit do to the repair cost and labor charges if your appliance is fairly old. But at this site simply punch in your model number (they will even tell you how to find that) and a diagram will come up with all the parts for your machine.
The site will also help you troubleshoot your machine to determiine what parts you will need. You will then find videos to help you do the repairs. And the best thing of all is , if you order the part they are delivered FAST and if it turns out not to be the problem you can return the part for reimbursement. If you have ever had an appliance repair done and they installed a part that wasnt the problem you were stuckl paying for it and the next part they wuld think the problem was!.
Still having a problem then hit their forum and post a message explaining your symptoms and model ect and you will quickly have someone giving you advice on how to repair ect. Or simply type in your symptoms and search the forum and I will almost bet someone has already posted the same problem with your brand and and an answer will immediately be found.
Good Luck and don't let appliances intimidate you they are VERY simply machines once you realize how they work and how simple they are constructed.
Tim
Oct 31, 2012 | Kenmore 3.5 cu. ft. Front Load Electric...
Kenmore front loader washer powers on but lets no water in
If the door lock is engaging, then there could be a few things causing the problem. These things are as follows:
1) The water valve is bad - you can check this by seeing if when you turn the machine on if power, 115vac is being applied to it. If so the valve is bad, if not read forward.
2) There is a part called the pressure switch, it controls the amount of water that flows into the machine. Its connected to the drum by a 1/4" tubing. You'll need to check to make sure that nothing is obstructing the tube.
3) Take the bottom of the machine off, called the kick plate. Inside there is a tech sheet with diagnostic walk through's that will carry you the rest of the way
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 17, 2012 | Kenmore HE2 Plus 3.6 cu. ft. Super...
The water in my front-loaded kenmore-he washer is not draining and doesn't seem to spin very fast either.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 10, 2011 | Kenmore Front Load Washer
Kenmore 3.5 super capacity. will not go to spin
if the drive coupler is broken it won't wash or spin. Does it have a removable lower access panel on the front? if so its an amana. see if u can manually turn the transmission pully both directions. AND make sure there is nothing holding the tub ie nail through tub whole garment between tubs etc.
Jun 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Won't fill w/ water, Kenmore 3.5 Super Capacity Front Loader
The pressure switch is likely to blame. Change it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 28, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
WHAT IS THE LOAD CAPCITY SIZE OF WASHER MODEL 110.20702990
On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
Nov 22, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
78 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
