Question about Jenn-Air Microwave Ovens
Jenn air microwave makes zapping sound and won't heat food
Put a cup of coffee in microwave, yes it was a microwave safe cup :) I heard a zapping sound and when I pulled out my cup it was still ice cold
    Top Expert:
  • 14,553 Answers
Possible bad inverter board (power) and or the Magnetron which does the main heating.
Posted on Nov 01, 2012
MicrowaveSvc
  • 9098 Answers
SOURCE: JVM convection microwave
I see. Okay, well then I would expect there's a problem with a high voltage part, such as the diode, magnetron or transformer.
Your model number should be entered as JVM192002 and you can find exploded views here.
You can usually find GE parts for much less here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Posted on Aug 10, 2008
  • 5 Answers
SOURCE: Everything works...Except for actually heating the food
It has a bad magnetron. This is the tube that provides the microwaves to heat the food. Not too easy to replace yourself but it can be done. Cost of magnetron is probably less than $50 or $60.
Posted on Dec 14, 2007
  • 18 Answers
SOURCE: Microwave not heating food and is making loud noise.
You have burned out the magnatron (heating element) which is common on GE microwaves. most service companies will charge about 200-250 to replace it
Posted on Jan 31, 2009
localwonder
  • 6784 Answers
SOURCE: Microwave seems to be operating but does not heat food. Popping sound was heard just prior to this problem. Popping sound no longer heard but still does not heat food.
Replacing the Magnetron will fix this heating issue you are having with this microwave. The Magnetron is the device that is responsible for the heating action.
Posted on Jun 03, 2009
heatman101
  • 43501 Answers
SOURCE: Jenn Air Microwave M169W will run but not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
zcvzcv
Posted on Sep 30, 2010
Panasonic Dimension 4 Microwave- Model NN D801. Whilst microwaving for 2 mins on high - heard a zapping noise. Didnt heat food. Front operating panel works. turntable still works. Any suggestions?
A "zapping noise" usually indicates a problem in the high voltage circuit. If it's an inverter oven, it should have provided you with a fault code. If a non-inverter, the most likely causes are a shorted high voltage rectifier or bad magnetron. But there are many other possible causes.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Oct 02, 2016 | Panasonic Microwave Ovens
How do I make coffee with this
make up a normal cup of coffee without hot water
coffee in the microwavable cup+ water+ milk if needed
stir well
zap on high for 1.30 to two minutes
May 29, 2016 | Microwave Ovens
Kenmore Over the Range Microwave making buzzing sound and not heating
This is a strong indicator the magnetron is fried, also! this is the most expensive part to replace in the microwave oven, and in most cases cheaper to replace the whole unit.
Jul 18, 2012 | Microwave Ovens
The microwave looks like it is working but no matter what I do there is no heat. I put in a cup of coffee and hit the minute button. It turned on and goes around but the coffee is cold. So I tried...
HELLO.
Below is the solution on how to make our microwave heat food.
1 Remove oven racks and place them in soapy water to soak.
2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • Thanks.
    Sep 20, 2011 | Microwave Ovens
    Had a problem with voltage (edison) smelt something burning while micro-wave was in use. now the lite+time works but nothing else. jenn-air jmc813odds
    If you open the door of the microwave can you smell an odd odor? if yes the magnetron is probably fried "heats food" the other parts that need to be checked are the high voltage capacitor and diode. I recommend appliance repairman or tv technician to further check with an estimate.
    Jan 30, 2011 | Jenn-Air JMC8130DDS Microwave Oven
    I have jenn-air microwave oven model m167. Unit will come on and all programming works to heat food. Oven acts as if it is heating food,however it does not cook or heat food items. Any help with...
    It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
    Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
    Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
    Hope that helps.
    Dec 28, 2010 | Jenn-Air JMC7000 Microwave Oven
    My Jenn-Air microwave JMV8208AAS will not heat the food and when turn on it makes a loud humming sound.
    This is most likely the magnetron, the high voltage capacitor, or the power diode.
    For an explanation on how these things are repaired, check out this website.
    http://www.partselect.com/microwave+no-heat+repair.htm
    If all else fails, call an Appliance Repair Technician.
    Dec 09, 2010 | Jenn-Air JMV8208AAS Microwave Oven
    Heating the cup more than coffee
    make sure the stirrer motor located under the outer cover that distributes the microwaves is turning otherwise you will get hot and cold spots in the oven cavity
    Apr 30, 2010 | GE JVM1870 Microwave Oven
    Microwave Ovens Logo
    144 people viewed this question
    Top Jenn-Air Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
