Question about Noritz Plumbing
I have a modle n-069m it has a leaking heat exchanger i have repaired it two times. is this a common problem and is it cost affective to replace exchanger with new one
    Problem Solver:
  • 11 Answers
They leak like mad better of replaceing
Posted on Jan 22, 2013
Heater core leaking
Pretty big job but has to be replaced asap. The fumes/vapors from the heater core will eventually come though the registrars and make you sick and mentally affected. If the floor board is wet under carpet, inside front windshield has oily, hard to get off residue and/or sour bittersweet smell; it's already affecting you if you spend much time in the car. Headaches, blurred vision, anger, dark circles under eyes. The heater core going bad is a common thing for Lincoln Towncars. It will cost around $600 to have repaired and about 6 hours. Also FYI, intake manifold recall for repair has expired for most Towncars but it should be looked at for leaks. The factory installed plastic gasget warps.
Mar 30, 2014 | 1998 Lincoln Town Car
Leaking heat exchanger
balance chemicals in pool and replace heat exchange
Jan 08, 2013 | Teledyne Laars HEAT EXCHANGER ASSEMBLY,...
014 code
A 14 code means the thermal fuse (white wire which wraps around the heat exchanger) has snapped. This occurs if the heat exchanger reaches a dangerously high temperature. To correct this error code you need to replace the thermal fuse and keep the heat exchanger from over heating. Typical reasons the heat exchanger over heats are:
1) scaling in the heat exchanger
2) combustion chamber dirty and burning hot
Oct 07, 2010 | Noritz N-069M-DV, N-084M, and N-084M-DV...
What does a F12 error indicate on a Noritz system
F12 occurs on a multi-system or quick connect. It means one of the units on the system suffered a flame loss. More specifically, it means the flame rod stopped detecting flame on the burner. The most typical causes are as follows:
1) insufficient BTUS (low gas pressure)
2) leaking heat exchanger
3) clog in the manifold, burner, or heat exchanger
4) stuck flue damper or improperly sized venting
5) dirty flame rod
6) damaged circuit board or gas valve
Sep 28, 2010 | Noritz N-069M-DV, N-084M, and N-084M-DV...
Light blinking 3 times - no remote - won't come on
You have an error code. If you cut electricity to the unit and wait about 20 seconds before powering it back up, the unit will come back on again. There are serveral error codes associated with 3 blinks, I'd recommend instaling the remote controll to determine exactly which one it is (instructions are in the installation manual).
The most common error code associated with 3 blinks is a 16 code, which is typically related to scale formation in the heat exchanger. This error code can be fixed by performing a descale.
Feb 25, 2010 | Noritz N-069M-DV, N-084M, and N-084M-DV...
My Noritz N-084M has an error code. the red light on the front flashes 4 times
Check the remote control for the actual error code, but here are some of the more common codes associated with 4 flashes:
20 - high limit switch; typically caused by scale in heat exchanger: I recommend performing a descale
66 - water flow control valve abnormality; typcially caused by scale in the valve, again I recommend a descale
61 - fan motor abnormality; usually the fan won't run properly and requires replacement; however, it can also be caused by a low or inconsistent voltage supply
Sep 25, 2009 | Noritz N-069M-DV, N-084M, and N-084M-DV...
Noritz 069 error 11
error code 11 is an ignition problem. make sure your gas pipe is sized properly, if your on propane check your tank and make sure it's not low or when it's running take the cover off and look in the flame window and make sure it's an even flame if not you probably have a gas control valve problem
Aug 06, 2009 | Noritz N-069M-DV, N-084M, and N-084M-DV...
Leaking Noritz water heater.... I have a Noritz N-069m water heater. When i purchased the unit 3 years ago, i was told that if i installed a water softner unit it would void the warranty. A year and a half...
Check your water pressure and the diagnostic codes on the controller to see if there is computer failure or another problem with the unit. send me an e mail i might be able to help im a nortiz certified service tech scott@bridgeplumbing.net
Jul 27, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Ferroli DOM F24B Is leaking from the two 22mm pipes on the secondary heat exchanger
Yes, this is a common problem on the domi compact. unfortunately ferroli accept no responsibility if not in warranty period! can be a costly repair..
Apr 21, 2008 | Heating & Cooling
Plumbing Logo
79 people viewed this question
Top Noritz Plumbing Experts
Kyocera HP Expert
Paul Carew
Muzammil Razzaq
Muzammil Razzaq
Are you a Noritz Plumbing Expert? Answer questions, earn points and help others
