Question about Frigidaire Washing Machines
How do i know if my door latch is working or if its the wires attached to it from the control panel
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 01, 2012
I need help on removing door panel on 2000 Dodge Caravan - window fell in dorr and I can not seem to get the panel off. Any suggestions?
Answer
FRONT DOOR TRIM PANEL
REMOVAL
Using a trim stick (available from parts stores), pry courtesy lamp from door trim.
Disconnect wire connector from courtesy lamp.
If equipped, remove screws attaching door assist handle to inner door panel.
If equipped, remove screw attaching door pull cup to inner door panel.
If equipped, remove screws attaching trim panel to door from below map pocket.
If equipped, remove window crank.
Using a trim stick, remove screw cover from switch panel.
Remove screws attaching switch panel to door trim.
Remove power accessary switch from door trim Front Door Switch Panel
Disconnect power switch from wire connector.
If equipped, using a small, flat bladed pry tool, remove memory seat/mirror switch and disconnect wire connector Memory Seat/Mirror Switch
If equipped, remove screw holding door trim to door panel from behind inside latch release handle.
Disengage clips attaching door trim to door frame around perimeter of panel Front Door Trim Panel
Lift trim panel upward to disengage flange from inner belt molding at top of door.
Tilt top of trim panel away from door to gain access to latch linkage.
Disengage clip attaching linkage rod to inside latch release handle Inside Door Handle Linkage
Separate linkage rod from latch handle.
Remove front door trim panel from vehicle.
INSTALLATION
Hold top of trim panel away from door to gain access to latch linkage.
Place linkage rod in position on latch handle.
Engage clip to hold linkage rod to inside latch release handle.
Place front door trim panel in position on door.
Install trim panel into inner belt molding at top of door.
Install clips to attach door trim to door frame around perimeter of panel.
If equipped, install screw to attach door trim to door panel behind inside latch release handle.
If equipped, connect power switch into wire connector.
Place power accessary switch in position on door trim.
Connect wire connector into memory seat/mirror switch and install switch into trim panel.
Install screws to attach accessary switch panel to door trim.
Install screw cover into switch panel.
If equipped, install window crank.
If equipped, install screws to attach trim panel to door inside map pocket.
If equipped, install screw to attach door pull cup to inner door panel.
If equipped, install screws to attach door assist handle to inner door panel.
Connect wire connector into courtesy lamp.
Install lamp in door trim.
Feb 02, 2012 | 2000 Dodge Caravan
I moved the latch for my jtp15 ge oven and now it won't open. What do i do to move the latch back over?
The latches on this model oven have a very high failure rate. Once the latch fails it is permanent. To open the door you have to access the control panel to reach the door look. To do this first turn the power to the oven off at the service panel by turning the breaker off.
  • Step 1 Remove the three screws from the control panel. The control panel is on the outside of the oven, above the door handle. Pull the bottom of the control panel toward you, then lift it up. This action will release the control panel cover's tabs.
  • Step 2 The mechanism that operates the door latch during the self-cleaning cycle will be behind a smooth, square plate held in place with two screws. White, black and red wires, as well as a grounding wire, will be protruding from the face of the plate. These wires will be twisted together with other control panel wiring and covered with electrical wire caps.
  • Step 3 Remove the failed part by removing the caps and untwisting the wires. Using an appropriate wrench, extract any screws holding the plate in place. The cylindrical-shaped mechanism will be attached to and behind this plate.
  • Step 4 Visit a store or contact GE at (800) 626-2224 to acquire a replacement part. To reassemble, slide the new mechanism into where the old one was and reattach the plate with the screws. Reconnect the wires by twisting them together and replacing the electrical wire caps.
  • Step 5 Replace the control panel by slipping the top of the panel into its groove and angling the panel downward, dropping the tabs back into the slots. Replace the three screws.
  • Aug 14, 2010 | GE JTP15 Electric Single Oven
    How do i remove the driver's inside panel door? My electric button panel for windows and locks isn't moving.
    Like reference guide, check this procedure to Removal & Installation / Door Lock Motor...
    The door lock motor is integral with the door latch. If the door lock motor is found to be defective, the entire door latch must be replaced.
    1. Before servicing the vehicle, refer to the Precautions Section.
    2. Roll the door glass down.
    3. Disengage the 2 clips attaching the speaker grille to the door trim panel. (They are at the front of the grille, one near the top, and the other one at the bottom).
    4. Remove the 3 large washer-headed screws surrounding the speaker.
      Fig. Fastener location for the door lower trim panel
    5. Remove the access cover at the front of the door trim panel. Remove by prying at its rear edge.
    6. Remove the red courtesy reflector from the lower tail of door. Disengage by prying at the screwdriver notch at the bottom of the reflector.
    7. Remove the flag trim panel from the door by prying it off at the 2 attachment clip points.
    8. Remove the 7 screws attaching the door trim panel to door:
      1. One screw is located at the lower rear screw pocket.
      2. Three screws are located along the bottom of the door.
      3. One screw is located inside the handle opening.
      4. One screw is located at the upper front.
      5. One screw is in the pull cup.
    9. Disengage the 2 hidden clips attaching the rear of the trim panel; pry them off at the 2 attachment clip points.
    10. Lift the trim panel upward and away from the door, disengage the trim panel from the upper retainer channel.
    11. Disengage the clip attaching the latch linkage to back door handle.
    12. Disconnect the electrical connectors as necessary, including the lower foot light, if equipped.
    13. Remove the door trim panel from the door.
    14. Remove the water shield (water dam) from the inside of the door.
      Fig. Remove the flag trim panel, door trim access cover, inside remote handle, and power door lock switch
    15. Raise the door glass.
    16. Remove the bolt and nut for the rear glass run channel and position the channel aside.
    17. Disconnect the lock rod from the lock button bellcrank.
    18. Disengage the lock and latch rods from the clips on the inner door panel.
    19. Disconnect the lock and latch rods from the outside door handle and the key cylinder at the door latch.
    20. Disconnect the wire connector from the power door lock motor.
    21. Remove the screws attaching the door latch to the door end frame.
    22. Remove the door latch and the power door lock motor from the vehicle.
      Fig. Expanded view of the door lock, latch, and linkage
      Fig. View of the door lock button, latch rod, lock rod, and door latch
    Hope helps (remember rated this).
    Jun 26, 2010 | 2000 Chrysler Sebring
    Machine light turns on, cycle light blinks, door is closed but the door lock light doesn't come on and washer won't start. Code shows f dl?
    The door lock and switch assembly has failed. You may actually hear it click several times before the code appears. If not, it may not be receiving power or signal from the central control unit to activate.
    Disconnect power to the washer to avoid electric shock.
    Remove the three screws from the rear of the top panel attaching it to the cabinet then slide the panel rearward, and then lift it off the cabinet.
    Disconnect the third and the fourth from right, facing the front of the washer, wiring harness connectors from the central control unit. Clean the connector terminals thoroughly then reseat it several times to ensure a good connection between them. Do the same with the connector second from the top on the left side of the central control unit.
    After ensuring that the connectors are properly connected, slide the top panel back in place, and then secure it the three attaching screws.
    The next thing to do is visually check the door lock and switch assembly for physical damage.
    Remove the wire and spring assembly that holds the door gasket to the lip of the door opening. Use a pair of needle-nose pliers to stretch the retaining spring then remove it together with the wire.
    Gently peel the part of the door gasket near the door lock/latch assembly off the lip of the right side of the door opening. Remove enough of the door gasket to access the door lock/latch assembly behind the front panel.
    Remove the three screws securing the door lock/latch assembly to the front panel and slightly lift it then pull it back off the front panel.
    Pull the door lock/latch assembly out of the washer and disconnect the wiring harness. Clean the terminals and reseat it several times.
    To replace the door lock and switch assembly (part #8182634); connect the wires properly then secure the assembly into position behind the front panel with the three securing screws.
    Put the eased part of the door gasket back in place over the lip of the door opening.
    Check that the door gasket is properly seated before securing it with the retaining wire and spring around the lip of the door opening and the door gasket.
    Mar 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Removing/installing 2000 dodge grand caravan window glass
    after u remove the bolts that hold it to the window regulator tip the window towards the front of the door and the top rear corner of the window should pop out and then u just lift hte window out,hope this helps
    Sep 05, 2009 | 2004 Dodge Caravan
    ELECTRIC DOOR LOCKS ONLY LOCK SOME TIMES
    if you hit the lock button a couple times, will it finally lock?
    If so, then you will need to take door cover off and lube up the connectors as they probably got corroded.
    Aug 14, 2009 | 2000 Ford F350 Super Duty Super Cab
    Rear door on driver side won't open,have taken the panel off the inside of car,seems like the lock won,t travelas far as it does on the other door.is there any way to open this door,thanks[1997 lincoln...
    Rear
    Removal
    1. Using a small screwdriver, remove the screw cover from the armrest of rear door trim panel (27406).
    1. Remove the two retaining screws.
    1. Using Trim Pad Removing Tool from Rotunda Windshield and Moulding/Trim Removal Kit 107-R0401 or equivalent, pry rear door trim panel from door inner panel.
    1. Disconnect electrical connectors.
    Installation
    1. Position rear door trim panel on door inner panel, aligning two locators on rear door trim panel. Reverse Removal procedure.
    ------------------------------------------------------------------------------------ Rear
    Removal
    1. Remove door trim panel and watershield. Refer to Section 01-05 .
    1. Check all connections of remote control links and cables. Service as necessary.
    1. Remove remote control assembly.
    1. Remove door latch remote control assembly from latch assembly.
    1. Drill out rivet at bellcrank and link (264B14).
    1. Remove three screws attaching latch assembly to door.
    1. Drill out rivet that attaches actuator motor to door.
    1. Remove latch assembly with actuator motor and door latch control rod lever link assembly.
    Installation
    1. Install new bushings and clip onto latch assembly.
    1. Install latch with links and power lock actuator into door cavity.
    1. Position latch assembly to door, aligning screw holes in latch and door. Install three screws. Tighten to 10-13 Nm (89-115 lb-in).
    1. Attach door latch actuator motor to door with a new rivet.
    1. Install bellcrank and link to door using a new rivet.
    1. Install inside door handle and remote control assembly to door.
    1. Open and close door to check latch assembly operation.
    1. Install watershield and door trim panel. Refer to Section 01-05 .
    Item Part Number Description 1 221A00 Door Handle to Door Latch Actuating Cable 2 26446 Rear Door Control Rod Retainer 3 377901 Plug Button 4 26412 Rear Door Latch 5 W623451-S2 Push Nut 6 224A32 Counter Balance 7 22450 Door Outside Handle Tension Spring 8 W701210-S309 Screw 9 224A20 Outside Door Handle Anti Rattle Pivot (2 Req'd) 10 22404 Door Handle 11 224A24 Front Door Outside Handle Spacer (2 Req'd) 12 264A64 Rear Door Actuating Rod 13 22408 Outside Door Handle Anti-Rattle Bumper 14 22428 Outside Door Handle Large Pad 15 N621906-S2 Nut (2 Req'd) 16 N807329 Screw (3 Req'd) 17 26595 Rear Door Electric Latch Actuator (RH) 18 W701566-S47 Rivet 19 431C04-A Rear Door Latch Striker Assembly 20 — Door Lock Striker Plate (Part of Door Shell Assy) 21 W525172-S Rivet (2 Req'd) 22 264B14 Bellcrank and Link (RH) 23 264A50 Bushing 24 N802034-SG Rivet 25 26420 Rear Door Latch Control Rod Link 26 W525172-S Rivet (2 Req'd) 27 21818 RR Door Latch (Inside) 28 A26460 RR Door Latch Push Button Rod 29 21982 Door Latch Rear Striker Assembly 30 N808377-S101 Screw (2 Req'd) 31 250A04 Rear Door Catch 32 N801010-S100 Truss Head Bolt (2 Req'd) 33 N804234-S2 Screw 34 266A74 Rear Door Latch Actuator Retainer 35 24630 Rear Door 36 26552 Rear Door Latch Control Escutcheon A — Tighten to 21-29 Nm (16-21 Lb-Ft) B — Tighten to 10-13 Nm (89-115 Lb-In) C — Tighten to 7-8 Nm (62-70 Lb-In) D — Tighten to 26-34 Nm (20-25 Lb-Ft) E — Tighten to 3-4 Nm (27-35 Lb-In)
    Mar 24, 2009 | 1997 Lincoln Continental
    Manual window won't roll up
    so is the right rear door ??
    if so here are some instructions.
    1. If applicable, remove the regulator handle by pulling the clip out with a wire hook.
    2. Remove the inside door handle and disconnect the latch rod.
    3. Remove the screws and detach the clips attaching the door panel (see trim pad remover.
    4. Disconnect the power window and courtesy light harnesses.
    5. Remove the door panel bracket and carefully remove the plastic cover
    6. Remove the screw attaching the door lock crank. Disconnect the latch rod from the latch side.
    if you have an email address i can send some images on how to do it.
    hope this helps
    Jun 07, 2008 | 1991 Honda Accord
    WIndows don't work and I need to open up the door cover!
    First try running the window switch to fully lower the window. Yeah, I know it's already down, but the regulator uses a push/pull cable that has detached from its connection to the window mount. It "pulls" the window up and "pushes" the window down. When detached from the window mount of the regulator, the window motor doesn't know when to quit turning, and so the cable has run all the way through the motor, certainly further than it should be run. If you're lucky, the end of the cable (the end that should normally be attached to the window attachment platform) is still at the motor and can re-mesh with the gears of the motor and allow the motor to pull it back in. When my regulator broke, the cable ran back into the far recesses of the door and tried to seek new paths. I suspect yours has run too far and "found" the latch/lock mechanism and jammed it. By "lowering the window" from the switch, the motor will hopefully pull the cable back out of the places it does not belong.
    If that doesn't work to get your door open, you obviously cannot remove the inner door panel with the door shut. So find a used door (same year, model and door position) with the the same color interior at a junkyard. After purchasing the new inner door panel and the two door lock and latch push/pull rods (horizontal), you can cut away your existing panel knowing you have replacement parts on standby. BE CAREFUL NOT TO CUT THROUGH THE WINDOW and LOCK CONTROL ELECTRICAL WIRES! Start the cut across the sill, then pull away as you cut downward so you can see the wires. The predominant possibilities, in this case, are that the regulator cable is still jammed in the latch/lock mechanisms or that the glass rattled out of its track and jammed the latch/lock control rods or broken the plastic levers to which they are attached.
    I imagine this advise is too late for you, but it may help someone else. Good luck!
    -James
    Jun 07, 2008 | 2005 Jeep Liberty
    Door latch
    The latch is fairly simple to replace. There are several screws around the inside of the door that hold the inside panel in place. You then will be able to slide the panel out of the way (it is attached by wires).
    You will then be able to access the latch it is not attached by any screws, but there is a wire harness on each side of the latch. There are two clips that you need to hold out of the way and slide the black harnesses off the two pins on the latch.
    Then simply replace the latch and close up the door and your problem is fixed.
    Dec 26, 2007 | Maytag 24 in. MDB6600A Jetclean II...
    Washing Machines Logo
    14 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
