I have a toshiba laptop, and in the last few weeks something weird started happening. When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries, and the battery level drops by about 1% every few hours, but it never turns off, meaning it is recieving power from the AC. But the LED displays show nothing lit except the power icon and HDD icon. The AC, and Full/Charging battery lights do not seem to light up at all. Now my battery has completely died, and i decided to just run the laptop on AC power and remove the battery pack. When i shut down last night and tried to turn on this morning it gives me the low battery indicator (flashing yellow light) even though the laptop is plugged into the AC. I got a fully charged battery pack and plugged it into the laptop and still it gives me the same low battery indication and will not turn on. This is very frustrating and I would greatly appreciate some advice on how to fix this problem ASAP.
    Sergeant:
  • 366 Answers
Change your AC charger.
It's NOT charging "When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries, and the battery level drops by about 1% every few hours"
That's the reason why: "battery has completely died"
If you do not change it you'll continue to "still it gives me the same low battery indication and will not turn on. "
Posted on Jan 04, 2009
Power wont turn on..battery led flash orange
Remove battery. Maybe faulty? Try another cord/charger with the EXACT same specs. Reseat the Memory Mods. has the AC jack been damaged by pulling on the cord? Try plug in and at the laptop's AC jack "wiggle" the AC jack plug. Any change?
Jan 04, 2013 | Toshiba Satellite U305-S2804 Laptop
My toshiba satellite laptop won't turn on. If I hold down the power button sometimes it will turn on for a few seconds, but then shuts off. About a week before this it would shut off without warning when...
I might just be the battery.
Look at your AC adapter and see if the light on it comes on when plugged in. If so then that should be good.
I could also be a dead battery that will not accept a charge. Replacing the battery could fix it.
If it happens again after the new battery discharges then it could be the connection on your motherboard is not charging the battery.
Apr 19, 2010 | Computers & Internet
My daughters Toshiba satellite l505d will not boot up correctly. It starts but then nothing happens. What do I need to do. Have already taken battery out and restarted. Any help would be helpful.
Try the following.
1. Remove battery and plug in the AC Adapter and check if it works
If yes - Battery is defective
If no - Motherboard Problem/AC adapter
2. Check the AC adapter LED indicator if its lighted or not(double check by a multitester)
If lighted - it works properly
if not - replace
3. Try to reinstall WINDOWS operating system by the use of the installer CD
4. Reformat your computer and install necessary drivers and applications
Thanks. Cheers!
Apr 15, 2010 | Toshiba Satellite L505-S5966 Notebook
I Have a Toshiba satelite laptop. It has a week battery. It can't be swithed on when the battery has been removed so that it should be using AC power. But when I put in the battery and plug the pc to the...
you have a bad plug on the end of the power supply a loose jack on the computer or a bad power supply you need to test the power supply with a volt meter to see if it is putting out any power if it is you have a bad connector on the pc or an intermittent connection on the power plug end. get a new battery before you blow something up. it is not good for the power supply to run the compputer all the time. it will shorten the life.
Jul 18, 2009 | Battery Technology Computers & Internet
Toshiba satilite P100...wont turn of
Try these:
1. Can you plug something else besides your laptop into the outlet...verify you have power?
2. Is there a light on your AC adapter...when you plug it in?
3. Try removing your battery and plugging it in, and verify that your AC adapter is working (somehow, if it has no indicator light)
4. Then unplug it, put the battery back in and see if it will start.
Let us know what happens after you try these.
Apr 12, 2009 | Toshiba Satellite P100 Notebook
Same Weird Problem,
Is the laptop display a windows or black out
Black out?
Please stop the laptop by pressing the power button until it stop.
remove the battery
remove the memory and then after 15 minute insert back the memory and install the battery.
If the system display windows, and the problem is always start when plugging the ac power. maybe the battery of the laptop is damage.
Please try go to bios setup and then at the power option, find the restore the "last state" something like that and the set it to "off: option.
Feb 03, 2008 | Acer Aspire 3680 Laptop
Power
Try this:
With the AC adapter and battery installed and it will not power up remove the adapter and the battery. Then plug in the
AC adapter after both have been removed for 30 seconds and let the laptop set for 30 seconds and then unplug the AC adapter and then slide in the batter within 15 seconds and try to start the laptop.
Nov 24, 2007 | Compaq Presario 900 /1500 Series EVO...
Help
sounds like you have an intermittent problem with your AC adaptor or dc input jack. Does the light on the AC adaptor light up when you plug it in? If it does then your dc input jack may be faulty. If the light on the ac adaptor does not light then replace the ac adaptor. Good Luck!
Sep 16, 2007 | Toshiba Satellite M30-S350 Notebook
Computers & Internet Logo
441 people viewed this question
David Payne
David Payne
