Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore Side by Side Ice Dispenser Not Working
I thought the Auger Motor was ad because it will not come on when you depress the the ice dispenser on the Door,but I took the tray out and ran a jumper wire from the light wire (white) and jumped it too the motor and the motor spins over fine. It appears the switch that activates the motor in the door is bad or something, i cannot find where it is actuated. any suggestions??????
  • 1 more comment
  • cemmusic Jan 04, 2009
    motor won't turn. how do you get to the motor?
  • carpenter474 Jan 30, 2009
    Our electric has been out for two days. I had emptied the freezer of my Kenmore Elite side by side and after the electric came back on the ice compartment refilled quickly. When I push the button to dispense crushed or cubed ice it does nothing, not even a sound. My water dispenser is fine. I emptied the bucket and everything turns freely manually.
  • Anonymous Mar 31, 2014
    There is no auger motor sound. Ice is being produced but not dispensed from the door
My GE DSS25KGRB side-by-side refrigerator had a problem where the ice dispenser motor would not turn. I had noticed this intermittently in the past, and this time it happened after the power came back on after being off for several hours. I removed the ice-cube bucket, and tried to turn the auger motor shaft ¼ turn manually, as advised in my instruction booklet for how to refit the bucket. Since it wouldn’t turn I guessed (correctly) that ice had gotten into the motor and froze it.
I removed the ice dispensor motor assembly (outer four hex screws), disconnected the two cables as I went, and removed the assembly from the fridge. I then disconnected the two motor wires, removed the clear-rubber boot that covered the motor, and let it defrost and dry out for 20 minutes or so, partially assisted with a hair dryer. Then I could turn the motor shaft.
Before reassembling it, I noticed what appeared to be a GE engineering error. Only two of the three attaching screws on the motor fit into the three clear-rubber grommets that were attached to the rubber boot. It looked like mismatched parts. This prevented the boot from covering the motor tightly, which probably contributed to moisture getting in. So after letting it dry for another hour or so, I put it back together, and sealed the gaps between the boot and the metal housing by applying some "100% silicon sealant, indoor/outdoor, for windows and doors".
I’ll really know whether this is a permanent fix if it survives a few freeze-thaw cycles. But it works again for now, and I don’t want my ice-cream to melt.
Posted on Feb 07, 2009
I have a Kenmore 106.56163500 that the ice dispenser is not working. I have replaced the ice auger motor. When you depress the ice door lever nothing happens. What next?
The new augur motor is not being energized. Check the circuitry that feeds it power and you will find the source of the issue.
Mar 16, 2017 | Kenmore Refrigerators
Kenmore cold spot refrigerator model # 106.56662500 ice is not dispensing through the door. How do I fix it?
This is common in these units. When the dispenser lever is depressed, an auger motor rotates the auger wire. When the auger rotates, it pushes the ice toward the dispenser door and chute. When the auger is defective, it isnt able to push the ice out of the dispenser. You need to check the auger to determine if it is broken or disconnected from the auger motor. If the auger is broken, replace it.
Jan 28, 2017 | Kenmore Refrigerators
The ice maker will not dispense any ice. When the dispenser lever on front panel is pushed the dispenser door opens but the auger motor does not operate. If I thaw the freezer the auger motor will...
It sounds like your auger motor has an issue in my opinion. How i check them is: remove ice bin, open freezer door, hold door switch down, depress the freezer ice dispenser button on the door and see if the auger motor has the torque when it turns, if the motor has power and turns but cant turn w/ torque or has power and dosen't turn. you need a new auger motor. lmk if u need more help!
Aug 04, 2013 | Frigidaire FPUS2686LF Professional 26 Cu....
Kenmore model number 253.55693400 when I push the ice dispenser tab the motor to push ice is on, but not pushing ice out.
You have an auger type of ice dispenser, so when you say you hear the motor is on, do you mean it is turning the auger? Take out the ice bin and close the door, push the dispense button and then open the door quickly to see if the auger is turning. If is is then dump your ice bin and let it sit out until it is completely defrosted and dry. Reinstall the ice bin and put the lever down. And see if that will clear the problem. The auger motor is not that strong and if you get any ice build up under the auger it will stop working. So defrosting and drying will normally clear it up.
Oct 02, 2011 | Kenmore Side by Side Refrigerator
I have a Kenmore side by side, not sure the model, but it's probably 10 years old or so. It has an ice maker with water, cube and crushed ice dispenser. The ice maker works fine, but it will not dispense...
Most of the time the bin has been removed and not put back in properly. When this happens ice blocks the drive motor. Remove the bin and turn the auger by hand make sure it will turn and is not jammed. Now with the bin out push the light button in that turns the light out and have someone push the button for ice while the door is still open the motor should turn in the back make sure thereis no ice blocking it. If it turns nothing is wrong with the motor. The clicking sound is usually the motor jammed by ice or the auger not engaged on the motor. hope this helps good luck
Aug 15, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Whirlpool side by side GD27DQXFW01; ice cubes are not dispensing
We will need to check the voltage at the auger motor while depressing the dispense switch. If all the other features work on the dispenser panel while I would consider checking the voltage going to the motor. Some auger motors are in areas where water causes the voltage to be shorted by constant moisture. We will need to remove the panel and simulate what you have done on the outside but this time we need to see if the voltage has been altered or if the auger motor itself is defective. Sea Breeze
Oct 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Door Ice Dispenser Not Working
mine froze up in the shute, had to put water down iti
Aug 26, 2009 | Whirlpool GS6SHAXLS Side by Side...
Ice dispenser not working - GE side by side refrigerator
Check auger motor if getting power then probably motor gone , if
not may be switch. good luck
Nov 09, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice dispenser
Hi Wilday1, Sounds like you have a possible defrost malfunction. In this case the Ice maker motor may have become iced and cannot turn the auger. Tell me if you have frost buildup at the back of the frezer and ice crystals on the auger drive. If you do , then you need to remove the Ice makers motor and allow it to thaw and defrost itself. be sure it is completely dry before putting it back in. I hope this helps.
Oct 08, 2007 | Kenmore 25.4 cu. ft. Side-By-Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
1,128 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
