Question about Oster Kitchen Appliances - Others
How do you remove the lid for cleaning as it is advertised?
  • Susan Sheldon Nov 03, 2012
    This was not a trick question trying to fool your "experts". The box the bread machine came in said that the lid was removeable for easy cleaning, but it doesn't say how to remove it in the instructions. Is this just false advertising by Oster or are their other "experts" out there? thanx
    Master:
  • 661 Answers
If you look closely you will see that one hinge has a slit in it and the other doesn\'t . Open the lid and gently edge it forward until the hinge comes free through the slot and do the same in reverse after you clean it.
Posted on Jan 23, 2014
Krups gx6000 grinder advertises removable burr grinders and there are no instructions, but is that the best way to clean them?
the Krups instruction manual is useless in this matter but if you do have some mechanical insight this is not very hard. You will need some tools, e.g. an Allen wrench to remove the housing lid.
Anyway, you should not have to clean the grinders very often, perhaps once a year is enough. It depends on the quality of the coffee beans you use; the more 'oily' beans the more frequent cleaning is required.
I would not use water to clean it, rather a small stiff brush (e.g. an old tooth brush), but if that is not enough, water will have to be used.
If so, be sure to assemble the grinder only after the burr is completely dry.
Check the link to Home Barista where a very similar grinder is shown, that should give you an idea about what to expect during the cleaning process.
Good luck;
Villi
Home Barista com
Jan 19, 2015 | Krups Gx600050 Conical Burr Grinder Black
Need to remove lid
If you have the kind of lid that has the slots on the back this video will help
Dec 10, 2013 | Zojirushi Kitchen Appliances - Others
My 2005 F-250 is reading water in fuel. Where is the valve to remove the water?
You can locate the horizontal fuel-conditioning module (HFCM) mounted to the frame rail underneath the driver's seat. Place a drain pan under the HFCM. Turn the fuel drain lever outwards and let the HFCM drain into the pan until clean fuel is observed coming from the module, then close the drain lever.
I have heard of people having to do this 2 or 3 times over the course of a week to get the light to remain off.
It may be a good idea to replace the filter element while you are in there as follows:
  1. Remove the fuel-filter lid from the HFCM with an adjustable wrench turned in a counterclockwise direction. Place the lid aside. Pull the old fuel filter from the HFCM and clean the filter mating surfaces with a clean rag.
  2. Insert a new filter element into the HFMC until it is fully seated. Remove the old "O" ring gasket from the fuel-filter lid and discard it. Stretch a new "O" ring gasket (included with a new fuel filter) over the lid and work it into the groove. Lubricate the gasket with clean diesel fuel applied with your finger. Tighten the cap in a clockwise direction onto the HFCM with an adjustable wrench. Remove the drain pan from under the vehicle.
  3. Open the hood and remove the fuel-filter housing lid on top of the engine with an adjustable wrench turned in a counterclockwise direction. Lift the old fuel-filter element from the housing and clean the filter mating surfaces with a clean rag.
  4. Push a new filter element into the housing until it is fully seated. Replace the "O" ring gasket on the lid in the same fashion as the HFCM fuel-filter lid and lubricate with diesel fuel. Screw the lid back on and tighten with an adjustable wrench. Close the hood.
Where safety goggles and gloves and good luck.
Jan 01, 2011 | 2005 Ford F 250 Super Duty
How do I remove the top of the washer to replace the lid switch on a 110 23832100?
Disconnect power then release the console from the top of the cabinet. Pull or pry off the end caps then remove the screw that secures the console to the cabinet top. Once the screws are removed, pull forward and up on the console and lay it back on the hinges.
Disconnect the lid switch harness connector by pressing on the tab located in the middle and pulling it up.
The cabinet is attached to the rear of the washer by two brass-colored retaining clips. Insert a flat blade screwdriver into the turned-up edge of the clip, located on both sides, and then pry back to release the clip from the slot in the cabinet.
Open and hold the lid while grabbing the cabinet front opening then tilt the top of the cabinet toward you by pulling the cabinet away from the base. This releases the front and back slots of the cabinet from the tabs in the front and back of the base.
Using the side of your leg and/or body as a support for the front of the cabinet, carefully lift up the cabinet and lay the front on a cushioned floor to access the lid switch.
Remove the lid switch ground and mounting screws then release the wire harness from the metal retainers. Pull the lid switch connector out and install the new lid switch in reverse order of the removal steps.
Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine.
Reconnect the lid switch harness then push the retaining clips back down into position to secure the cabinet to the rear of the machine. Reinstall and secure the console to complete the repair.
Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
Comment:
major_appliances;subcat=washing_machines;brand=kenmore;product=kenmore_22422_top_load_washer;ptype=thread;make=kenmore;solution=1;channel=0197193999;sz=650x250%2c2x2;tile=3;ord=634994898287111? Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
Comment:
Dec 30, 2010 | Kenmore Washing Machines
Need to remove top of scanner microtek scan wizard 5 to clean underside of glass
Follow these steps to clean the scanner :
Open up your scanner's lid. It does not matter if the scanner is on or off for this basic, regular cleaning.
Wipe down the glass surface with a dry, lint-free microfiber cloth. This will remove any dust or other fine particles that have accumulated on the scanner. You should remove excess dust every day or two.
Scan a blank sheet of white paper into your computer and look for visible discoloration. A white sheet will provide a clean, blank slate to view the scanner's overall quality. If you notice any irregularities on the white sheet, you need to do more thorough, semi-regular cleaning.
Semi-Regular Cleaning
Turn off the scanner and open up the lid.
Spray a small amount of "mild glass cleaner" on a soft, clean cloth as recommended by Scanner-Magic.com.
Wipe the scanner's glass to thoroughly clean the area. You should perform this semi-regular cleaning at least every two weeks or sooner if a white sheet of paper indicates discoloration.
Keep the scanner's lid open for a few minutes until all excess glass cleaner has dried.
Nov 26, 2010 | Microtek ScanMaker 5800 Flatbed Scanner
Can remove breadman pro lid
You might have figured out how to do this by now, but here's the answer anyway.
There are two slots that the lid's hinge pins slide into.  To remove the lid for cleaning or otherwise, tilt the lid at a 45-degree angle and pull it towards the front of the machine.  To put the lid back, simply reverse these directions.  CAUTION: Make sure that the hinge pins are completely inserted into their respective slots before carefully lowering the lid.  Not doing so could bend them or break them off and would ruin the lid.
Feb 14, 2009 | Breadman TR875 Bread Maker
C'PROGRAM ~1\MYWEBS~1\1.bin\M3PLUGIN.DLL
That file belongs to the My Websearch toolbar, which is malware. If you have
recently cleaned up your computer to remove malware, then a reference was
left in Startup. See below for how to manage your Startup. If you have
*not* recently cleaned up your computer, you need to do so. See below for
general malware removal steps.
You need to run a scan for malware search web for FREE program to do this make sure its the full program that will scan and DELETE malware not just scan
Or go to start/find/type in the dll name when found right clicck it and delete it
Aug 05, 2008 | Intel Motherboard
How do I remove lid for cleaning
With lid in open position just pull it straight up and off.
Feb 12, 2008 | Rival CF153-WM Deep Fryer
Not sucking up dirty water
The F5914 has a lid that must be engaged with the tank in order for the suction to reach the floor. Gently lift the front of the lid on the tank and if it lifts up, you haven't engaged the two tabs on the tank into the lid. Remove the lid and make sure the tabs on the tank fit into the grooves on the lid and snap it closed. This should solve your problem. Also, make sure that the removable duct in the front of the tank is in place. It is removed when the hose is used, but must be replaced when the machine is used on the carpet.
Feb 01, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Bosch dishwasher
your not supposed to be using tablets in the bosch dishwasher. the ball on the tablet gets the lid stuck. the sticker on the door recomending tablet is advertisment. your owners manual says to use powder only
Nov 18, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Kitchen Appliances - Others Logo
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
