Bravia KDL-40EX655 STANDBY indicator flashes 8 times.
Hello My Bravia KDL-40EX655 is not renewing the program (PKG1.504EUA). Downloaded files are starting to updating and stuck. PIC OFF / TIMER indicator slowly flashing 4-5 times. Then turns the STANDBY indicator flashes 8 times. Pause abaut 30s and wire flashes 8 times. Just would like to know what it means this Blinking Code (8 time). Tv model is KDL-40EX655BAEP. Turn on the TV, it slows down, will not open the menu, guide, sen... disappears sound. automatically reboots. Please update but not updated. I tried with usb and internet (Wifi). I do not know what to do. I'm sorry for my english language, it is imperfect. Renatas
Benimur
  • 6966 Answers
SOURCE: Sony KDL-40S20L1 Flashing Standby Led, No pic, No Sound
Hi, If all else fails, try do a hard reset. You can verify from your manual, but in some units, this is merely unplugging the unit from mains for a couple of hours. Try again, if it still shows error codes (blinking lights) you probably have to seek the services of a qualified professional. Hope this be of some help/idea. Good luck and kind regards.
Posted on Aug 26, 2007
redhead7377
  • 51 Answers
SOURCE: Four blinking red lights.
you can have the inverter board replaced...instead of the entire panel.
KDL 40S2010: inverter part # 178950032, you will also need 2 spacers..part # 289765511
you're looking @ 200-300$ for the inverter and 5-10$ a piece for the spacers.
KDL-46V2500: inverter part # A1251295B
you're looking @ around 500-600 $ for the part
Posted on Sep 09, 2008
mistersony
  • 320 Answers
Either on of the backlight inverter boards is bad or a backlight has failed inside the panel.
Posted on Oct 18, 2008
  • 4234 Answers
SOURCE: Sony Bravia KDL-40W4500 turns off
This can indicate a problem with the high voltage circuits. Since this is a new set, it should still be under warranty. DO NOT open up the unit as that will void the warranty. Return the set or request warranty service. Note the 8 blinks when you request service as that should allow them to bring the correct replacement parts.
Keep us posted.
Dan
Posted on Jan 05, 2009
waynejamescm
  • 67 Answers
SOURCE: tv bravia kdl 40v3000 problem turning on
Unfortunately, this is a failure of the balancer board for the backlight. The unfortunate part is that the balancer is not available by itself anymore, and the whole panel must be replaced, as Sony only has the balancers attached to new panels. You can contact Sony directly to ask for assistance, and it usually helps.
Hope this helps you...
The standby indicator is flashing 4 times on my sony bravia KDL55nx720 tv and will not start. Is there something that needs to be reset?
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.Viewing it in "Mosaic" or "Sidebar" will make surf easy.
Blinking codes details to many popular brand TVs are given.Surf the site with patience.
Aug 09, 2014 | Sony BRAVIA KDL-55NX720 55" 3D LED-LCD TV...
Sony bravia 22EX320 reboots and blink 8 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 19, 2014 | Sony BRAVIA KDL-22EX310 22" LED TV...
Hi I have a Sony Bravia KLV-40S200A which wont turn on. The standby button flashes five times then pauses for about 4 seconds then flashes again. Any ideas?
Diagnostic Test Indicators
When an error occurs, the POWER LED will flash a set number of times to indicate the possible cause of the problem. If there is more than one error, the LED will identify the first of the problem areas. If the errors occur simultaneously, the one that corresponds to the fewest flashes is identified first.
LED ERROR DESCRIPTION CODE
1 Supply Voltage Trouble Panel 5V UNReg (10.5V)
2 DE5V Voltage Trouble FE5V (DCALERT2)
3 Voltage Trouble D3.3V/D2.5V/D1.8V. (DCALERT1)
4 Backlight Trouble
5 Main Supply Voltage Trouble (17.5V.DET)
6 Speaker Applied Voltage Trouble
7 Monitor an Increase in Inside-Temperature (esp. on the panel side)
8 Trident IC Trouble
Apr 18, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony Bravia 46" The standby light flashes four
If tv model number is KDL-46S2000 then 4 times blinking standby light indicates back light failure problem in your tv.
Check/ replace back light inverter boards to solve its problem.
Thanks.
Dec 29, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
KDL-40XBR3 turns itself off; STANDBY light flashes 9 times
sony 52 inch tv in stand by mode comes on and off on its own
Jun 01, 2009 | Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
13 red standby flashing lights -- turns on, then turns off
Are you sure about the 13 flashes. Error code only goes to 8 flashes.
Apr 25, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Keep us posted.
Dan
Jan 05, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Have a new Sony Bravia KDL-40W500 keeps turning off into standby mode with 8 flashes.
There is some confusion on the model (KDL-40W500 vs. KDL-40V2500), so I will direct this toward the 40V2500.
On the KDL-40V2500, an 8X blink means the scan processer has gone bad, and the BU board needs to be replaced. If the problem is intermittent, the the AU board might be the problem, but if it all the time, bank on the BU.
A competent repair shop should be able to help you, or you can try calling Sony directly for assitance.
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
Electro Med Services...
