Question about Kenmore Dryers
Motor hums doesn't start
Are there any replaceable parts on this motor (like brushes), or do you have to replace the entire motor? The motor will run if you spin it by hand. But won't start on its own.
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 01, 2012
  • 958 Answers
SOURCE: Dryer hums and won't work
can you remove the belt and run it/..look at the motor if it is spinning. let me know. normally, if it hums, its the motor which is not starting, when you replaced the motor, im sure it has its own centrifugal switch and starting capacitor. did you replaced the starting capacitor?..it could be open.
Posted on Mar 28, 2008
  • 686 Answers
SOURCE: drum not turning
no brushes in those motors you need new one or different dryer
Posted on Mar 12, 2009
  • 2122 Answers
SOURCE: Heatman - you comments are
it could be the extra weight on the motor and the motor is bad,try this,open the door,push the door switch in with one hand and spin the drum with the other hand and have someone push the start button,if it runs and most of the time it does because you're helping it along you need a new motor.one more thing,if the filter is in front,remove the duct that the lint filter slides into and spin the drum,if the blower wheel moves with the drum you have a bad motor,if it doesn't you have something stuck in the blower wheel and it jams up the motor because it's attached to the motor shaft.
Posted on Jun 10, 2011
Testimonial: "Salde386 is the man. Helped me out and confirmed, clearly, what my issue was. Having an easy to talk to expert, reduce my frustration."
heatman101
  • 43501 Answers
SOURCE: I've got a 4 yr
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jul 04, 2011
canwoodjc
  • 3301 Answers
SOURCE: My Kenmore 110.66962501 dryer doesn't start.
if your sure the thermal fuse is good,, check the start switch,, making sure the dryer select setting is set to something other than off, also, the door switch . you can Jumper both these switches, I'd try the door switch first as they go out more often . if you have a meter and want to test the switch Some door switches have only two metal prongs extending from the body, while others have three. Those with three terminals will have a common (COM) terminal, a normally closed (N.C.) terminal, and a normally open (N.O.) terminal. Those switches with only two terminals will have either a common terminal and a normally open terminal, or a common terminal and a normally closed terminal. We are providing directions for testing a door switch with three terminals. If you are dealing with a door switch that has only two terminals, ignore the part of this test that does not apply to you.Use your ohmmeter to test your switch for continuity. Begin by setting your ohmmeter to measure resistance at a scale of R x 1. If yours is a two-wire switch, touch each tester probe to each of the switch's terminals. You should receive a reading of infinity. While the probes are still touching the switch's terminals, press in on and hold the switch. The reading should change to zero.
Posted on Jul 20, 2011
Electric log splitter motor hums but won't run
suggest you get information on repairing log splitter, not dryer. have the same problem, and no replacement parts available. must be in the electrical, easiest would be capacitor, less the motor itself, take apart and see if windings burned, or smell electrical
Oct 13, 2012 | Dryers
Have a whirlpool washer that now hums when I turn the cycle on, no water just a hum
I had a similar problem - had to get a technician out - there was a valve at the back of the machine that allows the machine to fill. It had split (apparently its a common problem? there are separate valves for hot and cold water, so I'm not sure if using a different cycle choice (ie cold only), may let the machine fill?). 10 minute fix job
Jul 14, 2012 | Whirlpool Washing Machines
Band saw motor won't start just hums
You will need to take the motor out and check the brushes on the back also check the bearings you may need to disassemble the motor to repair.
Apr 05, 2012 | Craftsman 12 Tilt Head Band Saw Owner...
D28770 dewalt does not turn the blade. Light works and switch works but not even a hum from the motor.
Check the brushes, if they are worn down to where they are not making good contact with the armature, the motor won't work.
If the brushes are OK you may have to have the armature tested to make sure it doesn't have a short in it.
Mar 05, 2012 | Dewalt Saws
Washer won't run just makes humming sound
hi the fault may be down to the brushes on the motor
regards
shaun
Nov 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Makes a humming noise but doesn't turn
Try this, open the dryer door and hold down the door light switch. Turn on the dryer and press start.When you hear the motor humming, turn the drum clockwise with your hand to see if it will turn. If itruns, you have a bad motor and will need to be replaced. If it doesn't turn, something is jammedinside and you will need to disassemble the unit to find the jam.
Hope this helps.
Oct 31, 2011 | LG DLE2514 Electric Dryer
My motor brushes at end of life for a Black and Decker electric leaf blower. Where can I get them? Black and Decker leaf hog, model BV400 type 4, Cinderson 90510850 motor. Black and Decker site no help...
Try Platt Electrical supply - 800-257-5288 (Platt.com) BLACK & DECKER #89754-01 REPLACEMENT BRUSH. It seems the entire motor head was manufactured by DeWalt and is now obsolete. I don't know if these brushes will fit, but someone there may help.
Good Luck!
Aug 31, 2011 | Black & Decker Leaf Hog 12-AMP Electric...
I must have gotten a pit stuck however when I feel in there there's nothing left n there. There's power to it because it hums but it doesn't chop. Any suggestions.
Put a wood broomstick down in the opening, or use allen wrench on bottom of motor, and see if you can free up the cutter disk.
You want the disk to rotate freely.
The use vacuum cleaner hose to make sure all the small stuff is removed.
If the disk rotates freely, but the motor will not start, and the motor just hums, then motor winding has gone bad, and motor is overheating each time it hums. Replace disposal.
I wrote ez disposal replacement steps from when I worked apartment maintenance.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Jul 06, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Dryers Logo
46 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
