How can I recover my
Flashed biose with wrong one. Now I get the caps lock light flasese blue series one flash. I have a lihht on the sd reader, power light and wifi. The drives seem as if they get no power. How can I recover
  • 27,725 Answers
Flashing a motherboard's BIOS can have many positive purposes and can help keep a motherboard compatible with changing technology.
PCnineoneone.com says that a proper BIOS flash can introduce enhanced features and bug fixes for the motherboard.
However, a bad BIOS flash can be devastating to a computer owner and very difficult to recover from.
If the proper preparations are made and all instructions are followed, a bad BIOS flash can be corrected.
Remove the side panel of the computer case, using the screwdriver to unfasten the screws normally located in the back.
Remove the jumper from its normal position on the motherboard and place it in the recovery position.
Usually, the jumper will need to be moved over one space to cover a previously exposed prong.
Locate the BIOS CMOS jumper on the motherboard, usually in the bottom, right corner.
The jumper consists of three metal pins facing upward and is usually marked with "CLR_CMOS" and has a plastic cap over two of the pins.
Check your specific motherboard manual if you are unsure where the jumper is.
If the motherboard does not have a jumper, removing the battery for 30 seconds and then replacing it may have the same effect.
Insert the BIOS flash disk and power on the computer.
If you used a flash tool or utility and did not create a BIOS flash disk before flashing the BIOS, then you will need to do so using a functioning computer.
Since there will be no video, listen for the internal PC speaker to beep.
This means it is performing the BIOS upgrade.
Power down the computer once the BIOS upgrade has been completed.
This process may take some time to complete, so be sure to not turn the computer off before the BIOS upgrade is finished.
Without video, the only way to be sure is to listen to the PC speaker.
When the upgrade is done, the PC speaker will beep again, and the floppy disk drive will turn off.
Replace the jumper back in its normal position and put the side panel of the computer back on.
Power the computer on.
If the computer turns on as normal, the recovery was a success.
or
How to Recover My Laptop BIOS
The BIOS is the basic input/output system on your computer that normally runs invisibly in the background, yet it's required for your computer to perform even the simplest task.
When something goes wrong with the BIOS, you might have difficulty even booting your computer.
There are a number of things you can do to recover a laptop BIOS that has gone wrong, ranging from relatively simple to somewhat costly.
Recover your BIOS by restoring the manufacturer settings as the first line of defense.
Reboot your laptop, reading the on-screen startup messages to determine what key you have to press on to enter the BIOS (normally "Esc" or "F2").
Press on the key when required to avoid booting into the main operating system, going instead to the BIOS screen.
Locate the item named "restore default settings" or "restore manufacturer settings"
(or something along those lines) within the BIOS.
Select this option using the arrow keys and pressing on enter, confirming when requested by pressing on the "Y" key.
This restores all of your old BIOS settings, potentially recovering your laptop BIOS with a minimum of fuss.
Send your computer back to the manufacturer or to an authorized dealer if restoring the factory default settings doesn't work.
The technician removes the old, faulty BIOS chip, replacing it with a new chip if possible.
It may also be a problem with the battery connected to the BIOS, which is always removable.
In many cases if the BIOS itself is the problem, the entire motherboard must be replaced since the BIOS chip is rarely removable in a laptop.
Hope this helps
Posted on Nov 01, 2012
cpenzes
  • 1102 Answers
SOURCE: Won't boot
was there any changes done to your system like upgrading anything
All your power seems to be on right
Posted on Jan 19, 2009
steveparlin
  • 61 Answers
SOURCE: Dell e1505 no start, flashing lights.
The symptoms you've described point to a failure in the system board. You can try to remove the ram memory and reinsert them to see if this solves your error. If the error persists then most likely the failure is the motherboard itself.
Posted on Sep 01, 2009
Testimonial: "Thanks, Yeah, that's what I was expecting, dell was of little help because the thing is some years old."
  • 5 Answers
SOURCE: the caps lock and scroll lock light flash and
probably the CPU was broken.
Posted on Nov 30, 2009
Jubert
  • 249 Answers
SOURCE: Dell Inspiron 1520- Blank screen, Caps Lock flashes 45 times...
If it does not even post or show the DELL Logo then this may already be a hardware failure. The best thing to do is to contact Dell Tech Support. Specially if you still have warranty. It could already be a couple of things ranging from the memory to the motherboard itself.
Posted on Apr 29, 2010
puku_07
  • 60 Answers
SOURCE: My Laptop: Fujitsu LifeBook A Series, A6110 is
Contact Your Dealer or
If you are able to repair your notebook so try cleaning RAM.
It may solve your problem
Posted on Jun 29, 2010
Unit powered off. I unplugged for 10 secs, replugged in. Unit powered on numerous lights flashed in sequence and went out. Power light was last light on. It flashed several times then went out.
It's trying to tell you something. Look up the series of flashes in your manual and see what it's trying to tell you. If you don't have a manual, go to the manufacturer's web site and see if you can download one.
May 06, 2011 | Office Equipment & Supplies
I have a Eos Digital and was trying to view my photos on the computer by using my USB and was only able to access and view half of the photos b/c a message corrupted files flashed on. Please Help. I want...
If the files themselves are actually corrupted, there is not a way to fix them-- if instead there was some sort of error with the transfer of information between the camera and computer, then this is something that you can troubleshoot.
Your best bet would be to remove the SD card from the camera, (this is accessible from the door on the bottom of the camera) and use a regular SD card reader (something you can pick up at your local camera shop, or even at Walmart) to view the files on the card. This removes the camera from the equation, in the event that there is something wrong with it.
If you attempt to transfer the files when using just a regular SD card reader, and the transfer fails or your computer indicates that the files are corrupted, then you may need to resort to either a professional data recovery service (which may be offered by a local camera shop), or you may just not be able to recover the files in their entirety.
Mar 04, 2011 | Canon Powershot SD450 / IXUS 55 Digital...
My dell inspirion 1525's screen is black numerical lock light is onblue,the cap lock blue light is flashing,the download lock light is on blue as well
Hi Friend, In this case if the caps lock is flashing blue and the other 2 LED's are solid blue, this is an indication that there is something wrong with the memory (RAM) itself.
So I would recommend you to please reseat the memory card of the system. I am also sending you the link that will assist you in reseating the memory
http://support.dell.com/support/edocs/systems/ins1525/en/SM/memory.htm#wp1180987
Please reseat the memories. Please let me know if it is of any help.
Dec 11, 2010 | Dell Inspiron 1525 Notebook
My loptop D610 turn on ,caps lock blinks and ater 3 to4 secons it
I would try clearing the cmos battery. It's located under a small door under the laptop battery. Unhook the wire (laptop unplugged) and let it sit for 20 minutes. Hook it back up and try to power up. If that doesn't work www.pcrepairhelp.net has techs that work on laptops.
May 04, 2010 | Dell Latitude D600 Notebook
Blue light flashed on the power swich
Check this site regarding monitors and capacitors. This is very likely a capacitor failure.
Apr 19, 2010 | Computers & Internet
Pls, after flashing my compaq nx 6320 laptop, the screen cant come on. its beeps once and thats all.
1 beep usually indicates that the System, is ok and past The Bios Tests. i,d suggest that you may have flashed the incorrect bios. or it has not updated thoroughly. or corrupt.
there a couple of possible solutions, one is to reflash with the original bios. secondly maybe to obtain the vga/graphics chip drivers onto a cd, and boot the laptop up with the disk in the drive.
A system restore Disk, may be the Only Other option.
Mike @ Compurepair.
Oct 28, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Fuel gauge lights keep flashing mercedes benz s320 car has gas
psi diff inside tank is wrong.
use a OEM fuel cap to make light go off.
make sure it clicks at least 3 times.
Oct 10, 2009 | 1997 Mercedes-Benz Mercedes Benz S Class...
Problem with Sony Grand Wega TV
This could be due to bad capacitors in the sweep supply, a bad High Voltage block, a bad regulator.
Jul 06, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
