Question about Acer Aspire T160-US321H (AST160-U-S321H) PC Desktop
Computer does not send out a signal to tthe monitor and does not power the keyboard
This is following me stupidly unplugging everything from th motherboard; the power button is reconnected, as is the HDD to the serial port of the motherboard, but there is the card reader wire and 2 white wires that i do not know the placements of.
  • 380 Answers
You should try to locate a manual for that system and see about re-routing the wires. If you are wired correctly you should be able to boot. if not, you may have damaged the board.
Posted on Dec 04, 2014
3 Suggested Answers
  • 94 Answers
SOURCE: Problem for Acer Aspire M1641- PC Desktop
It is not the monitor that is your problem. Your monitor is fine, it is a software problem with your CPU/Computer. You need to put your operating cd in the cd tray, boot computer in this order...cd rom first, then hard drive, etc. Your operating sysytem is corupt/missing some files, it won't boot up thru the hard drive, because it can't, it need to boot from the cd, where the files are that it needs.
Posted on Jun 28, 2010
Testimonial: "ok thanks for ur adviced..."
SOURCE: Problem with my Acer Aspire m1100 E1402A.PC came
This problem is related to incompatibility between RAM memory. For that make sure all RAM has same frequency and same company. Always different frequency of RAM creates this problem. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Nov 06, 2010
Monitor will not boot up is reading no input signal
So either the computer isn't generating a video signal, the cable isn't carrying the signal to the monitor, or else the monitor isn't capable of receiving a video signal.To test this, first try a video cable that you know is good, in case your cable is bad, If it works with the other cable, the problem was your original video cable. If it still doesn't work, put your original cable back, and hook another computer up to the monitor. If the monitor makes the same message, the problem is with the monitor. If the other computer works when connected to this monitor, your problem was that the original computer isn't booting (which could be due to several reasons I will list below), or the video adapter is broken.Possible reasons for the computer not booting: bad power supply, bad power button, bad hard drive, bad memory, bad motherboard component. If you determine that it isn't booting, unplug everything except the keyboard mouse monitor and power cord, to see if that makes a difference. If it boots after that, something you unplugged was causing the problem, plug them each back in one by one, rebooting in between, and when it stops booting properly, the last thing you plugged in is causing the problem.
Mar 02, 2012 | Acer Computers & Internet
Acer x136w monitor, no signal. Connected parralel conector to back of computer. no signal..tried everything I know to do. Even stupidly pirchased driver whiz. nothing. ready to through monitor into th e...
No signal message on your LCD monitor screen means that your monitor is not receiving any signal from your PC graphic card. This problem "no signal" have nothing to do with the drivers installations. Have you check whether your graphic card is faulty or your cable connection properly connected/secured? ie VGA (D-sub). As far as I know there are no parallel connectors for PC Monitor connectors only, VGA(D-sub), DVI or HDMI cable interface.
Try to connect your monitor to another PC, just to test whether the LCD monitor is functional.
Hope it helps.
Mar 19, 2011 | Computers & Internet
My computer beeps and doesnt send a signal to the monitor or keyboard. When it does send signal it says entering power save mode on monitor. what do i do to get it to boot?
Sounds like you may have a bad memory module. If you have more then 1 memory module installed in the computer try removing one at a time to see if one is shorting your computer. Make sure the power is OFF when removing memory.
Jan 26, 2011 | Dell Inspiron 518 Desktop Computer
Monitor on power save mode and using wireless keyboard and mouse
This sounds like the monitor is not reading a signal from the computer. I had the same problem when I installed a DIV cable from my old VGA cable. The video card was still sending the signal via VGA port instead of the DVI port of my video card. You should cheack the cable to you're computer and what port is being used. If everything is hooked up correctly then there might be a problem with the cable. Other then that it could be you're video card. If the hard drive is running and everything is running fine then what I said should be whats wrong. If nothing works go back to the shope and tell them the new problem you have.
Sep 10, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Syncmaster 941bw coming up blank
Hummm. Try to unplug everything, reconnect, than restart. If not working, try to plug your monitor on a different computer to diagnose what is wrong, the computer or monitor. It could also be your graphic adapter, verify that it is firmly attached to the motherboard.
Lastly, replace the defective part.
Mar 27, 2009 | Samsung 941BW LCD Monitor
No power but ON button flashing
Quickest fix for this is probably to temporarily unplug the monitor power cord.
For your other outages, I assume the monitor is connected to a computer, make sure the operating system power-save features have not disabled the video output signal from the computer ... if so, monitor should re-activate when you use the mouse or hit a key on the keyboard.
If your computer has two video outputs, make sure the primary display hasn't been shifted to the other one ... try it by moving the LCD data cable to the other video connector on the computer.
Dec 26, 2008 | Westinghouse LCM-19v1 Monitor
Emachines monitor has no signal
* First u can remove the display cable from cpu ( system ) .
1. Power LED coming or not .
2. Self cheak display or plain raster is comming or not. , both r ok ,
3. then u can cheak the display cable. & system.
4. 14 th pin is horizontel signal , 15 th is vertical signal , cheak the continuty the both wires.this signals is most importent for display.
Oct 20, 2008 | Computers & Internet
Sleep mode
Does the monitor go to sleep when you unplug the video cable? If so, then the computer is still sending a signal, if not, check the monitor menu settings for no signal settings.
Apr 25, 2008 | ViewSonic VX2435wm (Silver, Black) Monitor
Acer Aspire T160-US321H (AST160-U-S321H) PC Desktop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
