Question about Toyotomi Heating & Cooling
I HAVE TOYOTOMI TIN-320 I WANT A CONTROL FOR THIS
Toyo aircon
"Contact the factory it looks like they sell parts.
The phone number is 203-775-1909
There is a link to parts towards the bottom of the page
http://www.toyotomiusa.com/products/PortableAirConditioners.ph
Jun 10, 2013 | Toyotomi TIN/TIG-329D Air Conditioner
My Toyotomi TAD-30F 'tank full' light keeps coming on despite my emptying the tank daily.
Check and see if the light is activated by a float switch. If it is it may be sticking. Your owners manual may have a clue.
Jul 11, 2012 | Toyotomi TAD-30F Portable Air Conditioner
I have a summer house and would like to heat the house in winter while I'm away to keep the humidity out. The problem is there is often breackdown of electricity. What must I do@
Hello,If unoccupied during the winter so what,Assuming the house water is off & drained.#1 get a generator for the house with auto demand start.#2 install a millivolt steam heat system (makes it's own electricty to operate)#3 the burgular alarm system can have tempature alert added so you get a phone call if the house gets too cold.Just an idea.
Oct 15, 2010 | Toyotomi TIN/TIG-329D Air Conditioner
Heatcool toyo ta-09chs
hi friend,
go to website
www.retrevo.com/samples/Toyotomi-manuals.html
i think this may solve ur problem
thank u for using fixya
regards,
sivaranjini
Aug 05, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
I have a Toyo Aircon TA 12C(H)S air conditioner that shows E3 on the readout and nothing will come on. Any ideas what the error codes mean?
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. E3 means low pressure of refrigerant. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck to you!
Jul 03, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Toyo airco is not working
well need to check if the condenser is turning on that the part outside. if not you can check fuse next to the unite or the breaker
Jun 26, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Toyo Aircon. Starts perfectly. Runs for approx 5 min and then the yellow "timer" light starts flashing and machine stops working. Green power light on...yellow timer light flashing. When you switch unit...
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck!
Dec 28, 2008 | Toyotomi TIN/TIG-329D Air Conditioner
Heating & Cooling Logo
115 people viewed this question
Top Toyotomi Heating & Cooling Experts
hmca
Level 1 Expert
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Toyotomi Heating and Cooling Expert? Answer questions, earn points and help others
