Question about JVC RX-5020VBK Receiver
Some speakers have no sound coming out, and sub woofer wont work
When i put my JVC RX 5020 on all channel stereo, only 3 out of 4 speakers have sound coming out of them, and also accidental the sub woofer got unplugged and when i try to hook it back up it wouldn't turn on?
  • kelli-grey Feb 10, 2009
    Can't get sub woofer or center channel detected even when answer yes to settings. Using s video and digital audio from Dish DVR.
simplemitch
  • 752 Answers
SOURCE: Whenever I turn receiver on, it turns off almost immediately
The amplifier blew out (probably shorted and damaged when wire was loose, and gave out under load). It won't be cheap to repair....
Posted on Sep 13, 2007
SOURCE: jvc rx 318
did you find a manual? I have this stereo and the manual if you need some help.
Posted on May 06, 2008
  • 1348 Answers
SOURCE: JVC Receiver RX-6040B turns it self off after 10 seconds
the amplifier is seeing a short,or the internal components like one of the output ic are causing dc to show at the speaker terminals.the speaker protect is causing it to shut down.
Posted on May 14, 2009
mbnataraj
  • 84 Answers
SOURCE: everything appears normal but no sound, tried
Hi
Is there a mute switch on the system which has been activated?
Posted on Jul 08, 2009
  • 336 Answers
SOURCE: JVC RX-6042 Sub out not working, swaped sub cable
Check the setting on the receiver. Sub on and front speakers need to be set to small.
Posted on Nov 29, 2009
Ouku litb 100-7 no sound from speakers.. only sub woofer works. .... any idea?
check the output type from the menu, check whether its surround channeled, stereo channeled, or placed working in the mono sub woofer mode.
Mar 19, 2015 | Audio Players & Recorders
How to connect a jvc Rx 516v amplifier to a four terminal sub woffer
Connect both speaker outputs from you amplifier to the left and right inputs on your sub woofer. Connect your normal speakers to these connections on the sub woofer.
Mar 04, 2015 | JVC Audio Players & Recorders
How do you make the 6.1 channel work? Right now it just says digital. Does 6. 1 channel sound better?
6.1 stands for six speakers and one sub-woofer - a total of seven actual speakers giving you the surround sound effect. Before it can play a surround sound environment, the media - a CD or DVD must have it encoded on the disc, like a movie that has 6.1 surround sound recorded on it or a music CD with recorded surround sound. Otherwise, it will just play stereo audio - two speakers and the others are redundant. And yes, it does sound better as if you are in the actual area it was produced - like if you were there.
Feb 23, 2011 | Yamaha RX-V459 Receiver
Subwoofer not working.... JVC surround sound system 778V Subwoofer Part Number SP-PW37-SUB I hear a hum coming from unit so there's power going to it. I hear weak bass thumps with volume turned all the way...
A connectivity check could provide the solution, notice any wrong wire connections on device or any other devices requiring interconnection. The woofer would perform properly when the connections that provide current for woofing are approapiate
important notes
1. Trace the connection from Recorder or sound output to the woofer device
2. The wiring connections should be sound and video ouput into sound and video output into woofer.
3. The connections if any problems would be located at the stereo recorder or device producing the spund and video. Check the connections of wires on the recorder device ensuring rewiriing
4. finally, adjust the equalisers if any the buttoms could have been disbled by master switch hindering full blaster boost sound.
Dec 05, 2010 | JVC RX-778V
Yamaha RX-V861 no sub woofer output
It sounds like you have switched off the sub channel.
Keeping pressing C Level on the remote till you see SWFR.
Press D l / h to adjust the speaker output
level.
Jun 25, 2017 | Yamaha RX-V861 Receiver
I get no bass sound from sub-Woofer connected to Yamaha RX-V465
Check your speaker settings in Setup menu / Speaker Setup / Manual / Config (and then in this submenu also Equalizer).
In Config, choose where should low frequency sound go - subwoofer and/or front speakers (if they are big enough). The settings are: Bass Out: SWFR/Front/Both.
Also check Subwoofer phrase in SWFR Phase.
Check settings of all speakers, they can be Large / Small / None. If small, frequencies lower than "Crossover" settings, will not be put on them.
Nov 13, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
JVC TH-M45
no, u cant use the speakers with other normal DVD player because it wont have amplification for the speakers... u can use the sub to other dvd player because its inbuilt 120 watt woofer. ur dvd player is 5-disc player as wel as 120 X 2 and 80 X 3 watts amplifier (AV receiver ).... so just the JVC better sound thru the sub and speakers... ENJOY
kanny_amancha@yahoo.com
www.kanny-sounds.blogspot.com
Jan 24, 2009 | Pioneer 1000 Watt 5.1 Surround Sound...
Subwoofer speaker
See page 3 at manual below. It seems like coaxial cable with RCA ends.
http://resources.jvc.com/Resources/00/00/96/LET0117-001B.pdf
Jan 02, 2009 | Audio Players & Recorders
Jvc rx-e100rsl home cinema control center
unless there are some other connectors that may be used, i would think that the issue would be resolvable thru the system settings menu, there may be a speaker arrangement setting somewhere in the menus. The Sub is a .1 setting like 5.1 or 7.1, perhaps even 2.1 where the beginning number is the speaker channels and .1 is the sub. I would think with the sub being on a mono channel it woul/should work with any setting. If there is any more info you could supply I will further research this issue and try to help you get the sub working.
Jan 27, 2008 | Audio Players & Recorders
JVC RX-809V
Go to the following website www.servicemanuals.net where you can get the service manual for $17.00, unbelieveable, don't you think? The service manual should help you sort out your hookup problems. Good luck.
Jun 10, 2006 | JVC RX-818V Receiver
JVC RX-5020VBK Receiver Logo
205 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
