Question about Acer NSK8458AN Keyboard
Attaching to multi media projector issue.
When I attach an NEC projector to the laptop, I am unable to see the content on the laptop. Another time, I tried to show a DVD through the projector. I saw my screen saver on the wall and the movie on the laptop.
    Sergeant:
  • 366 Answers
A Function Key cpmbination is driving display choice: on my Acer (travelmate) is FN + F5 on your model could be different (On Compaq 6710 is FN+F4)
Check your manual or your keyboard for function symbol (Blue marked).
Allow time to perform a switch
Posted on Jan 04, 2009
Nec MT1060 blue screen when connected to a Hdmi source thru dvi port.Dvi setting to match Hdmi resolution.tried different cables and dvi to Hdmi adapters....any ideas..??
Hi Genaro,
Sounds like an issue with the HDMI HDCP content protection. I do not think it will be possible to connect using a DVI to HDMI cable.
Jan 19, 2014 | NEC MT1060 Multimedia Projector
The lamp lights on my NEC 4001 are blinking 6 times in a loop. I am unable to get any light from the lamps or connect to my pc.
check the lamp first
there are 2 lamps in the projector ,
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Oct 18, 2013 | Bti Nec Np4000/4001 Replacement Projector...
NEC WT610. projected image is backwards. Unable to maintain image from laptop
use the menu to change orientation of the projected picture
Jul 08, 2011 | NEC WT610 DLP Projector
I have the NEC projector connected to a laptop but I do not know how to get the image to appear on the wall. The power is on and I see light but not the Powerpoint presentation that is on my screen. Please...
dear friend for this you have to configure you display settings
right click on desktop and click on properties now click on settings and see for the setting you have mentioned select the second display adapter appear in the dialouge box and save it and close the dialouge box. now you can see your contents on your projector vote me if it helped gagan
Mar 15, 2011 | NEC MultiSync MT1020 Multimedia Projector
Need to replace NEC Lamp Unit in VT75LPE. Unit is bolted to ceiling in library and unable to be detached easily. What is procedure for replacing lamp?
Hi. You are most likely going to have to remove the projector *and* the projector mounting plate in order to access the lamp door. Mark the orientation of the projector mount plate with a marker and set aside. Remove the lamp door with a proper screwdriver. The PROJECTOR MUST BE COOL TO PROCEED!! The lamp will be secured, usually with 2 screws. Loosen these screws--new screws should come with the new lamp--already held in position. Using the hinged metal handle, pull the old lamp straight up and out of the projector. ( you might have to wiggle it and work it out steadily--its a precision fit) Take your time and *don't force* it! Carefully slide the new lamp into position, taking care that the power connector on the lamp assembly is properly seated. MAKE ABSOLUTELY SURE YOU DO NOT TOUCH ANY LAMP GLASS WITH YOUR FINGERS!!! If you do get finger prints on any glass surfaces, carefully wipe them off completely with a dry, soft cloth--DO NOT USE CLEANER!! This is critical to the life of the new lamp--finger oil attracts heat and will cause the new lamp to fail pre-maturely. Re-attach the lamp door--make sure you don't over-tighten any screws on lamp or door--they need to be firmly tight but not "gorilla" tight! lol Clean any dust filters thoroughly before re-attaching the mounting plate--you'll be glad you did! After re-mounting the projector, power it up and go into the menu in order to reset the lamp timer.--Hope I helped you!---Rick
Dec 30, 2009 | NEC (VT75LPE) Projector Lamp
Suddenly stops showing the picture
The cause is a sudden overheat but when restarted its fine then it goes again this intermittant issue is with the lamp beleave that or not i found replacing the lamp solved the issue perm.
Thanks and please leave postive feedback..
Nov 17, 2009 | NEC NP60 Projector
I have replaced bulbs in 3 different types of NEC projectors: a silver, older model thta uses a VT60LP bulb, model VT595 and VT470. The lamp will still not work - the power and status light just continue...
I had the same issue, what I figured out was that I never removed the lamp door correctly, causing a small plastic piece to break off. To see if this is also your problem, inspect the back of the lamp door, top right corner, if it seems a rectangular plastic piece is missing, thats the problem. It presses in a small button nearby the lamp to let the projector know it's safe to power on.
Sep 01, 2009 | NEC VT695 LCD Projector
Nec Lt265 extremely dim
I had this same issue and it was the bulb. We had 2 of the NEC LT265 projectors so we swapped the bulbs between the 2 and it tracked with the bulb.
Mar 23, 2009 | NEC VT676 Multimedia Projector
NEC VT460 issue with RGB input saying out of range. Using cable between laptop and projector
Dear please set the resolution of your PC or Laptop ,so that it can give O/P at same resolution as projector. For issue regarding resolution supported by Projector go through manual of Projector.
regards,
rakesh Kumar
Network Support Engineer
Nov 12, 2008 | NEC VT47 Multimedia Projector
Acer NSK8458AN Keyboard Logo
120 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
