Question about Philips 26PF9966 26 in. LCD Television
Philips 23PF9966/37 color problem!
I have a 23PF9966/37. my TV picture turned Green and cartoony like colors. Can you please advise me what component(s) might be defective or where I can get the service manual.
  • g-wiener Jan 16, 2009
    I have a 23PF9966/37. After a power failure my TV picture
    turned Green. Can you please advise me what component(s) might be
    Thank you
  • jcarb123 May 11, 2010
    Does the picture look like this?
Try to adjust it in the Service Alignment Mode (SAM).
Press 062596 followed by the STATUS button (upper left). Navigate to "White Tone", press the right key to enter and select "Normal" mode. Set the colors:
Red = 135, Green = 128, Blue = 133.
The "Cool" and "Warm" menus are deltas from the "Normal" settings:
COOL: R -3, G -1, B 5
WARM: R 2, G -3, B -13
Press the "MENU" button to return to the main menu, then the "Power" button to turn the TV off.
Posted on Jun 15, 2009
I have a Philips dlp60pl...the picture flickers and the color turn red to green then back to normal color, could this be the bulb.
No.Do the tv pictures colors back ground flashes black and white when this problems happen?Ur tv now make any humming sound or motor noises?Yes,than the tv colors wheel it is the causes and the problems.The tv colors wheel it is dying and starting to be worn out.The tv colors wheel itself it is starting to come out of the spinning motor axis.The tv colors wheel have to be replace to fix this problems.The tv colors wheel sit way back of the tv,must have to take out many mechanical parts before u can even come to the tv colors wheel itself to replace it.If u have no mechanical skills don't tries to replace the tv colors wheel ur self.Hire a tv Tech. to replace the tv colors wheel it is ur best bet.
Sep 24, 2011 | Philips 60PL9200D Projection Televisions
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
My philips 46pp9302 picture looks green ive lined up the blue and red colors but dont know whats wrong.....help
The tv have a problems known as a convergence problems,it dead.The tv color lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead parts.The 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost like $300-350 for parts and labors.
Oct 27, 2010 | Philips 46PP9302 46" Rear Projection...
Sony trinitron wega kv-36fs200 36' tv is missing green color
sounds like a major fault with the line output transformer/power board. if no green on screen, tube is on it's last legs. Advise to scrap, not to repair, cost in excess of £200
Oct 23, 2009 | Televison & Video
Most likely you can adjust it in the Service Alignment Mode (SAM).
Jun 15, 2009 | Philips 26PF9966 26 in. LCD Television
PHILIPS MAGNAVOX Picture Color Off
hi i hope i can help you?. please check the arial connection. may i please ask you if you open up . go to where the red light is and check for any adjusters.if you find turn down the red top tip if you use a mirror and place in front of the tv and tha t way you will see what is hapining.
May 08, 2009 | Philips Televison & Video
Picture is multi color, double shadows, curved
This is failure of convergence out ICs in TV. Qualified TV tech will replace convergence out ICs or board.
Feb 14, 2009 | Philips Televison & Video
Color real cartoony and low contrast value
I solved the problem by connecting a VCR to the TV and surfed the tv channels with the vcr remote, some how the new video input cables and the vcr solved this problem for me. I just set the tv on Video Input 1 and use the VCR. It wasn't as hard as I thought the problem was, just poor signal.
Oct 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
No Red color on Phillips tv model 60PP9202/17F
one of the picture tubes inside the went bad you 'll need a tech
Aug 13, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 26PF9966 26 in. LCD Television Logo
306 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
