Question about Cisco Computers & Internet
Cisco ip phone spa504g orange lights - Cisco Computers & Internet
SOURCE: Cisco 7912G IP Phone
You can not shut off CCM CSRST fall Back service. You need to either remove SRST reference in the device pool or for the phone specific configuration. I suggest you create device pool similar to one you have but without SRSR reference. Then you need to re-apply device pool in the phoone configuration and restart the phone.
Posted on Jun 09, 2008
  • 5 Answers
SOURCE: Cisco 7970 ip phone, can't pickup call
Make sure you have both phones in the same call pickup group. I have never used the group pickup button. The regular pickup button is what I use.
Just to be clear the procedure is..once phone A rings you hit the pickup button on any other phone that is in the same group as phone A. After you hit the pickup button the call will be drawn to the phone that you hit the pickup button on. Once the call is on that set hit the answer button to answer the call.
Posted on Aug 01, 2009
  • 121 Answers
SOURCE: CISCO IP PHONE 7941 -add background images (user preferences,
See Cisco's user guide regarding template modification and customization at http://www.ciscosystems.am/en/US/docs/voice_ip_comm/cuipph/7960g_7940g/7_0/sip/english/administration/guide/7960usrS.pdf
Posted on Feb 19, 2010
SOURCE: CONFIGURE ip pHONE 7912G
My phone cuts in and out. I am hooked up to a Rogers Rocket Hub with a static ip address.
Posted on Jul 12, 2010
  • 17 Answers
SOURCE: Good day! How Cisco 7911G IP Phone can connect to
You must have a valid functional callmanager. You then set option 150 in your DHCP which specifies the IP address of the TFTP server which is ultimately callmanager.
Posted on Jan 11, 2011
Why wont the setting Call foward No Answer Activation connect to cell phone number set
While farwarding the call you need to press the call farwarding option.
Then try to put the number with the ISD code for example +919857012356 Country code must be there before the number.
Jun 25, 2014 | Cisco SPA504G IP Phone
Cisco 504g will not power up
Plug out the cable from this and put in again or reset the device.
May 08, 2014 | Cisco SPA504G IP Phone
Cisco SPA504G Firmware update issue
You need to make sure that your laptop and IP phone are on the same network subnet. For instance, if you IP phone's IP address is 192.168.2.24 than your laptop must be on the same network addressing scheme, such as 192.168.2.23.
<a href="http://www.ciscopowercube.com">Cisco CP-PWR-CUBE3</a>
Sep 07, 2012 | Cisco SPA504G IP Phone
We cannot get the 504g will not broadcast its caller ID. it only shows 'restricted'. why won't it display correctly.
change the configuration in your IP Phone change the setting to allow broadcast caller ID .
May 12, 2011 | Cisco SPA504G IP Phone
How can I clear / reset a Cisco IP Phone 7910
How to set a Cisco IP phone to factory default Reset configuration of Cisco IP Phone (7910, 1911, 7940, 7941, 7960, 7961)
To set the Cisco IP phone to factory default completes the following steps: should be completed:
For 7940, 7941, 7960, 7961 phones:
1. Power up the phone (unplug power cable and plug in again and hold the # key.
2. Release # when lights start flashing.
3. Press 123456789*0#.
4. Press 1 to keep network configuration or 2 to lose the network configuration.
For 7906G and 7911G phones:
2. Release # when MWI starts flashing.
3. Press 3491672850*#.
Oct 28, 2010 | Cisco 7910 IP Phone
How do you make a background picture show up on a Cisco 504G phone. The online Config Utility asks for a Bitmap URL and I found one online that I liked, the only thing on the page is the picture, but it...
You need to make the bmp file the correct format
128 x 48 pixels 1-bit deep
Simply upload this to a webserver and point the backupground url at the address.
www.mpbtech.com
Oct 07, 2010 | Cisco SPA504G IP Phone
No dial tone on cisco 504G phone
to use an Ethernet phone you will need a VOIP supplier ( You will need to Google this for the country you are in ) . You will not be able to use it until you have these set up. Ethernet phones are not like a standard home phone which use your local exchange to route your calls they use servers on the internet to do that and route your call to landlines.
I hope this helps if so please give me a thumbs up
Jul 23, 2010 | Cisco SPA504G IP Phone
VOIP headset PlantroMX500i 72517-01 to use with Cisco IP spa504G
mx500i.gif MX500i 3-in-1 VoIP Headset Sorry your headset + phone combination is not currently listed in our database. Please contact Plantronics Technical Assistance Center to confirm compatbility
Versatile 3-in-1 Headset for Internet/VoIP, cordless and mobile calls
Part Number: 72517-01
Apr 21, 2010 | Radio Communications
CISCO 7912 Ip Phone,Red lights are continuously on.
Well, in most Cisco VoIP phones those lights are used to tell you if you have a voicemail. Have you checked your vm and cleared any new ones? This might be your issue ;)
Oct 14, 2008 | Cisco 7912G IP Phone
Computers & Internet Logo
1,896 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
